He’s not looking for a mere 16".
Easy fix, add this (though the brightness isn’t quite there):
Yea, who doesn’t have a spare $4,000 ($1 per pixel) burning a hole in their pocket? And if you check, it does not appear to be available for sale anymore. Which might be good, some reviews are not great. Hard to ignore considering the very premium price
OP has the budget. Just not sure if it’s a budget for the solution, or budget for Framework specifically. (When you pay for a ‘solution’, you don’t think about things like “that heat pipe is too expensive”)
$4k for a display in the colour grading space is ‘low-mid range’ in that space (price-wise).
Needing / wanting a solution that’s not needed by everyone…is always going to be expensive. No news here.
That’s why mobile workstations with 10bit displays (GPU and panel support, plus ISV) tend to have a $3.5k-ish starting price. People who priced the hardware know the use case, the audience, the specific fields / discipline that needs this…who has the budget.
(Also why any ‘workable’ MBP for video editing starts at $4k really when you get the storage and memory and cores up to scratch. They’re not charging you for the hardware, they’re charging you for your use case. They want a cut of the profit that you completed the work using their hardware.)
@Second_Coming
Thanks for your useful information!
For you laptop information, unlucky, I use 64GB of ram.
I use rotoscope of ae, magic mask of dr, so I need tons of ram.
But your portable display is very helpful like an oasis at desert.
There are tons of high-spec laptops, but not portable display.
I really appreciate it. Thank you.
I’ve been eyeing the Lenovo P16 for awhile now. Waiting for its 13th gen refresh with a 13980HX. For now, I’m just using a Strix G16 (upgrade to 64GB of RAM…but I need 128GB in some scenarios…which my older P15 Gen 2 has). Unlike you though, I don’t have a 10bit requirement. So I just happened to be in the workstation space because of compute requirements…which lowers my cost.
Dell’s Precision 7780 also just hit the market…looking good too.
@MJ1 This guy was waiting for it, and willing for it.
I already prepared 5,000 dollar even with Celeron processor.
If, it is laptop and it’s display has over 200 ppi, 100% dci-p3, 10bit true.
As Second_Coming mentioned, I wrote it on my post already.
Of course it isn’t in my pocket, but afford just after one month.
But thanks to your reply, I found it isn’t available. Thanks
@Second_Coming hope you get proper laptop.
Thanks. Waiting to see what this year’s offerings are like, and how the FL16 specs will look.
Naturally, I’m now assuming you’re 7ft tall and over 140kg.
