Hello I am having a few issues with my Framework DIY Edition batch 6.
The first issue is with a USB C to Display Port Cable I can only run the monitor up to 144Hz I have a 360Hz panel at the moment and was curious If I can output to this refresh rate the cable is fine as it outputs at that refresh rate on another system.
The second issue I am having is with the Audio Jack I hear a beep whenever the audio stops or starts I am running Sennheiser HD 650 if that helps at all and I am running on Arch Linux I assume this has something to do with the Tempo codec in the batch 6 models.
Lastly I have an issue where I can be using the external monitor just fine and then when I load up a light game like Bloons TD the monitor stops receiving the signal and I need to open the laptop remove the cable and plug it back in for it to work its quite annoying. I am using autorandr to auto disable the laptop display whenever the usb c to display port cable is connected to the laptop.
Any help would be greatly appreciated thanks!
