Try setting up another network that has more conservative wireless settings, just as a test case, like I outlined in a comment above. That should eliminate the dropouts, it has in my case. It’s obviously not ideal as it will still be comparatively slow, but it at least makes the connection usable for most use cases until the driver situation for this chipset under Linux gets fixed.
Hey, thanks for the advice. However, I’d rather like to see if there is any chance in getting the MT7925 to work properly under Linux, or if I need to switch out my wifi card.
I took a look at the linux commit history of the MT7925 driver in the kernel and I do see quite some movement between v6.17 and the current v.6.19-rc2 (as of writing right now).
In particular I see
commit 066f417be5fd8c7fe581c5550206364735dad7a3
Author: Quan Zhou quan.zhou@mediatek.com
Date: Tue Nov 18 19:54:54 2025 +0800wifi: mt76: mt792x: fix wifi init fail by setting MCU_RUNNING after CLC load
commit 3bc62aa4484dcb9529fea70e756743769b1145e6
Date: Fri Oct 31 17:03:51 2025 +0800wifi: mt76: mt7925: add auto regdomain switch support
commit 2a035ae2062f38dc5183002d1c5a64ca682170c1
Date: Wed Oct 1 09:25:06 2025 +0800wifi: mt76: mt7925: cqm rssi low/high event notify
Potentially:
commit f5160304d57c5543c63404a15cc8737ef714b669
Date: Mon Sep 1 15:02:33 2025 +0200wifi: mt76: mt7996: Enable MLO support for client interfaces Report MT7996 MLO STA capabilities to mac80211 stack. Signed-off-by: Lorenzo Bianconi <lorenzo@kernel.org> Link: https://patch.msgid.link/20250901-mt7996-enable-mlo-client-v1-1-50c46317325d@kernel.org
alltough this should just be a refact for 7925, but maybe they also “sneaked” in a fix here.
and maybe
commit d54424fbc53b4d6be00f90a8b529cd368f20d357
Date: Mon Sep 1 15:32:00 2025 +0800wifi: mt76: mt7925: add pci restore for hibernate
and
commit c7c682100cec97b699fe24b26d89278fd459cc84
Author: Rosen Penev rosenp@gmail.com
Date: Thu Sep 11 15:16:19 2025 -0700wifi: mt76: mt76_eeprom_override to int
There are more commits regarding the mt7925, so in general it seems to remain a region of active development in the Linux kernel, even tough its initial commits are by now two years old.
As I’m on bazzite changing the kernel is quite a pain for me and to see if v6.19-rc2 does any good to my wifi issues. Anybody here who can run some iperf performance tests on the v6.19 kernel and give me some feedback?
Kernel v.6.18 seems to only contain the
commit. I rather not expect much improvement between v6.17 and v6.18, but you never know. ![]()
Its good to see more changes are getting merged.
However, the reality is that there still many issues with this card on Linux, regardless what tricks to try.
As stupid as it sounds, for now, swapping the card for an Ax210 really was the best solution for me. If in the future the drivers, firmware etc of the 7925e improve more and the card become more stable, I can always swap back.
I did some more experiments.
I exchanged the firmware blobs for the MT7925 with the most recent one on: linux-firmware
This is not ideal, as it keeps the linux diver (part of the kernel) unchanged but changes the mediathek provided firmware blob used by the kernel. (On Bazzite this can be done with OverlayFS.)
I didn’t do poper testing with the original and then changed firmware blob, but I compared it to another laptop with an old Intel 8265 / 8275 I have. Both latops are the identical framework laptop only the network card is different and the performance difference is significat:
Mediathek: 20-26 MBits/s (Exchanged Firmware, 5GHz)
Intel: 184-192 MBits/s (5GHz)
Mediathek: 43-58 MBits/s (Original Firmware on Bazzite, 2,4 GHz)
Mediathek: 18-25 MBits/s (Original Firmware on Bazzite, 5GHz)
The laptops are placed back to back and use the same desk and use the same wifi connection. In theory Meidathek should be a lot faster as it can use MIMO and Intel can not, but as we can see, that doesn’t really matter if you driver/firmware is broken.
In a nut shell, I don’t expect any significant improvement of the Mediathek with kernel 6.19 and thus I will try to give back the Mediathek chip and request another chip.
This is the same wifi card default on the Framework Desktop and I’ve been going crazy trying to fix different issues with it. Sent some 11 patches upstream already today.
Yeah, I think patches fix most of these issues, too. If Framework sends me a laptop, I would be happy to test it for them. ![]()
Do you have a driver build with all of these changes implemented? I would be happy to test it out ahead of these commits making it to main.
Looks like a CVE was resolved against this today: https://www.cvedetails.com/cve/CVE-2026-23363/
Hope that draws some more attention, I would really like to have a fully functional experience with this card.
I’m on fedora 43 on framework Laptop 16 and the mediatek rz616 card won’t recognize my bluetooth speaker at all. Do the Intel versions of framework laptops ahip with Intel wifi? I wonder if anyone is having issues with those.
I’m on Ubuntu 25.10 (kernel 6.17.0-19) and experiencing random WIFI drops with this card (MT7925 (RZ717)) on FW16 too. The trick with wifi.powersave = 2 helped improve stability, but drops still happen anyway from time to time. Seems like these issues are not fixed by now and Zac’s PRs are not merged. Sad btw. So maybe the only valid option for now is switch to Ax210?
Whenever your WiFi drops, does it still say your network is connected? I’ve had issues with a Mediatek MT7921 on my desktop as described here.
Also, I see that you’re using quite an old kernel (6.17.0-19). I would say with Mediatek Wi-Fi cards, if you are ever experiencing an issue, try to use a newer version of the Linux kernel to see if it helps.
Hey everyone,
I ran into a Bluetooth issue on my Lenovo Legion 5 (MT7925 WiFi/Bluetooth chip) after updating my kernel on Linux Mint 22.3 (Ubuntu 24.04 base). Thought I’d share the fix in case it helps someone else.
The Problem
After a reboot:
Bluetooth wouldn’t turn on I rautomatically
bluetoothctl listsometimes shVerellenowed nothing -
Or the controller existed but showed:
Powered: no -
Had to manually enable Bluetooth every time
Cause
The Bluetooth device (USB ID 0489:e111, Foxconn / MT7925) is not recognized automatically by the btusb driver in newer kernels.
So:
The device shows up in
lsusb -
But the driver doesn’t bind to it
And Bluetooth doesn’t power on
The Fix (Permanent)
1. Create a udev rule:
sudo nano /etc/udev/rules.d/99-btusb-mt7925.rules
Paste this:
ACTION=="add", SUBSYSTEM=="usb", ATTR{idVendor}=="0489", ATTR{idProduct}=="e111", RUN+="/bin/sh -c 'echo 0489 e111 > /sys/bus/usb/drivers/btusb/new_id; sleep 1; /usr/bin/bluetoothctl power on'"
2. Reload udev rules:
sudo udevadm control --reload-rules
sudo udevadm trigger
3. Reboot
reboot
Result
After reboot:
Bluetooth turns on automatically
Devices reconnect normally
No manual steps needed
Notes
This is mainly affecting MediaTek MT7925 users
Happens more often on newer kernels (6.6+)
It’s basically a missing device ID in the btusb driver
I also reported this upstream to the Linux kernel, so hopefully it gets fixed properly in a future update.
Bonus Tip
If your Bluetooth completely disappears from lsusb, do a full shutdown and hold the power button ~15 seconds (power reset). That brought mine back.
Hope this helps someone!
So, I switched to Intel Ax210 and it’s completely ok since then
