when my laptop reawakens from hibernation wifi fails to reconnect. Ive seen this issue before but they are all old and they get closed after saying just reboot the card every wakeup. Is there any proper fix found or in the works?
linux kernel ver
6.9.0-273linux-tkg
this has appeared on botht the standard arch kernel and the tkg built one
network manager logs after a hibernate when the wifi is broken my only fix thus far has been reboot
Jul 07 00:02:05 framework-16 NetworkManager[528]: <info> [1720306925.8286] manager: (p2p-dev-wlp1s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/11)
Jul 07 00:02:05 framework-16 NetworkManager[528]: <info> [1720306925.8287] device (p2p-dev-wlp1s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Jul 07 00:02:05 framework-16 NetworkManager[528]: <info> [1720306925.8289] device (wlp1s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Jul 07 00:02:05 framework-16 NetworkManager[528]: <info> [1720306925.8292] device (p2p-dev-wlp1s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.8534] policy: auto-activating connection 'SKYDVHIM' (3e71d08f-fffc-40d7-9d30-91e03e050829)
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.8537] device (wlp1s0): Activation: starting connection 'SKYDVHIM' (3e71d08f-fffc-40d7-9d30-91e03e050829)
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.8537] device (wlp1s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.8538] manager: NetworkManager state is now CONNECTING
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.8877] device (wlp1s0): set-hw-addr: reset MAC address to FC:B0:DE:18:25:89 (preserve)
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.9297] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.9299] device (wlp1s0): Activation: (wifi) access point 'SKYDVHIM' has security, but secrets are required.
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.9300] device (wlp1s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.9301] sup-iface[35fa2d5854664971,8,wlp1s0]: wps: type pbc start...
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.9303] device (wlp1s0): supplicant interface state: disconnected -> interface_disabled
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.9304] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected -> interface_disabled
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.9311] device (wlp1s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.9312] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.9313] device (wlp1s0): Activation: (wifi) connection 'SKYDVHIM' has security, and secrets exist. No new secrets needed.
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.9313] Config: added 'ssid' value 'SKYDVHIM'
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.9313] Config: added 'scan_ssid' value '1'
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.9313] Config: added 'bgscan' value 'simple:30:-65:300'
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.9313] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.9313] Config: added 'auth_alg' value 'OPEN'
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.9313] Config: added 'psk' value '<hidden>'
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.9495] device (wlp1s0): supplicant interface state: interface_disabled -> inactive
Jul 07 00:02:15 framework-16 NetworkManager[528]: <info> [1720306935.9496] device (p2p-dev-wlp1s0): supplicant management interface state: interface_disabled -> inactive
Jul 07 00:02:17 framework-16 NetworkManager[528]: <info> [1720306937.0428] device (wlp1s0): supplicant interface state: inactive -> authenticating
Jul 07 00:02:17 framework-16 NetworkManager[528]: <info> [1720306937.0429] device (p2p-dev-wlp1s0): supplicant management interface state: inactive -> authenticating
Jul 07 00:02:21 framework-16 NetworkManager[528]: <info> [1720306941.8136] device (wlp1s0): supplicant interface state: authenticating -> disconnected
Jul 07 00:02:21 framework-16 NetworkManager[528]: <info> [1720306941.8136] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating -> disconnected
Jul 07 00:02:21 framework-16 NetworkManager[528]: <info> [1720306941.9137] device (wlp1s0): supplicant interface state: disconnected -> scanning
Jul 07 00:02:21 framework-16 NetworkManager[528]: <info> [1720306941.9138] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected -> scanning
Jul 07 00:02:41 framework-16 NetworkManager[528]: <warn> [1720306961.6581] device (wlp1s0): Activation: (wifi) association took too long, failing activation
Jul 07 00:02:41 framework-16 NetworkManager[528]: <info> [1720306961.6581] device (wlp1s0): state change: config -> failed (reason 'ssid-not-found', sys-iface-state: 'managed')
Jul 07 00:02:41 framework-16 NetworkManager[528]: <info> [1720306961.6585] manager: NetworkManager state is now DISCONNECTED
Jul 07 00:02:41 framework-16 NetworkManager[528]: <info> [1720306961.7073] device (wlp1s0): set-hw-addr: set MAC address to 46:0D:05:93:40:F6 (scanning)
Jul 07 00:02:41 framework-16 NetworkManager[528]: <warn> [1720306961.7495] device (wlp1s0): Activation: failed for connection 'SKYDVHIM'
Jul 07 00:02:41 framework-16 NetworkManager[528]: <info> [1720306961.7497] device (wlp1s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Jul 07 00:02:41 framework-16 NetworkManager[528]: <info> [1720306961.7683] device (wlp1s0): supplicant interface state: scanning -> disconnected
Jul 07 00:02:41 framework-16 NetworkManager[528]: <info> [1720306961.7683] device (p2p-dev-wlp1s0): supplicant management interface state: scanning -> disconnected
Jul 07 00:02:41 framework-16 NetworkManager[528]: <info> [1720306961.7735] device (wlp1s0): supplicant interface state: disconnected -> inactive
Jul 07 00:02:41 framework-16 NetworkManager[528]: <info> [1720306961.7735] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected -> inactive
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.7886] policy: auto-activating connection 'SKYDVHIM' (3e71d08f-fffc-40d7-9d30-91e03e050829)
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.7893] device (wlp1s0): Activation: starting connection 'SKYDVHIM' (3e71d08f-fffc-40d7-9d30-91e03e050829)
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.7894] device (wlp1s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.7895] manager: NetworkManager state is now CONNECTING
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8153] device (wlp1s0): set-hw-addr: reset MAC address to FC:B0:DE:18:25:89 (preserve)
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8574] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8576] device (wlp1s0): Activation: (wifi) access point 'SKYDVHIM' has security, but secrets are required.
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8576] device (wlp1s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8578] sup-iface[35fa2d5854664971,8,wlp1s0]: wps: type pbc start...
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8580] device (wlp1s0): supplicant interface state: inactive -> interface_disabled
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8580] device (p2p-dev-wlp1s0): supplicant management interface state: inactive -> interface_disabled
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8588] device (wlp1s0): supplicant interface state: interface_disabled -> inactive
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8588] device (p2p-dev-wlp1s0): supplicant management interface state: interface_disabled -> inactive
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8589] device (wlp1s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8590] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8591] device (wlp1s0): Activation: (wifi) connection 'SKYDVHIM' has security, and secrets exist. No new secrets needed.
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8591] Config: added 'ssid' value 'SKYDVHIM'
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8591] Config: added 'scan_ssid' value '1'
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8591] Config: added 'bgscan' value 'simple:30:-65:300'
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8591] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8591] Config: added 'auth_alg' value 'OPEN'
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8591] Config: added 'psk' value '<hidden>'
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8598] device (wlp1s0): supplicant interface state: inactive -> scanning
Jul 07 00:02:51 framework-16 NetworkManager[528]: <info> [1720306971.8598] device (p2p-dev-wlp1s0): supplicant management interface state: inactive -> scanning
lines 586-651/651 (END)
