Arch
Which kernel are you using?
6.11.3-zen1-1-zen
3.05
Which Framework Laptop 13 model are you using? AMD Ryzen™ 7040 Series
I have enabled rfkill-block@bluetooth.service
to block Bluetooth automatically on boot. But I also have suspend-then-hibernate enabled, so I am frequently using hibernate. When I resume from hibernate, Bluetooth is enabled again. I saw Bluetooth disabled state not restored when resuming from disk · Issue #3026 · systemd/systemd · GitHub, which links a kernel bug report that seems to suggest it is a BIOS implementation issue, and that bluetooth should stay disabled even after resuming from disk if rfkill
ed.
Does anyone else have any experience with keeping Bluetooth disabled, especially while using hibernate? Is there a lower level fix for this instead of just making a script that does rfkill block bluetooth
both on boot and on resume?
