my keys f1 to f12 are not working for shortcuts with alt for example the good old alt + f4
shortcut does not work ( and yeah it is configured in KWin ) does anyone know how to solve this ? Or did anybody else encounter this error ?
Hi @Kalinux,
My name is Matt Hartley and I’m the brand new Linux Support Lead for Framework. So with that, sorry for the lengthy delay as I just started here.
- Is this still an issue?
- 11th gen or 12th gen?
- Which distro and release version (if not rolling).
- Has a live USB version of said distro been tested?
Hello Matt the delay is no big problem : ) but the problems are still there
My CPU is the 12th gen intel i5-1240p
I use Manjaro with the Kernel being the Linux Kernel 5.15.76-1
and thanks for your respons and help ^^
This may sound like a silly question, but are you holding down the Fn key to switch the function keys from brightness/media control/volume to F1…F12? Are you using Fn Lock?
This one?
DHowett thanks for the advice i had the fn key auto configured on fkeyslast
solved the problem thanks for your help guys ; )
