Lego Brick Expansion Card
Does that include shipping? Edit: It seems is must.
I just went there and unless their printers are poorly calibrated, it shouldn’t be a problem. The only thing I might worry about is that since they are using ABS plastic, thin features like the walls will be more prone to warping if they don’t have good heating while they print… The toughness will be good, but I’d prefer them printed in PLA, PET-G, or even ASA if possible to keep the small details.
I’d offer you a better deal if I could ship outside the US cheaply, but sadly international shipping is pricey.
Oh, ta.
3dprintmything will do ASA (sadly in black) for sub 12 quid, delivered.
That’s more likely to come out well, I think. Again, the first company’s ability to print the fine details is probably good enough. I suspect the warning is just that, a warning, rather than a “we can’t do this.”
I think real Lego is made from ABS if I’m not mistaken.
I’ve added an STL for a Brick System USB-C Expansion Card mod built with the mod files from my other post.
Let me charge it for you. :notes:
That’s even more useful as you don’t loose the USB port. Now to find a really short USB-C extension cable…
Like,
https://www.amazon.co.uk/Extension-RIITOP-Extender-Compatible-Nintendo-Red/dp/B08DR6R5SZ?th=1
is far too long and a fixed extender like
https://www.amazon.co.uk/Extension-Converter-Thunderbolt-Connector-Compatible-Gray/dp/B09BJP78PW?crid=19CSL4HXXVJKY
isn’t long enough…
The mod doesn’t add to the dimensions of the card if that’s the implication. You unscrew the old one and put the printed version in its place.
I am confused then… so with the hollow version, you can just gut the official expansion card and transfer it across ?
Yep! There’s some small screws on the official Expansion Cards that allow them to easily be opened. You can then separate the bottom and top pieces and access the PCB. The printed part just swaps in place of one of these halves.
I found one media article about this expansion card :slight_smile:
Framework Laptop Brick System expands notebook with Lego feet, wheels, cable holders and more - Notebookcheck
https://www.notebookcheck.net/Framework-Laptop-Brick-System-expands-notebook-with-Lego-feet-wheels-cable-holders-and-more.898451.0.html
Thank you for sharing, there was also a small blurb on The Verge!
@bonkrat, I am considering doing a “Inspiration” series of SNACK drawers based on some ideas floating around that could be incorporated into my project. I noticed that your Printables license allows commercial use, but I still feel it’s prudent to ask you for permission before even selling a product inspired by your design.
Along those same lines, would it be OK to sell your base designs? I’m happy to negotiate some kind of profit sharing (probably would net you ~$20 a year at most).
Thank you.
Thanks for asking - feel free to sell the designs as long as attribution is included!
Sounds good. Some Bonk Boxes might be in order then.
I just got one printed with a UK-based company called SGD 3D for £7.93 including delivery. Opted for their premium Vapour Smoothed finish :smile:
That’s a very good deal!
aww man…couple of servo’s in there, small microcontroller hooked up via the usb-c …laptop already has cam/bluetooth/wifi/power …app on your mobile … I already see this zipping through the house
Printed out a couple of these in PLA on my A1 mini. I found the ones which are solid work best printed face down so you get a nice flat finish, and the expansion card one works best laid face up. I didn’t need to add any supports, but did need to do a bit of filing to make the bobbles mate properly with actual Lego bricks
Wonder if one could use the 4 studs for usb2 connection and mod other stuff to have 4 studs wide usb-L connectors…
