Module question
if i just plug a usbc cable right into the usbc port where the modules connect would it charge
Welcome to the community.
The USB C expansion card is basically just a pass through. So if you don’t have a USB C expansion card, yes, you could plug the USB C charger directly into the port on the mainboard and it will charge.
