Today, I decided to take a plunge and open up my Framework 13 myself. Luckily, all of the captive fasteners remained in, with the exception of the one that would normally push up the input cover at the front right corner. The last person to work on my laptop claimed these fell out, necessitating their replacement. But, I didn’t lose anything, and nothing fell out of the bottom while I was flipping the laptop back over.
My first thought upon opening the laptop was, this input cover is thin. A lot thinner than I thought it would be. My second was, I didn’t expect the input connector cable to feel like a thin flat peace of paper. I’ve encountered some cables like this before, a type of ribbon cable I believe. I suppose I should have expected this given how thin the laptop is, but I’d never actually felt the input cover cable before.
Everything was very tightly placed within the laptop chassis, more so than I expected. I thought there might be a little room to work with things a bit more finely with some room for error, but there doesn’t seem to be. It takes some getting used to, and I doubt I would ever attempt to upgrade the Mainboard myself. I’ve read enough horror stories about the tiny WIFI antenna connectors to know that I’d rather not have anything to do with them if I was ever changing a WIFI card. Not to mention all the other connections to the Mainboard. I suspect changing the battery would require a great deal of accuracy and care, at least on the FW13 where the little pins are for the battery connector.
While the laptop was open, I switched to another SSD, a Samsung. I wanted to see if I could get Arch Linux running on the system, which I did, though it was just a basic console install. Oddly, for some odd reason, fwupd did not recognize my EFI partition despite it clearly being marked and mounted under /boot, and I have the same exact install on another system with no issues in that regard. A problem for another day, I suppose. And, Arch took a long time to boot. Most systems using such an install take perhaps ten seconds to present the login screen, but on the Framework, it took over thirty seconds. No idea why, as efibootmgr recognized it just fine.
Anyway, dealing with the tiny fastener for the SSD was an adventure I wouldn’t want to do too often, but I did manage to put in the Samsung SSD. Then, when I was done, I switched back to the Western Digital SSD that was originally in the system. However, now that I’ve put the input cover back on for the second time, something sounds hollow underneath the keyboard, despite the fact that the input cover appears to fit perfectly. Everything is working at the moment, and whatever is hollow sounding, I have no idea. It’s bothering my OCD though, so I may have to figure out what I’ve done wrong and fix it before I’m completely satisfied. Perhaps I slightly misaligned the thermal pad on the SSD when I put it back on.
Also, in dealing with the input cover, I did bump or rub one of its edges against my screen. I very well could have scratched it, I’m not sure. But, individuals helping me read my screen on my phone didn’t seem to have any problems reading anything, and they didn’t mention any scratches, though I never asked.
Opening the laptop is definitely not something I’m going to do very often, if I can avoid it. I wish there was more room to work with things in the system.
