Physical Volume Control Module
Hey everyone, I’ve always wanted a physical volume slider as a module for my framework and recently came across a usbc device that could do just that. I was planning to 3d print an enclosure such that it can sit flush with the sides of my framework.
Going further I thought about other use cases, perhaps I can create a program that would allow me to change the device’s use cases. Based off a hotkey, I could have it scroll webpages, or zoom in. There’s a lot of use cases!
I’ve gone ahead and ordered the module to start tinkering, would anyone have a recommendation on a usbc-usbc card I can use inside the enclosure?
Here’s the link!
Volume Slider
Interesting idea! I suggest you to get the module first, and then figure out the length needed to make it flush. There are plenty of different USB-Cm → USB-Cf on AliExpress :slight_smile:
