POP OS 22.04 Intel Ultra Core 7 Hardware Acceleration
Happy owner of a new Ultra 7 DIY laptop. I’ve installed POP OS 22.04 and it looks like hardware acceleration is broken or not supported yet? Anyone got vaapi working? Is there a new driver I need to use?
$ vainfo
libva info: VA-API version 1.14.0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so
libva info: Found init function __vaDriverInit_1_14
libva error: /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so init failed
libva info: va_openDriver() returns 1
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
libva info: Found init function __vaDriverInit_1_10
libva error: /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so init failed
libva info: va_openDriver() returns -1
vaInitialize failed with error code -1 (unknown libva error),exit
$ mpv --hwdec=auto Big_Buck_Bunny_1080_10s_30MB.mp4
 (+) Video --vid=1 (*) (h264 1920x1080 30.000fps)
File tags:
 Artist: Blender Foundation 2008, Janus Bager Kristensen 2013
 Comment: Creative Commons Attribution 3.0 - http://bbb3d.renderfarming.net
 Composer: Sacha Goedegebure
 Genre: Animation
 Title: Big Buck Bunny, Sunflower version
[vo/gpu/wayland] GNOME's wayland compositor lacks support for the idle inhibit protocol. This means the screen can blank during playback.
[vaapi] libva: /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so init failed
[vaapi] libva: /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so init failed
Cannot load libcuda.so.1
[ffmpeg] AVHWDeviceContext: Cannot load libcuda.so.1
[ffmpeg] AVHWDeviceContext: Could not dynamically load CUDA
Failed to open VDPAU backend libvdpau_nvidia.so: cannot open shared object file: No such file or directory
[ffmpeg/video] h264_v4l2m2m: Could not find a valid device
[ffmpeg/video] h264_v4l2m2m: can't configure decoder
Could not open codec.
Sorry I don’t have an answer, but I can relate to graphics troubles with Pop + Framework. I can’t remember the exact error messages I was seeing but I believe they were also related to CUDA. I finally gave up trying to get WebGPU / Unreal to work in Pop and switched to Ubuntu, and then everything “just worked” (but don’t get me started on snaps, ugh). Hope you have better luck troubleshooting and please let us know if you figure it out…
Works fine under Fedora with kernel 6.10. What kernel version is Pop! 22.04 using?
6.9, maybe I should try installing pop os 24.04 alpha or install 6.10 from ubuntu mainline.
