Power button(?) doesn't seem to work
I’m not sure if my power button is working. I plug in charger: straight to white light. Plug in with the deck panel removed: Flashing red. I’ve gone through the board reset process: get the blinking red as expected. Checked my CMOS battery with a multimeter: 2.95V
when I press the power button, I get no response. no light, or anything.
I’ve checked the connections visually, nothing seems out of the ordinary.
I was wondering if there was a way to know which pins to check to verify the health of the keyboard, or if there are any other suspects to try with the troubleshoot.
UPDATE: I discovered the mainboard power button. used that, and all is well.
