I am considering buying the Framework laptop. Among other things I am drawn to it for the clean industrial design.
My question is, when using Windows what scale do you set the screen to? If you have a Framework laptop running Windows, please right-click on the desktop, then Display Settings then look under “Scale and layout”. What is the value you see there, by default? It could be a number like 150% or 200%.
I run mine at 175%, but if you want things a little bigger 200% is the recommended and default setting. Personally I’ve still got good eyes so I keep it lower to fit more taskbar icons.
I use 150% scaling. I think of it like having ~1500x1000 resolution but sharper. I run my old laptop (ThinkPad T460s 1920x1080) at 125% scaling (= 1536x864), and the text on it is already looking a bit jagged in comparison
