EDIT:
Got it solved. I needed to enable:
CONFIG_I2C_DESIGNWARE_PLATFORM
which made the brightness buttons show up as ACPI events, and the default ACPI rules automatically changed the brightness in response to those on my system. There might be other stuff needed if someone’s got an even more minimal config than mine, but this is the setting my config was missing.
Original post:
Just swapped out my 11th gen Intel board with the AMD one (7840) a few days ago, and while the backlight works fine, and I can manually adjust it via /sys/class/backlight…, the backlight brightness keys on the keyboard aren’t sending key events (tested with “xev”), nor ACPI events (tested with acpi_listen).
The keys do generate ACPI events on Fedora 39, so I’m assuming that I’m missing some needed kernel module or something on my Gentoo install, though I’m not sure which one, as the diff of the lsmod output doesn’t seem to have anything jumping out at me, though I’m not very familiar with the kernel stuff.
(Edit: My Gentoo machine is on kernel 6.1.57, and the Fedora livecd is on 6.2.9. I also tried 6.5.10 on Gentoo, but that didn’t seem to make a difference (though maybe there’s a driver that’s needed which isn’t in 6.1?))
I’m pasting the diff of the lsmod output in case anyone is more familiar with it. And if there’s any other info that would help, let me know. I’m new to ACPI and a novice with the kernel stuff, so there’s decent odds I’m making some simple mistake or overlooking something simple.
lsmod diffs:
< = my Gentoo lsmod
> = the Fedora 39 lsmod
1,3c1,2
< 8021q
< ac
< aesni_intel
> ac97_bus
> acpi_cpufreq
5c4,7
< battery
> amd_pmc
> amd_pmf
> be2iscsi
> binfmt_misc
6a9,10
> bnep
> bnx2i
11a16
> ccp
12a18
> cec
13a20
> cnic
14a22
> crc32_pclmul
16,17c24,29
< cryptd
< crypto_simd
> cros_ec
> cros_ec_lpcs
> cxgb3
> cxgb3i
> cxgb4
> cxgb4i
20d31
< drm_kms_helper
22,25c33,35
< ecc
< ecdh_generic
< efivarfs
< fb_sys_fops
> edac_mce_amd
> fuse
> ghash_clmulni_intel
26a37,41
> hid_multitouch
> hid_sensor_als
> hid_sensor_hub
> hid_sensor_iio_common
> hid_sensor_trigger
29c44,61
< ipv6
> i2c_piix4
> industrialio
> industrialio_triggered_buffer
> intel_rapl_common
> intel_rapl_msr
> iommu_v2
> ip6_tables
> ip_set
> ip_tables
> irqbypass
> iscsi_boot_sysfs
> iscsi_tcp
> isofs
> joydev
> k10temp
> kfifo_buf
> kvm
> kvm_amd
31c63,72
< mfd_core
> libarc4
> libcxgb
> libcxgbi
> libiscsi
> libiscsi_tcp
> loop
> mac80211
> mc
> mdio
> mii
32a74,104
> mt76
> mt76_connac_lib
> mt7921_common
> mt7921e
> nf_conntrack
> nf_conntrack_broadcast
> nf_conntrack_netbios_ns
> nf_defrag_ipv4
> nf_defrag_ipv6
> nf_nat
> nfnetlink
> nf_reject_ipv4
> nf_reject_ipv6
> nf_tables
> nft_chain_nat
> nft_ct
> nft_fib
> nft_fib_inet
> nft_fib_ipv4
> nft_fib_ipv6
> nft_reject
> nft_reject_inet
> nvme
> nvme_common
> nvme_core
> pcspkr
> platform_profile
> polyval_clmulni
> polyval_generic
> qla4xxx
> qrtr
33a106,107
> rapl
> rfcomm
35,36c109,110
< roles
< sha512_generic
> scsi_transport_iscsi
> serio_raw
37a112
> snd
38a114
> snd_compress
44a121,122
> snd_hrtimer
> snd_hwdep
45a124
> snd_intel_sdw_acpi
48a128,131
> snd_pci_ps
> snd_pcm
> snd_pcm_dmaengine
> snd_rawmidi
50a134,136
> snd_seq
> snd_seq_device
> snd_seq_dummy
52,55c138,152
< syscopyarea
< sysfillrect
< sysimgblt
< thermal
> snd_soc_core
> snd_sof
> snd_sof_amd_acp
> snd_sof_amd_rembrandt
> snd_sof_amd_renoir
> snd_sof_pci
> snd_sof_utils
> snd_sof_xtensa_dsp
> snd_timer
> snd_usb_audio
> snd_usbmidi_lib
> soundcore
> sp5100_tco
> squashfs
> sunrpc
56a154
> tls
59a158
> uas
60a160,161
> uinput
> uio
62,63c163,166
< xhci_hcd
< xhci_pci
> usb_storage
> video
> wmi
> zram
