G’day all,
As of the past few weeks, I’ve been having WiFi issues similar to others out there, however none of the remedies out there (on this forum or elsewhere) seem to rectify my problems.
I first ran into the no connection after sleep issue, but I quickly worked around that by restarting NetworkManager. But now, I can connect to a WiFi network but can’t ping any endpoint, whether it’s a gateway, other device on same network, public DNS server, anything. Strangely though, connecting through a mobile hotspot, such as my temporary iPhone, works just fine. Even ethernet is affected.
I’ve tried different networks, different OS’s (Arch is installed, tried live iso Debian, Ubuntu and Fedora), reseating the WiFi card, updating to beta BIOS 3.03b, tried to make sense and google the errors from journalctl, and given pretty much every solution I’ve found a try; outside of rolling back Arch. I figured that rolling back wouldn’t solve the issue if a live iso didn’t either. Here’s a bit of an info dump below to be thorough. I hope it’s something obvious I’ve overlooked.
Thanks in advance, peeps!
sudo dmidecode -s bios-version
03.03
sudo dmesg | grep mt7921
[ 5.662244] mt7921e 0000:01:00.0: enabling device (0000 -> 0002)
[ 5.666855] mt7921e 0000:01:00.0: ASIC revision: 79220010
[ 5.748428] mt7921e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20240219103244a
[ 6.128853] mt7921e 0000:01:00.0: WM Firmware Version: ____000000, Build Time: 20240219103337
sudo lspci -k
01:00.0 Network controller: MEDIATEK Corp. MT7922 802.11ax PCI Express Wireless Network Adapter
Subsystem: MEDIATEK Corp. MT7922 802.11ax PCI Express Wireless Network Adapter
Kernel driver in use: mt7921e
Kernel modules: mt7921e
sudo pacman -Q networkmanager
networkmanager 1.46.0-2
journalctl -b
Mar 16 11:26:59 framework NetworkManager[956]: <info> [1710548819.0072] manager: NetworkManager state is now CONNECTING
Mar 16 11:26:59 framework NetworkManager[956]: <info> [1710548819.0920] device (wlan0): set-hw-addr: reset MAC address to 14:AC:60:46:98:1D (preserve)
Mar 16 11:26:59 framework NetworkManager[956]: <info> [1710548819.1584] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 11:26:59 framework NetworkManager[956]: <info> [1710548819.1586] device (wlan0): Activation: (wifi) access point 'NoStringsAttached' has security, but secrets are required.
Mar 16 11:26:59 framework NetworkManager[956]: <info> [1710548819.1586] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 16 11:26:59 framework NetworkManager[956]: <info> [1710548819.1638] device (wlan0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 11:26:59 framework ksystemstats[1691]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Mar 16 11:26:59 framework kded6[1558]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Mar 16 11:26:59 framework NetworkManager[956]: <info> [1710548819.1640] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 11:26:59 framework NetworkManager[956]: <info> [1710548819.1641] device (wlan0): Activation: (wifi) connection 'NoStringsAttached' has security, and secrets exist. No new secrets needed.
Mar 16 11:26:59 framework NetworkManager[956]: <info> [1710548819.1642] Config: added 'ssid' value 'NoStringsAttached'
Mar 16 11:26:59 framework NetworkManager[956]: <info> [1710548819.1642] Config: added 'scan_ssid' value '1'
Mar 16 11:26:59 framework NetworkManager[956]: <info> [1710548819.1642] Config: added 'bgscan' value 'simple:30:-65:300'
Mar 16 11:26:59 framework NetworkManager[956]: <info> [1710548819.1642] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Mar 16 11:26:59 framework NetworkManager[956]: <info> [1710548819.1642] Config: added 'psk' value '<hidden>'
Mar 16 11:26:59 framework plasmashell[1589]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Mar 16 11:26:59 framework NetworkManager[956]: <info> [1710548819.1978] device (wlan0): supplicant interface state: disconnected -> scanning
Mar 16 11:26:59 framework NetworkManager[956]: <info> [1710548819.1979] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> scanning
Mar 16 11:27:00 framework wpa_supplicant[1025]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Mar 16 11:27:01 framework wpa_supplicant[1025]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Mar 16 11:27:01 framework wpa_supplicant[1025]: wlan0: SME: Trying to authenticate with 48:22:54:f2:64:d1 (SSID='NoStringsAttached' freq=5240 MHz)
Mar 16 11:27:01 framework kernel: wlan0: authenticate with 48:22:54:f2:64:d1 (local address=14:ac:60:46:98:1d)
Mar 16 11:27:02 framework NetworkManager[956]: <info> [1710548822.3122] device (wlan0): supplicant interface state: scanning -> authenticating
Mar 16 11:27:02 framework NetworkManager[956]: <info> [1710548822.3123] device (p2p-dev-wlan0): supplicant management interface state: scanning -> authenticating
Mar 16 11:27:02 framework kernel: wlan0: send auth to 48:22:54:f2:64:d1 (try 1/3)
Mar 16 11:27:02 framework wpa_supplicant[1025]: wlan0: Trying to associate with 48:22:54:f2:64:d1 (SSID='NoStringsAttached' freq=5240 MHz)
Mar 16 11:27:02 framework NetworkManager[956]: <info> [1710548822.3205] device (wlan0): supplicant interface state: authenticating -> associating
Mar 16 11:27:02 framework NetworkManager[956]: <info> [1710548822.3205] device (p2p-dev-wlan0): supplicant management interface state: authenticating -> associating
Mar 16 11:27:02 framework kernel: wlan0: authenticated
Mar 16 11:27:02 framework kernel: wlan0: associate with 48:22:54:f2:64:d1 (try 1/3)
Mar 16 11:27:02 framework kernel: wlan0: RX AssocResp from 48:22:54:f2:64:d1 (capab=0x1811 status=0 aid=2)
Mar 16 11:27:02 framework kernel: wlan0: associated
Mar 16 11:27:02 framework wpa_supplicant[1025]: wlan0: Associated with 48:22:54:f2:64:d1
Mar 16 11:27:02 framework wpa_supplicant[1025]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mar 16 11:27:02 framework wpa_supplicant[1025]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Mar 16 11:27:02 framework NetworkManager[956]: <info> [1710548822.5541] device (wlan0): supplicant interface state: associating -> associated
Mar 16 11:27:02 framework NetworkManager[956]: <info> [1710548822.5541] device (p2p-dev-wlan0): supplicant management interface state: associating -> associated
Mar 16 11:27:02 framework systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 16 11:27:03 framework wpa_supplicant[1025]: wlan0: WPA: Key negotiation completed with 48:22:54:f2:64:d1 [PTK=CCMP GTK=CCMP]
Mar 16 11:27:03 framework wpa_supplicant[1025]: wlan0: CTRL-EVENT-CONNECTED - Connection to 48:22:54:f2:64:d1 completed [id=0 id_str=]
Mar 16 11:27:03 framework wpa_supplicant[1025]: bgscan simple: Failed to enable signal strength monitoring
Mar 16 11:27:03 framework NetworkManager[956]: <info> [1710548823.5917] device (wlan0): supplicant interface state: associated -> completed
Mar 16 11:27:03 framework NetworkManager[956]: <info> [1710548823.5917] device (wlan0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "NoStringsAttached"
Mar 16 11:27:03 framework NetworkManager[956]: <info> [1710548823.5917] device (p2p-dev-wlan0): supplicant management interface state: associated -> completed
Mar 16 11:27:03 framework NetworkManager[956]: <info> [1710548823.5923] device (wlan0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 16 11:27:03 framework NetworkManager[956]: <info> [1710548823.5925] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Mar 16 11:27:05 framework systemd[1]: fprintd.service: Deactivated successfully.
Mar 16 11:27:08 framework systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Mar 16 11:27:09 framework systemd[1]: systemd-localed.service: Deactivated successfully.
Mar 16 11:27:09 framework systemd[1]: systemd-timedated.service: Deactivated successfully.
Mar 16 11:27:11 framework systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 16 11:27:11 framework systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 16 11:27:12 framework systemd[1323]: Started Terminator.
Mar 16 11:27:12 framework systemd[1323]: Started VTE child process 2898 launched by terminator process 2891.
Mar 16 11:27:12 framework plasmashell[1589]: qt.qpa.wayland: eglSwapBuffers failed with 0x300d, surface: 0x0
Mar 16 11:27:12 framework plasmashell[1589]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/PopupDialog.qml:36:13: QML PlasmoidHeading: Binding loop detected for property "leftInset"
Mar 16 11:27:21 framework systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 16 11:27:23 framework plasmashell[1589]: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml:201:9: QML QQuickImage: Error decoding: qrc:/qt/qml/org/kde/kirigamiaddons/components/Avatar.qml?timestamp=1710548801007>
Mar 16 11:27:23 framework plasmashell[1589]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Mar 16 11:27:24 framework plasmashell[1589]: kf.kio.core: No Exec field in ""
Mar 16 11:27:24 framework plasmashell[1589]: org.kde.plasma.runner.services: Failed to resolve executable from service. Error: "No Exec field in "
Mar 16 11:27:24 framework systemd[1323]: Starting KRunner provider for baloo file indexer...
Mar 16 11:27:24 framework systemd[1323]: Started KRunner provider for baloo file indexer.
Mar 16 11:27:24 framework systemd[1323]: Started Mousepad - Text Editor.
Mar 16 11:27:24 framework mousepad[3016]: Failed to load plugin "mousepad-plugin-shortcuts": libxfce4kbd-private-3.so.0: cannot open shared object file: No such file or directory
Mar 16 11:27:28 framework pipewire[1433]: mod.client-node: 0x5e42cba14810: unknown peer 0x5e42cba12b60 fd:43
Mar 16 11:27:37 framework systemd[1323]: Started Consume pending crashes using DrKonqi.
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/usr/bin/kwalletd5" 1532 "/var/lib/systemd/coredump/core.kwalletd5.1000.75e35bf9049f4c2cbcf64788b1d14f55.1532.1709366700000000.zst"
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/usr/bin/cat" 7534 "/var/lib/systemd/coredump/core.cat.1000.7864654d5f664426b158031e0cd6f6a1.7534.1709375038000000.zst"
Mar 16 11:27:38 framework systemd[1323]: Started Launch DrKonqi for a systemd-coredump crash (PID 3028/UID 1000).
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3029]: Unable to find file for pid 1532 expected at "kcrash-metadata/kwalletd5.75e35bf9049f4c2cbcf64788b1d14f55.1532.ini"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3030]: Unable to find file for pid 7534 expected at "kcrash-metadata/cat.7864654d5f664426b158031e0cd6f6a1.7534.ini"
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/usr/bin/cat" 7641 "/var/lib/systemd/coredump/core.cat.1000.7864654d5f664426b158031e0cd6f6a1.7641.1709375041000000.zst"
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/usr/bin/kwalletd5" 1611 "/var/lib/systemd/coredump/core.kwalletd5.1000.7864654d5f664426b158031e0cd6f6a1.1611.1709447053000000.zst"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3035]: Unable to find file for pid 7641 expected at "kcrash-metadata/cat.7864654d5f664426b158031e0cd6f6a1.7641.ini"
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/usr/bin/dash" 9202 "/var/lib/systemd/coredump/core.sh.1000.72211ae464d14b54b82dc7f3fd632ba5.9202.1709453403000000.zst"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3038]: Unable to find file for pid 1611 expected at "kcrash-metadata/kwalletd5.7864654d5f664426b158031e0cd6f6a1.1611.ini"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3039]: Unable to find file for pid 9202 expected at "kcrash-metadata/dash.72211ae464d14b54b82dc7f3fd632ba5.9202.ini"
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/usr/bin/kwalletd5" 1642 "/var/lib/systemd/coredump/core.kwalletd5.1000.72211ae464d14b54b82dc7f3fd632ba5.1642.1709453904000000.zst"
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/usr/bin/cat" 3952 "/var/lib/systemd/coredump/core.cat.1000.683114cdaaf2469aaf3cd73547d85bed.3952.1709454038000000.zst"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3044]: Unable to find file for pid 1642 expected at "kcrash-metadata/kwalletd5.72211ae464d14b54b82dc7f3fd632ba5.1642.ini"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3045]: Unable to find file for pid 3952 expected at "kcrash-metadata/cat.683114cdaaf2469aaf3cd73547d85bed.3952.ini"
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/home/jake/.local/share/Steam/ubuntu12_32/steam" 2437 "/var/lib/systemd/coredump/core.steam.1000.683114cdaaf2469aaf3cd73547d85bed.2437.1709536653000000.zst"
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/usr/bin/kwalletd5" 2130 "/var/lib/systemd/coredump/core.kwalletd5.1000.683114cdaaf2469aaf3cd73547d85bed.2130.1709536661000000.zst"
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/usr/bin/kwalletd5" 1532 "/var/lib/systemd/coredump/core.kwalletd5.1000.598950ac47154d0f8ae287e32616e29d.1532.1709553074000000.zst"
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/usr/bin/kwalletd5" 1539 "/var/lib/systemd/coredump/core.kwalletd5.1000.bec77d2cf7af43c1a930a11bef3bd5df.1539.1709631656000000.zst"
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/usr/bin/kwalletd5" 1892 "/var/lib/systemd/coredump/core.kwalletd5.1000.26c6066d6a0d45eb9e7e77fb893ceabc.1892.1709645068000000.zst"
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/usr/bin/dash" 3909 "/var/lib/systemd/coredump/core.sh.1000.09ab84dc381347038e33ddd44e4a958d.3909.1709645201000000.zst"
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/usr/bin/dash" 42167 "/var/lib/systemd/coredump/core.sh.1000.09ab84dc381347038e33ddd44e4a958d.42167.1709706316000000.zst"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3050]: Unable to find file for pid 1539 expected at "kcrash-metadata/kwalletd5.bec77d2cf7af43c1a930a11bef3bd5df.1539.ini"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3055]: Unable to find file for pid 2130 expected at "kcrash-metadata/kwalletd5.683114cdaaf2469aaf3cd73547d85bed.2130.ini"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3051]: Unable to find file for pid 1892 expected at "kcrash-metadata/kwalletd5.26c6066d6a0d45eb9e7e77fb893ceabc.1892.ini"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3054]: Unable to find file for pid 2437 expected at "kcrash-metadata/steam.683114cdaaf2469aaf3cd73547d85bed.2437.ini"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3052]: Unable to find file for pid 3909 expected at "kcrash-metadata/dash.09ab84dc381347038e33ddd44e4a958d.3909.ini"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3053]: Unable to find file for pid 42167 expected at "kcrash-metadata/dash.09ab84dc381347038e33ddd44e4a958d.42167.ini"
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/usr/bin/kwalletd5" 3232 "/var/lib/systemd/coredump/core.kwalletd5.1000.23697fec180b4210a61ff64f07beb479.3232.1709938954000000.zst"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3056]: Unable to find file for pid 1532 expected at "kcrash-metadata/kwalletd5.598950ac47154d0f8ae287e32616e29d.1532.ini"
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/usr/bin/kwalletd5" 1582 "/var/lib/systemd/coredump/core.kwalletd5.1000.71d67cc5f6a34df2b894fefe6871201d.1582.1709949597000000.zst"
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/home/jake/.local/share/Steam/compatibilitytools.d/GE-Proton8-22/files/bin/wine64-preloader" 24021 "/var/lib/systemd/coredump/core.wine64.1000.71d67cc5f6a34df2b8>
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/usr/bin/cat" 25050 "/var/lib/systemd/coredump/core.cat.1000.71d67cc5f6a34df2b894fefe6871201d.25050.1709950129000000.zst"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3072]: Unable to find file for pid 1582 expected at "kcrash-metadata/kwalletd5.71d67cc5f6a34df2b894fefe6871201d.1582.ini"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3073]: Unable to find file for pid 24021 expected at "kcrash-metadata/wine64-preloader.71d67cc5f6a34df2b894fefe6871201d.24021.ini"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3071]: Unable to find file for pid 3232 expected at "kcrash-metadata/kwalletd5.23697fec180b4210a61ff64f07beb479.3232.ini"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3074]: Unable to find file for pid 25050 expected at "kcrash-metadata/cat.71d67cc5f6a34df2b894fefe6871201d.25050.ini"
Mar 16 11:27:38 framework drkonqi-coredump-processor[3028]: "/usr/bin/cat" 7083 "/var/lib/systemd/coredump/core.cat.1000.defc9208978c4425baf75286ecc35e95.7083.1710305352000000.zst"
Mar 16 11:27:38 framework drkonqi-coredump-launcher[3085]: Unable to find file for pid 7083 expected at "kcrash-metadata/cat.defc9208978c4425baf75286ecc35e95.7083.ini"
Mar 16 11:27:49 framework NetworkManager[956]: <info> [1710548869.0292] device (wlan0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Mar 16 11:27:49 framework NetworkManager[956]: <info> [1710548869.0297] manager: NetworkManager state is now DISCONNECTED
Mar 16 11:27:49 framework kernel: wlan0: deauthenticating from 48:22:54:f2:64:d1 by local choice (Reason: 3=DEAUTH_LEAVING)
Mar 16 11:27:49 framework wpa_supplicant[1025]: wlan0: CTRL-EVENT-DISCONNECTED bssid=48:22:54:f2:64:d1 reason=3 locally_generated=1
Mar 16 11:27:49 framework wpa_supplicant[1025]: BSSID 48:22:54:f2:64:d1 ignore list count incremented to 2, ignoring for 10 seconds
Mar 16 11:27:49 framework NetworkManager[956]: <info> [1710548869.1743] device (wlan0): set-hw-addr: set MAC address to EE:4B:2F:BA:88:F7 (scanning)
Successful connection to Mobile Hotspot - journalctl -b
Mar 16 23:47:05 framework wpa_supplicant[1056]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.0892] device (wlan0): Activation: starting connection 'iPhone' (41b0c9a6-671f-49aa-8c79-88dfa55c8e9c)
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.0893] audit: op="connection-activate" uuid="41b0c9a6-671f-49aa-8c79-88dfa55c8e9c" name="iPhone" pid=1596 uid=1000 result="success"
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.0894] device (wlan0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.0898] manager: NetworkManager state is now CONNECTING
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.1790] device (wlan0): set-hw-addr: reset MAC address to 14:AC:60:46:98:1D (preserve)
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2447] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2451] device (wlan0): Activation: (wifi) access point 'iPhone' has security, but secrets are required.
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2451] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2461] device (wlan0): supplicant interface state: disconnected -> interface_disabled
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2461] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> interface_disabled
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2562] device (wlan0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:06 framework kded6[1566]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Mar 16 23:47:06 framework ksystemstats[1697]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2564] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2566] device (wlan0): Activation: (wifi) connection 'iPhone' has security, and secrets exist. No new secrets needed.
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2566] Config: added 'ssid' value 'iPhone'
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2567] Config: added 'scan_ssid' value '1'
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2567] Config: added 'bgscan' value 'simple:30:-65:300'
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2567] Config: added 'key_mgmt' value 'SAE FT-SAE'
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2567] Config: added 'auth_alg' value 'OPEN'
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2567] Config: added 'psk' value '<hidden>'
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2567] Config: added 'ieee80211w' value '2'
Mar 16 23:47:06 framework plasmashell[1596]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2722] device (wlan0): supplicant interface state: interface_disabled -> disconnected
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2722] device (p2p-dev-wlan0): supplicant management interface state: interface_disabled -> disconnected
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2873] device (wlan0): supplicant interface state: disconnected -> scanning
Mar 16 23:47:06 framework NetworkManager[986]: <info> [1710593226.2874] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> scanning
Mar 16 23:47:08 framework wpa_supplicant[1056]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Mar 16 23:47:08 framework wpa_supplicant[1056]: wlan0: SME: Trying to authenticate with 12:77:2c:1e:19:c0 (SSID='Darth Layto\xe2\x80\x99s iPhone' freq=5745 MHz)
Mar 16 23:47:08 framework kernel: wlan0: authenticate with 12:77:2c:1e:19:c0 (local address=14:ac:60:46:98:1d)
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.0663] device (wlan0): supplicant interface state: scanning -> authenticating
Mar 16 23:47:09 framework kernel: wlan0: send auth to 12:77:2c:1e:19:c0 (try 1/3)
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.0664] device (p2p-dev-wlan0): supplicant management interface state: scanning -> authenticating
Mar 16 23:47:09 framework wpa_supplicant[1056]: wlan0: SME: Trying to authenticate with 12:77:2c:1e:19:c0 (SSID='Darth Layto\xe2\x80\x99s iPhone' freq=5745 MHz)
Mar 16 23:47:09 framework kernel: wlan0: authenticate with 12:77:2c:1e:19:c0 (local address=14:ac:60:46:98:1d)
Mar 16 23:47:09 framework wpa_supplicant[1056]: wlan0: PMKSA-CACHE-ADDED 12:77:2c:1e:19:c0 0
Mar 16 23:47:09 framework wpa_supplicant[1056]: wlan0: Trying to associate with 12:77:2c:1e:19:c0 (SSID='Darth Layto\xe2\x80\x99s iPhone' freq=5745 MHz)
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.1495] device (wlan0): supplicant interface state: authenticating -> associating
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.1496] device (p2p-dev-wlan0): supplicant management interface state: authenticating -> associating
Mar 16 23:47:09 framework kernel: wlan0: authenticated
Mar 16 23:47:09 framework kernel: wlan0: associate with 12:77:2c:1e:19:c0 (try 1/3)
Mar 16 23:47:09 framework kernel: wlan0: RX AssocResp from 12:77:2c:1e:19:c0 (capab=0x11 status=0 aid=1)
Mar 16 23:47:09 framework kernel: wlan0: associated
Mar 16 23:47:09 framework kernel: wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 12:77:2c:1e:19:c0
Mar 16 23:47:09 framework wpa_supplicant[1056]: wlan0: Associated with 12:77:2c:1e:19:c0
Mar 16 23:47:09 framework wpa_supplicant[1056]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mar 16 23:47:09 framework wpa_supplicant[1056]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=AU
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.3820] device (wlan0): supplicant interface state: associating -> 4way_handshake
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.3821] device (p2p-dev-wlan0): supplicant management interface state: associating -> 4way_handshake
Mar 16 23:47:09 framework wpa_supplicant[1056]: wlan0: WPA: Key negotiation completed with 12:77:2c:1e:19:c0 [PTK=CCMP GTK=CCMP]
Mar 16 23:47:09 framework wpa_supplicant[1056]: wlan0: CTRL-EVENT-CONNECTED - Connection to 12:77:2c:1e:19:c0 completed [id=0 id_str=]
Mar 16 23:47:09 framework wpa_supplicant[1056]: bgscan simple: Failed to enable signal strength monitoring
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.4892] device (wlan0): supplicant interface state: 4way_handshake -> completed
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.4892] device (wlan0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "iPhone"
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.4893] device (p2p-dev-wlan0): supplicant management interface state: 4way_handshake -> completed
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.4894] device (wlan0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.4901] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.6094] dhcp4 (wlan0): state changed new lease, address=172.20.10.4, acd pending
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.8075] dhcp4 (wlan0): state changed new lease, address=172.20.10.4
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.8082] policy: set 'iPhone' (wlan0) as default for IPv4 routing and DNS
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.8193] device (wlan0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.8222] device (wlan0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.8225] device (wlan0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.8229] manager: NetworkManager state is now CONNECTED_SITE
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.8235] device (wlan0): Activation: successful, device activated.
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.8342] audit: op="statistics" interface="wlan0" ifindex=2 args="2000" pid=1596 uid=1000 result="success"
Mar 16 23:47:09 framework NetworkManager[986]: <info> [1710593229.8393] audit: op="statistics" interface="wlan0" ifindex=2 args="500" pid=1697 uid=1000 result="success"
Mar 16 23:47:09 framework kwin_wayland[1392]: kwin_core: Could not find window with uuid "{7caa7d11-d774-4602-b919-60e457ea5a4b}"
Mar 16 23:47:11 framework NetworkManager[986]: <info> [1710593231.1157] manager: NetworkManager state is now CONNECTED_GLOBAL
Mar 16 23:47:11 framework systemd[1]: fprintd.service: Deactivated successfully.
Mar 16 23:47:12 framework systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 16 23:47:15 framework NetworkManager[986]: <info> [1710593235.3103] dhcp6 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Mar 16 23:47:15 framework NetworkManager[986]: <info> [1710593235.3110] policy: set 'iPhone' (wlan0) as default for IPv6 routing and DNS
Mar 16 23:47:15 framework NetworkManager[986]: <info> [1710593235.3849] dhcp6 (wlan0): state changed new lease
Mar 16 23:47:15 framework systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 16 23:47:15 framework systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 16 23:47:25 framework systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Mar 16 23:47:50 framework NetworkManager[986]: <info> [1710593270.6934] device (wlan0): state change: activated -> deactivating (reason 'user-requested', sys-iface-state: 'managed')
Mar 16 23:47:50 framework NetworkManager[986]: <info> [1710593270.6936] manager: NetworkManager state is now DISCONNECTING
Mar 16 23:47:50 framework kded6[1566]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
Mar 16 23:47:50 framework NetworkManager[986]: <info> [1710593270.6952] audit: op="device-disconnect" interface="wlan0" ifindex=2 pid=1596 uid=1000 result="success"
Mar 16 23:47:50 framework systemd[1]: Starting Network Manager Script Dispatcher Service...
Mar 16 23:47:50 framework NetworkManager[986]: <info> [1710593270.7357] audit: op="statistics" interface="wlan0" ifindex=2 args="0" pid=1596 uid=1000 result="success"
Mar 16 23:47:50 framework systemd[1]: Started Network Manager Script Dispatcher Service.
Mar 16 23:47:50 framework NetworkManager[986]: <info> [1710593270.7446] audit: op="statistics" interface="wlan0" ifindex=2 args="500" pid=1697 uid=1000 result="success"
Mar 16 23:47:50 framework kernel: wlan0: deauthenticating from 12:77:2c:1e:19:c0 by local choice (Reason: 3=DEAUTH_LEAVING)
Mar 16 23:47:51 framework wpa_supplicant[1056]: wlan0: CTRL-EVENT-DISCONNECTED bssid=12:77:2c:1e:19:c0 reason=3 locally_generated=1
Mar 16 23:47:51 framework wpa_supplicant[1056]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 16 23:47:51 framework wpa_supplicant[1056]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Mar 16 23:47:51 framework NetworkManager[986]: <info> [1710593271.0912] device (wlan0): supplicant interface state: completed -> disconnected
Mar 16 23:47:51 framework NetworkManager[986]: <info> [1710593271.0912] device (p2p-dev-wlan0): supplicant management interface state: completed -> disconnected
Mar 16 23:47:51 framework NetworkManager[986]: <info> [1710593271.0915] device (wlan0): state change: deactivating -> disconnected (reason 'user-requested', sys-iface-state: 'managed')
Mar 16 23:47:51 framework NetworkManager[986]: <info> [1710593271.0919] dhcp4 (wlan0): canceled DHCP transaction
Mar 16 23:47:51 framework NetworkManager[986]: <info> [1710593271.0919] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Mar 16 23:47:51 framework NetworkManager[986]: <info> [1710593271.0920] dhcp4 (wlan0): state changed no lease
Mar 16 23:47:51 framework NetworkManager[986]: <info> [1710593271.0922] dhcp6 (wlan0): canceled DHCP transaction
Mar 16 23:47:51 framework NetworkManager[986]: <info> [1710593271.0922] dhcp6 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Mar 16 23:47:51 framework NetworkManager[986]: <info> [1710593271.0922] dhcp6 (wlan0): state changed no lease
Mar 16 23:47:51 framework wpa_supplicant[1056]: wlan0: PMKSA-CACHE-REMOVED 12:77:2c:1e:19:c0 0
Mar 16 23:47:51 framework NetworkManager[986]: <info> [1710593271.1808] device (wlan0): set-hw-addr: set MAC address to 56:EE:89:89:DE:6A (scanning)
Mar 16 23:47:51 framework NetworkManager[986]: <info> [1710593271.3290] manager: NetworkManager state is now DISCONNECTED
Mar 16 23:47:51 framework NetworkManager[986]: <info> [1710593271.3304] device (wlan0): supplicant interface state: disconnected -> interface_disabled
Mar 16 23:47:51 framework NetworkManager[986]: <info> [1710593271.3305] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> interface_disabled
Mar 16 23:47:51 framework NetworkManager[986]: <info> [1710593271.3306] device (wlan0): supplicant interface state: interface_disabled -> disconnected
Mar 16 23:47:51 framework NetworkManager[986]: <info> [1710593271.3306] device (p2p-dev-wlan0): supplicant management interface state: interface_disabled -> disconnected
Mar 16 23:47:53 framework wpa_supplicant[1056]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Mar 16 23:47:55 framework wpa_supplicant[1056]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.7466] device (wlan0): Activation: starting connection 'iPhone' (41b0c9a6-671f-49aa-8c79-88dfa55c8e9c)
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.7468] audit: op="connection-activate" uuid="41b0c9a6-671f-49aa-8c79-88dfa55c8e9c" name="iPhone" pid=1596 uid=1000 result="success"
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.7469] device (wlan0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.7474] manager: NetworkManager state is now CONNECTING
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8041] device (wlan0): set-hw-addr: reset MAC address to 14:AC:60:46:98:1D (preserve)
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8696] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8699] device (wlan0): Activation: (wifi) access point 'iPhone' has security, but secrets are required.
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8700] device (wlan0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8709] device (wlan0): supplicant interface state: disconnected -> interface_disabled
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8709] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> interface_disabled
Mar 16 23:47:56 framework kded6[1566]: org.kde.plasma.nm.kded: Unhandled active connection state change: 1
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8751] device (wlan0): supplicant interface state: interface_disabled -> disconnected
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8751] device (p2p-dev-wlan0): supplicant management interface state: interface_disabled -> disconnected
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8823] device (wlan0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8824] device (wlan0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:56 framework kded6[1566]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8826] device (wlan0): Activation: (wifi) connection 'iPhone' has security, and secrets exist. No new secrets needed.
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8827] Config: added 'ssid' value 'iPhone'
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8827] Config: added 'scan_ssid' value '1'
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8827] Config: added 'bgscan' value 'simple:30:-65:300'
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8827] Config: added 'key_mgmt' value 'SAE FT-SAE'
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8827] Config: added 'auth_alg' value 'OPEN'
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8827] Config: added 'psk' value '<hidden>'
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.8827] Config: added 'ieee80211w' value '2'
Mar 16 23:47:56 framework ksystemstats[1697]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Mar 16 23:47:56 framework wpa_supplicant[1056]: wlan0: SME: Trying to authenticate with 12:77:2c:1e:19:c0 (SSID='Darth Layto\xe2\x80\x99s iPhone' freq=5745 MHz)
Mar 16 23:47:56 framework plasmashell[1596]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Mar 16 23:47:56 framework kernel: wlan0: authenticate with 12:77:2c:1e:19:c0 (local address=14:ac:60:46:98:1d)
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.9501] device (wlan0): supplicant interface state: disconnected -> authenticating
Mar 16 23:47:56 framework kernel: wlan0: send auth to 12:77:2c:1e:19:c0 (try 1/3)
Mar 16 23:47:56 framework NetworkManager[986]: <info> [1710593276.9502] device (p2p-dev-wlan0): supplicant management interface state: disconnected -> authenticating
Mar 16 23:47:57 framework wpa_supplicant[1056]: wlan0: SME: Trying to authenticate with 12:77:2c:1e:19:c0 (SSID='Darth Layto\xe2\x80\x99s iPhone' freq=5745 MHz)
Mar 16 23:47:57 framework kernel: wlan0: authenticate with 12:77:2c:1e:19:c0 (local address=14:ac:60:46:98:1d)
Mar 16 23:47:57 framework kernel: wlan0: send auth to 12:77:2c:1e:19:c0 (try 1/3)
Mar 16 23:47:57 framework wpa_supplicant[1056]: wlan0: PMKSA-CACHE-ADDED 12:77:2c:1e:19:c0 0
Mar 16 23:47:57 framework wpa_supplicant[1056]: wlan0: Trying to associate with 12:77:2c:1e:19:c0 (SSID='Darth Layto\xe2\x80\x99s iPhone' freq=5745 MHz)
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.0327] device (wlan0): supplicant interface state: authenticating -> associating
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.0327] device (p2p-dev-wlan0): supplicant management interface state: authenticating -> associating
Mar 16 23:47:57 framework kernel: wlan0: authenticated
Mar 16 23:47:57 framework kernel: wlan0: associate with 12:77:2c:1e:19:c0 (try 1/3)
Mar 16 23:47:57 framework kernel: wlan0: RX AssocResp from 12:77:2c:1e:19:c0 (capab=0x11 status=0 aid=1)
Mar 16 23:47:57 framework kernel: wlan0: associated
Mar 16 23:47:57 framework kernel: wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 12:77:2c:1e:19:c0
Mar 16 23:47:57 framework wpa_supplicant[1056]: wlan0: Associated with 12:77:2c:1e:19:c0
Mar 16 23:47:57 framework wpa_supplicant[1056]: wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mar 16 23:47:57 framework wpa_supplicant[1056]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=AU
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.1181] device (wlan0): supplicant interface state: associating -> 4way_handshake
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.1182] device (p2p-dev-wlan0): supplicant management interface state: associating -> 4way_handshake
Mar 16 23:47:57 framework wpa_supplicant[1056]: wlan0: WPA: Key negotiation completed with 12:77:2c:1e:19:c0 [PTK=CCMP GTK=CCMP]
Mar 16 23:47:57 framework wpa_supplicant[1056]: wlan0: CTRL-EVENT-CONNECTED - Connection to 12:77:2c:1e:19:c0 completed [id=0 id_str=]
Mar 16 23:47:57 framework wpa_supplicant[1056]: bgscan simple: Failed to enable signal strength monitoring
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.2359] device (wlan0): supplicant interface state: 4way_handshake -> completed
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.2360] device (wlan0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "iPhone"
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.2360] device (p2p-dev-wlan0): supplicant management interface state: 4way_handshake -> completed
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.2361] device (wlan0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.2366] dhcp4 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.2514] dhcp4 (wlan0): state changed new lease, address=172.20.10.4, acd pending
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.4275] dhcp4 (wlan0): state changed new lease, address=172.20.10.4
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.4280] policy: set 'iPhone' (wlan0) as default for IPv4 routing and DNS
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.4501] device (wlan0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.4537] device (wlan0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.4538] device (wlan0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.4541] manager: NetworkManager state is now CONNECTED_SITE
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.4544] device (wlan0): Activation: successful, device activated.
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.4757] audit: op="statistics" interface="wlan0" ifindex=2 args="2000" pid=1596 uid=1000 result="success"
Mar 16 23:47:57 framework NetworkManager[986]: <info> [1710593277.4829] audit: op="statistics" interface="wlan0" ifindex=2 args="500" pid=1697 uid=1000 result="success"
Mar 16 23:47:58 framework NetworkManager[986]: <info> [1710593278.2617] manager: NetworkManager state is now CONNECTED_GLOBAL
Mar 16 23:47:58 framework kdeconnectd[1828]: 2024-03-16T23:47:58 kdeconnect.core: Failed to send mDNS query: Cannot assign requested address
Mar 16 23:47:59 framework NetworkManager[986]: <info> [1710593279.3395] dhcp6 (wlan0): activation: beginning transaction (timeout in 45 seconds)
Mar 16 23:47:59 framework NetworkManager[986]: <info> [1710593279.3402] policy: set 'iPhone' (wlan0) as default for IPv6 routing and DNS
Mar 16 23:47:59 framework NetworkManager[986]: <info> [1710593279.3554] dhcp6 (wlan0): state changed new lease
Mar 16 23:48:00 framework systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Ubuntu live iso failed connection - journalctl
Mar 16 13:20:28 ubuntu NetworkManager[1784]: <info> [1710595228.3016] device (wlp1s0): Activation: starting connection 'NoStringsAttached' (288eb512-d9df-432b-929a-ff1b8dde17e8)
Mar 16 13:20:28 ubuntu NetworkManager[1784]: <info> [1710595228.3022] audit: op="connection-add-activate" uuid="288eb512-d9df-432b-929a-ff1b8dde17e8" name="NoStringsAttached" pid=6530 uid=999 result="succes>
Mar 16 13:20:28 ubuntu NetworkManager[1784]: <info> [1710595228.3033] device (wlp1s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 13:20:28 ubuntu NetworkManager[1784]: <info> [1710595228.3043] manager: NetworkManager state is now CONNECTING
Mar 16 13:20:28 ubuntu NetworkManager[1784]: <info> [1710595228.3062] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 13:20:28 ubuntu NetworkManager[1784]: <info> [1710595228.3071] device (wlp1s0): Activation: (wifi) access point 'NoStringsAttached' has security, but secrets are required.
Mar 16 13:20:28 ubuntu NetworkManager[1784]: <info> [1710595228.3072] device (wlp1s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 16 13:20:28 ubuntu NetworkManager[1784]: <info> [1710595228.3115] device (wlp1s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 13:20:28 ubuntu NetworkManager[1784]: <info> [1710595228.3125] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 13:20:28 ubuntu NetworkManager[1784]: <info> [1710595228.3134] device (wlp1s0): Activation: (wifi) connection 'NoStringsAttached' has security, and secrets exist. No new secrets needed.
Mar 16 13:20:28 ubuntu NetworkManager[1784]: <info> [1710595228.3137] Config: added 'ssid' value 'NoStringsAttached'
Mar 16 13:20:28 ubuntu NetworkManager[1784]: <info> [1710595228.3137] Config: added 'scan_ssid' value '1'
Mar 16 13:20:28 ubuntu NetworkManager[1784]: <info> [1710595228.3138] Config: added 'bgscan' value 'simple:30:-70:86400'
Mar 16 13:20:28 ubuntu NetworkManager[1784]: <info> [1710595228.3138] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Mar 16 13:20:28 ubuntu NetworkManager[1784]: <info> [1710595228.3139] Config: added 'psk' value '<hidden>'
Mar 16 13:20:28 ubuntu NetworkManager[1784]: <info> [1710595228.3649] device (wlp1s0): supplicant interface state: disconnected -> scanning
Mar 16 13:20:28 ubuntu systemd[2066]: Started Application launched by gnome-session-binary.
Mar 16 13:20:30 ubuntu wpa_supplicant[1824]: wlp1s0: SME: Trying to authenticate with 48:22:54:f2:64:d1 (SSID='NoStringsAttached' freq=5240 MHz)
Mar 16 13:20:30 ubuntu kernel: wlp1s0: authenticate with 48:22:54:f2:64:d1
Mar 16 13:20:31 ubuntu NetworkManager[1784]: <info> [1710595231.1876] device (wlp1s0): supplicant interface state: scanning -> authenticating
Mar 16 13:20:31 ubuntu kernel: wlp1s0: send auth to 48:22:54:f2:64:d1 (try 1/3)
Mar 16 13:20:31 ubuntu wpa_supplicant[1824]: wlp1s0: Trying to associate with 48:22:54:f2:64:d1 (SSID='NoStringsAttached' freq=5240 MHz)
Mar 16 13:20:31 ubuntu kernel: wlp1s0: authenticated
Mar 16 13:20:31 ubuntu kernel: wlp1s0: associate with 48:22:54:f2:64:d1 (try 1/3)
Mar 16 13:20:31 ubuntu NetworkManager[1784]: <info> [1710595231.1978] device (wlp1s0): supplicant interface state: authenticating -> associating
Mar 16 13:20:31 ubuntu kernel: wlp1s0: RX AssocResp from 48:22:54:f2:64:d1 (capab=0x1811 status=0 aid=2)
Mar 16 13:20:31 ubuntu wpa_supplicant[1824]: wlp1s0: Associated with 48:22:54:f2:64:d1
Mar 16 13:20:31 ubuntu wpa_supplicant[1824]: wlp1s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Mar 16 13:20:31 ubuntu wpa_supplicant[1824]: wlp1s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=DE
Mar 16 13:20:31 ubuntu kernel: wlp1s0: associated
Mar 16 13:20:31 ubuntu NetworkManager[1784]: <info> [1710595231.2452] device (wlp1s0): supplicant interface state: associating -> associated
Mar 16 13:20:32 ubuntu wpa_supplicant[1824]: wlp1s0: WPA: Key negotiation completed with 48:22:54:f2:64:d1 [PTK=CCMP GTK=CCMP]
Mar 16 13:20:32 ubuntu wpa_supplicant[1824]: wlp1s0: CTRL-EVENT-CONNECTED - Connection to 48:22:54:f2:64:d1 completed [id=0 id_str=]
Mar 16 13:20:32 ubuntu wpa_supplicant[1824]: bgscan simple: Failed to enable signal strength monitoring
Mar 16 13:20:32 ubuntu kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
Mar 16 13:20:32 ubuntu NetworkManager[1784]: <info> [1710595232.5332] device (wlp1s0): supplicant interface state: associated -> completed
Mar 16 13:20:32 ubuntu NetworkManager[1784]: <info> [1710595232.5334] device (wlp1s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "NoStringsAttached"
Mar 16 13:20:32 ubuntu NetworkManager[1784]: <info> [1710595232.5340] device (wlp1s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Mar 16 13:20:32 ubuntu NetworkManager[1784]: <info> [1710595232.5355] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
Mar 16 13:20:32 ubuntu avahi-daemon[1780]: Joining mDNS multicast group on interface wlp1s0.IPv6 with address fe80::64a1:e47e:2139:412d.
Mar 16 13:20:32 ubuntu avahi-daemon[1780]: New relevant interface wlp1s0.IPv6 for mDNS.
Mar 16 13:20:32 ubuntu avahi-daemon[1780]: Registering new address record for fe80::64a1:e47e:2139:412d on wlp1s0.*.
Mar 16 13:20:34 ubuntu NetworkManager[1784]: <info> [1710595234.0531] dhcp6 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
Mar 16 13:20:45 ubuntu systemd[1]: systemd-timedated.service: Deactivated successfully.
Mar 16 13:20:45 ubuntu dbus-daemon[1782]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.66' (uid=0 pid=1797 comm="/u>
Mar 16 13:20:45 ubuntu systemd[1]: Starting Time & Date Service...
Mar 16 13:20:45 ubuntu dbus-daemon[1782]: [system] Successfully activated service 'org.freedesktop.timedate1'
Mar 16 13:20:45 ubuntu systemd[1]: Started Time & Date Service.
Mar 16 13:21:15 ubuntu systemd[1]: systemd-timedated.service: Deactivated successfully.
Mar 16 13:21:16 ubuntu dbus-daemon[1782]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.66' (uid=0 pid=1797 comm="/u>
Mar 16 13:21:16 ubuntu systemd[1]: Starting Time & Date Service...
Mar 16 13:21:16 ubuntu dbus-daemon[1782]: [system] Successfully activated service 'org.freedesktop.timedate1'
Mar 16 13:21:16 ubuntu systemd[1]: Started Time & Date Service.
Mar 16 13:21:18 ubuntu casper-md5check[6308]: Checking ./casper/filesystem.squashfs..................................................................../casper/filesystem.squashfs: OK
Mar 16 13:21:18 ubuntu casper-md5check[6308]: Checking ./casper/filesystem.manifest..../casper/filesystem.manifest: OK
Mar 16 13:21:18 ubuntu casper-md5check[6308]: Checking ./.disk/cd_type..../.disk/cd_type: OK
Mar 16 13:21:18 ubuntu casper-md5check[6308]: Checking ./.disk/base_installable..../.disk/base_installable: OK
Mar 16 13:21:18 ubuntu casper-md5check[6308]: Checking ./.disk/info..../.disk/info: OK
Mar 16 13:21:18 ubuntu casper-md5check[6308]: Checking ./.disk/casper-uuid-generic..../.disk/casper-uuid-generic: OK
Mar 16 13:21:18 ubuntu casper-md5check[6308]: Checking ./.disk/release_notes_url...../.disk/release_notes_url: OK
Mar 16 13:21:18 ubuntu casper-md5check[6308]: Check finished: no errors found.
Mar 16 13:21:18 ubuntu systemd[1]: Finished casper-md5check Verify Live ISO checksums.
Mar 16 13:21:18 ubuntu systemd[1]: Startup finished in 17.698s (firmware) + 18.398s (loader) + 8.741s (kernel) + 4min 15.229s (userspace) = 5min 67ms.
Mar 16 13:21:18 ubuntu NetworkManager[1784]: <info> [1710595278.9534] device (wlp1s0): state change: ip-config -> failed (reason 'ip-config-unavailable', sys-iface-state: 'managed')
Mar 16 13:21:18 ubuntu NetworkManager[1784]: <info> [1710595278.9543] manager: NetworkManager state is now DISCONNECTED
Mar 16 13:21:18 ubuntu NetworkManager[1784]: <warn> [1710595278.9548] device (wlp1s0): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
Mar 16 13:21:18 ubuntu NetworkManager[1784]: <warn> [1710595278.9552] device (wlp1s0): Activation: failed for connection 'NoStringsAttached'
Mar 16 13:21:18 ubuntu NetworkManager[1784]: <info> [1710595278.9557] device (wlp1s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Mar 16 13:21:18 ubuntu avahi-daemon[1780]: Withdrawing address record for fe80::64a1:e47e:2139:412d on wlp1s0.
Mar 16 13:21:18 ubuntu avahi-daemon[1780]: Leaving mDNS multicast group on interface wlp1s0.IPv6 with address fe80::64a1:e47e:2139:412d.
Mar 16 13:21:18 ubuntu avahi-daemon[1780]: Interface wlp1s0.IPv6 no longer relevant for mDNS.
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.0001] dhcp4 (wlp1s0): canceled DHCP transaction
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.0005] dhcp6 (wlp1s0): canceled DHCP transaction
Mar 16 13:21:19 ubuntu kernel: wlp1s0: deauthenticating from 48:22:54:f2:64:d1 by local choice (Reason: 3=DEAUTH_LEAVING)
Mar 16 13:21:19 ubuntu wpa_supplicant[1824]: wlp1s0: CTRL-EVENT-DISCONNECTED bssid=48:22:54:f2:64:d1 reason=3 locally_generated=1
Mar 16 13:21:19 ubuntu wpa_supplicant[1824]: wlp1s0: CTRL-EVENT-DSCP-POLICY clear_all
Mar 16 13:21:19 ubuntu wpa_supplicant[1824]: wlp1s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.2395] device (wlp1s0): supplicant interface state: completed -> disconnected
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.5048] policy: auto-activating connection 'NoStringsAttached' (288eb512-d9df-432b-929a-ff1b8dde17e8)
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.5063] device (wlp1s0): Activation: starting connection 'NoStringsAttached' (288eb512-d9df-432b-929a-ff1b8dde17e8)
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.5065] device (wlp1s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.5071] manager: NetworkManager state is now CONNECTING
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.5077] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.5085] device (wlp1s0): Activation: (wifi) access point 'NoStringsAttached' has security, but secrets are required.
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.5085] device (wlp1s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.5114] device (wlp1s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.5121] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.5127] device (wlp1s0): Activation: (wifi) connection 'NoStringsAttached' has security, and secrets exist. No new secrets needed.
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.5128] Config: added 'ssid' value 'NoStringsAttached'
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.5128] Config: added 'scan_ssid' value '1'
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.5129] Config: added 'bgscan' value 'simple:30:-70:86400'
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.5129] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
Mar 16 13:21:19 ubuntu NetworkManager[1784]: <info> [1710595279.5130] Config: added 'psk' value '<hidden>'
Mar 16 13:21:19 ubuntu wpa_supplicant[1824]: wlp1s0: Reject scan trigger since one is already pending
Mar 16 13:21:19 ubuntu wpa_supplicant[1824]: wlp1s0: Failed to initiate AP scan
Mar 16 13:21:20 ubuntu wpa_supplicant[1824]: wlp1s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Mar 16 13:21:20 ubuntu wpa_supplicant[1824]: wlp1s0: Reject scan trigger since one is already pending
Mar 16 13:21:20 ubuntu wpa_supplicant[1824]: wlp1s0: Failed to initiate AP scan
Mar 16 13:21:21 ubuntu wpa_supplicant[1824]: wlp1s0: CTRL-EVENT-REGDOM-CHANGE init=BEACON_HINT type=UNKNOWN
Mar 16 13:21:21 ubuntu wpa_supplicant[1824]: wlp1s0: Reject scan trigger since one is already pending
Mar 16 13:21:21 ubuntu wpa_supplicant[1824]: wlp1s0: Failed to initiate AP scan
Mar 16 13:21:22 ubuntu wpa_supplicant[1824]: wlp1s0: Reject scan trigger since one is already pending
Mar 16 13:21:22 ubuntu wpa_supplicant[1824]: wlp1s0: Failed to initiate AP scan
Mar 16 13:21:23 ubuntu NetworkManager[1784]: <info> [1710595283.5932] device (wlp1s0): supplicant interface state: disconnected -> scanning
I’ve been researching this a bunch lately. Looks like the issue lies with linux firmware for the MediaTek mt7921e on AMD. I’m running Manjaro, but a quick search shows this is pretty broad:
Symptoms seem to be one or more of:
Wi-fi takes up to 2 minutes to start after cold boot, but starts immediately after warm boot
Adapter not found after hibernate, but works fine after suspend
Lost packets, sometimes a lot of them
I’ve tested against kernels 6.6, 6.7, and 6.8, but am currently running 6.6-19
I’ve not solved the cold-boot issue. I have been able to work-around the hibernate issue by restarting the network service (I’m using iwd, so systemctl restart iwd ) after wake-up.
Hi @Jacob_Layton ,
Can you try these steps , and see if that fixes your problem?
thanks.
I’ll give them a whirl when I get home from work. Fingers crossed and I’ll let you know how it goes
Tiao
March 19, 2024, 5:54am
8
I’m having similar issue, lost wifi after back from hibernation. With kernel 6.8 & firmware build time is Build Time: 20240219103337. The link above mentioned firmware built around 20230627143702a fixed the issue. Not sure if that’s the same issue(maybe a regression). I’m trying to figure out how to override specific firmware in NixOS to be able to test that.
Hi again Loell,
Haven’t had any luck yet. But I’ll take this as a good starting point, see what I can do over the next 24 hours and get back to you.
Thanks!
No joy so far. When I get the time, I’m going to try a fedora install, and the steps as above if necessary.
Currently have the same problem.
When it occurs I have to rmmod and modprobe again the wifi module in order to get access back.
Very annoying, I don’t know if there is a solution.
G’day again all,
Muhe has been fixed, but wanted to wait a week or two to make sure it was stable.
What worked for me, was the steps as above from Loell, in addition to a complete purge of NetworkManager. I wouldn’t go as far to say that would be necessary for everyone, especially on officially supported distros. I’d say it was due to my specific setup that had something persistent hanging around.
@Alexandre_Acebedo If all else fails, and you’re confident doing so, maybe the above is worth a try?
I’ve been experiencing something that looks a lot like OPs description of the issue.
Network stays connected, but it starts dropping packets by the looks of it. No page loads, no network command works (ping, dig, …).
Interestingly enough, even on my end I can connect to my Android mobile hotspot as a temporary workaround.
03.05
[ 8.269476] mt7921e 0000:01:00.0: ASIC revision: 79220010
[ 8.349970] mt7921e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20240409163301a
[ 8.732270] mt7921e 0000:01:00.0: WM Firmware Version: ____000000, Build Time: 20240409163347
[ 9.854963] mt7921e 0000:01:00.0 wlp1s0: renamed from wlan0
sudo lspci -k
Subsystem: MEDIATEK Corp. Device e616
sudo zypper se -i -v NetworkManager
i+ | NetworkManager | package | 1.44.4-1.1 | x86_64 | openSUSE-Tumbleweed-Oss
