Hi Guys,
I successfully installed ArchLinux on my Framework 13 with a Ryzen 7 CPU. See below for my config.
From time to time but not systematically, at boot up, I get a black screen and my caps lock hey start blinking white. In this situation I can never get to the login screen.
The solution is to reboot the laptop and typically it does not happen twice in a row.
I looked at the kernel messages from the boot sequence and I could only see the following errors:
ucsi_acpi USBC000:00: UCSI_GET_PDOS failed (-70)
USBC000:00: ucsi_handle_connector_change: GET_CONNECTOR_STATUS failed (-5)
USBC000:00: possible UCSI driver bug 1
USBC000:00: ucsi_handle_connector_change: GET_CONNECTOR_STATUS failed (-22)
Can anybody help here? It is not blocking as quite often it does boot, but still not very pretty
Thanks for your help!
