@Matt_Hartley Is this something I should be concerned by?
Here’s the HTML I copied out of the terminal, which includes formatting that makes it easier to see the errors: dmesg framework ($3690565) · Snippets · GitLab
I was testing my HDMI, DisplayPort, and Ethernet adapters and the following showed up in dmesg:
[ 800.505312] usb 7-1: new full-speed USB device number 3 using xhci_hcd
[ 800.687401] usb 7-1: New USB device found, idVendor=32ac, idProduct=0002, bcdDevice= 0.00
[ 800.687415] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 800.687421] usb 7-1: Product: HDMI Expansion Card
[ 800.687426] usb 7-1: Manufacturer: Framework
[ 800.687430] usb 7-1: SerialNumber: 11AD1D00A49C401224360B00
[ 800.771427] hid-generic 0003:32AC:0002.0013: hiddev1,hidraw4: USB HID v1.11 Device [Framework HDMI Expansion Card] on usb-0000:c4:00.4-1/input1
[ 806.988926] ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
[ 807.106662] ucsi_acpi USBC000:00: unknown error 256
[ 807.106676] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-5)
[ 807.330094] ucsi_acpi USBC000:00: possible UCSI driver bug 1
[ 807.330111] ucsi_acpi USBC000:00: ucsi_handle_connector_change: GET_CONNECTOR_STATUS failed (-22)
[ 807.486413] ucsi_acpi USBC000:00: unknown error 256
[ 807.486422] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-5)
[ 807.647023] ucsi_acpi USBC000:00: possible UCSI driver bug 1
[ 807.647038] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-22)
[ 838.533362] usb 7-1: USB disconnect, device number 3
[ 840.738515] ucsi_acpi USBC000:00: possible UCSI driver bug 1
[ 840.738532] ucsi_acpi USBC000:00: ucsi_handle_connector_change: GET_CONNECTOR_STATUS failed (-22)
[ 840.752981] usb 7-1: new full-speed USB device number 4 using xhci_hcd
[ 840.842141] ucsi_acpi USBC000:00: unknown error 256
[ 840.842151] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-5)
[ 840.934248] usb 7-1: New USB device found, idVendor=32ac, idProduct=0002, bcdDevice= 0.00
[ 840.934256] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 840.934260] usb 7-1: Product: HDMI Expansion Card
[ 840.934264] usb 7-1: Manufacturer: Framework
[ 840.934267] usb 7-1: SerialNumber: 11AD1D00A49C401224360B00
[ 841.014299] ucsi_acpi USBC000:00: unknown error 256
[ 841.014307] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-5)
[ 841.015628] hid-generic 0003:32AC:0002.0014: hiddev1,hidraw4: USB HID v1.11 Device [Framework HDMI Expansion Card] on usb-0000:c4:00.4-1/input1
[ 841.074900] Registered IR keymap rc-cec
[ 841.074969] rc rc0: DP-3 as /devices/pci0000:00/0000:00:08.1/0000:c2:00.0/rc/rc0
[ 841.075009] input: DP-3 as /devices/pci0000:00/0000:00:08.1/0000:c2:00.0/rc/rc0/input28
[ 841.123912] audit: type=1107 audit(1711149718.141:95): pid=637 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_signal" bus="system" path="/org/freedesktop/login1" interface="org.freedesktop.DBus.Properties" member="PropertiesChanged" name=":1.19" mask="receive" pid=2702 label="snap.firefox.firefox" peer_pid=737 peer_label="unconfined"
exe="/usr/bin/dbus-daemon" sauid=102 hostname=? addr=? terminal=?'
[ 847.181401] ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
[ 847.367192] ucsi_acpi USBC000:00: unknown error 256
[ 847.367204] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-5)
[ 852.557014] ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
[ 855.402417] ucsi_acpi USBC000:00: ucsi_handle_connector_change: GET_CONNECTOR_STATUS failed (-5)
[ 855.485036] usb 7-1: USB disconnect, device number 4
[ 855.501969] ucsi_acpi USBC000:00: possible UCSI driver bug 1
[ 855.501980] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-22)
[ 863.945901] audit: type=1107 audit(1711149740.965:96): pid=637 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_signal" bus="system" path="/org/freedesktop/login1" interface="org.freedesktop.DBus.Properties" member="PropertiesChanged" name=":1.19" mask="receive" pid=2702 label="snap.firefox.firefox" peer_pid=737 peer_label="unconfined"
[ 875.918988] ucsi_acpi USBC000:00: ucsi_handle_connector_change: GET_CONNECTOR_STATUS failed (-5)
[ 876.051014] ucsi_acpi USBC000:00: possible UCSI driver bug 1
[ 876.051026] ucsi_acpi USBC000:00: ucsi_handle_connector_change: GET_CONNECTOR_STATUS failed (-22)
[ 876.907046] ucsi_acpi USBC000:00: unknown error 256
[ 876.907060] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-5)
[ 877.061500] usb 7-1: new full-speed USB device number 5 using xhci_hcd
[ 877.245291] usb 7-1: New USB device found, idVendor=32ac, idProduct=0003, bcdDevice= 0.00
[ 877.245307] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 877.245314] usb 7-1: Product: DisplayPort Expansion Card
[ 877.245318] usb 7-1: Manufacturer: Framework
[ 877.245323] usb 7-1: SerialNumber: 11AD1D00A49C400F210A0B00
[ 877.329715] hid-generic 0003:32AC:0003.0015: hiddev1,hidraw4: USB HID v1.11 Device [Framework DisplayPort Expansion Card] on usb-0000:c4:00.4-1/input1
[ 883.277463] ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
[ 883.442735] ucsi_acpi USBC000:00: unknown error 256
[ 883.442745] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-5)
[ 888.653457] ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
[ 888.811104] ucsi_acpi USBC000:00: possible UCSI driver bug 1
[ 888.811114] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-22)
[ 891.065584] usb 7-1: USB disconnect, device number 5
[ 892.439399] ucsi_acpi USBC000:00: ucsi_handle_connector_change: GET_CONNECTOR_STATUS failed (-5)
[ 892.574905] ucsi_acpi USBC000:00: unknown error 256
[ 892.574920] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-5)
[ 893.053088] usb 7-1: new full-speed USB device number 6 using xhci_hcd
[ 893.071216] audit: type=1107 audit(1711149770.089:97): pid=637 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_signal" bus="system" path="/org/freedesktop/login1" interface="org.freedesktop.DBus.Properties" member="PropertiesChanged" name=":1.19" mask="receive" pid=2702 label="snap.firefox.firefox" peer_pid=737 peer_label="unconfined"
[ 893.236600] usb 7-1: New USB device found, idVendor=32ac, idProduct=0003, bcdDevice= 0.00
[ 893.236614] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 893.236620] usb 7-1: Product: DisplayPort Expansion Card
[ 893.236624] usb 7-1: Manufacturer: Framework
[ 893.236628] usb 7-1: SerialNumber: 11AD1D00A49C400F210A0B00
[ 893.295486] hid-generic 0003:32AC:0003.0016: hiddev1,hidraw4: USB HID v1.11 Device [Framework DisplayPort Expansion Card] on usb-0000:c4:00.4-1/input1
[ 898.893525] ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
[ 899.154757] ucsi_acpi USBC000:00: possible UCSI driver bug 1
[ 899.154767] ucsi_acpi USBC000:00: ucsi_handle_connector_change: GET_CONNECTOR_STATUS failed (-22)
[ 899.310638] ucsi_acpi USBC000:00: possible UCSI driver bug 1
[ 899.310645] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-22)
[ 899.483493] ucsi_acpi USBC000:00: unknown error 256
[ 899.483508] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-5)
[ 902.917812] usb 7-1: USB disconnect, device number 6
[ 904.457106] usb 7-1: new full-speed USB device number 7 using xhci_hcd
[ 904.644678] usb 7-1: New USB device found, idVendor=32ac, idProduct=0003, bcdDevice= 0.00
[ 904.644686] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 904.644690] usb 7-1: Product: DisplayPort Expansion Card
[ 904.644693] usb 7-1: Manufacturer: Framework
[ 904.644695] usb 7-1: SerialNumber: 11AD1D00A49C400F210A0B00
[ 904.727349] hid-generic 0003:32AC:0003.0017: hiddev1,hidraw4: USB HID v1.11 Device [Framework DisplayPort Expansion Card] on usb-0000:c4:00.4-1/input1
[ 910.669712] ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
[ 910.867310] ucsi_acpi USBC000:00: unknown error 256
[ 910.867324] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-5)
[ 910.944036] audit: type=1107 audit(1711149787.965:98): pid=637 uid=102 auid=4294967295 ses=4294967295 subj=unconfined msg='apparmor="DENIED" operation="dbus_signal" bus="system" path="/org/freedesktop/login1" interface="org.freedesktop.DBus.Properties" member="PropertiesChanged" name=":1.19" mask="receive" pid=2702 label="snap.firefox.firefox" peer_pid=737 peer_label="unconfined"
[ 916.045589] ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
[ 916.246912] ucsi_acpi USBC000:00: ucsi_handle_connector_change: GET_CONNECTOR_STATUS failed (-5)
[ 921.421496] ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
[ 921.530888] ucsi_acpi USBC000:00: unknown error 256
[ 921.530903] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-5)
[ 926.797548] ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
[ 926.906918] ucsi_acpi USBC000:00: unknown error 256
[ 926.906929] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-5)
[ 932.173595] ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
[ 932.287379] ucsi_acpi USBC000:00: unknown error 256
[ 932.287391] ucsi_acpi USBC000:00: con4: failed to register partner alt modes (-5)
[ 937.549201] ucsi_acpi USBC000:00: ucsi_handle_connector_change: ACK failed (-110)
[ 957.166065] usb 1-1: USB disconnect, device number 2
[ 962.691112] ucsi_acpi USBC000:00: ucsi_handle_connector_change: GET_CONNECTOR_STATUS failed (-5)
[ 962.789772] usb 7-1: USB disconnect, device number 7
[ 962.810184] ucsi_acpi USBC000:00: possible UCSI driver bug 1
[ 962.810191] ucsi_acpi USBC000:00: ucsi_handle_connector_change: GET_CONNECTOR_STATUS failed (-22)
[ 982.174089] usb 2-2.3: new SuperSpeed USB device number 6 using xhci_hcd
[ 982.193960] usb 2-2.3: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=31.04
[ 982.193966] usb 2-2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 982.193968] usb 2-2.3: Product: USB 10/100/1G/2.5G LAN
[ 982.193969] usb 2-2.3: Manufacturer: Realtek
[ 982.193971] usb 2-2.3: SerialNumber: 4013000001
[ 982.301548] usbcore: registered new device driver r8152-cfgselector
[ 982.570312] r8152-cfgselector 2-2.3: reset SuperSpeed USB device number 6 using xhci_hcd
[ 982.629545] r8152 2-2.3:1.0: ram code speedup mode fail
[ 982.629554] r8152 2-2.3:1.0: load rtl8156b-2 v2 04/27/23 successfully
[ 982.670214] r8152 2-2.3:1.0 (unnamed net_device) (uninitialized): netif_napi_add_weight() called with weight 256
[ 982.670626] r8152 2-2.3:1.0 eth0: v1.12.13
[ 982.670662] usbcore: registered new interface driver r8152
[ 982.674216] usbcore: registered new interface driver cdc_ether
[ 982.675444] usbcore: registered new interface driver cdc_ncm
[ 982.676888] usbcore: registered new interface driver cdc_wdm
[ 982.677741] usbcore: registered new interface driver cdc_mbim
[ 982.709959] r8152 2-2.3:1.0 enx9cbf0d004c7a: renamed from eth0
