Hello,
It looks like this very sequence of events leads to difficulties to resume the laptop from suspend mode:
- after I launch an offline-upgrade before shutdown [1]
- and after the upgrade the laptop shuts down (as expected)
- and after I start it again (usually the next day)
- and after it suspends itself (due to inactivity)
- it is very difficult and sometimes impossible to resume (wake up) the laptop.
Screen remains dark, power button is blinking, but no response. Tried to unplug/plug in the power cord. Tried to press the power button many times… tried to press it a little longer… tried to close/open the lid…
Sometimes, the laptop eventually wakes up after a while. Sometimes, even after minutes, nothing happens, and I’m forced to perform a hard shutdown and start again the laptop.
Those difficulties never happen when no upgrade has been performed before shutdown.
Does anyone noticed this issue before? Do you think it might be related to Grub/Fedora or BIOS or hardware?
[1] I.e. given an upgrade is available and has been automatically downloaded, when I click on shutdown, Gnome ask me if I’d like to apply offline-upgrade before shutting down (Restarting and Offline Updates - Fedora Magazine)
Kernel: 6.6.4-200.fc39.x86_64
Processor: 13th Gen Intel® Core™ i7-1360P × 16
Ext. cards: 2×USB-C (rear) + 1 HDMI (front) + 1 USB-A (front)
TLP profile as recommended here (gnome power profile removed): Optimizing Fedora Battery Life
$ cat /etc/default/grub
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="$(sed 's, release .*$,,g' /etc/system-release)"
GRUB_DEFAULT=saved
GRUB_DISABLE_SUBMENU=true
GRUB_TERMINAL_OUTPUT="console"
GRUB_CMDLINE_LINUX="rd.luks.uuid=luks-1185776b-e7ce-40c9-8ad1-89f5b2177ccd rhgb quiet"
GRUB_DISABLE_RECOVERY="true"
GRUB_ENABLE_BLSCFG=true
Last three boots: (did offline-upgrade; did eventually wake up after ~10 seconds)
$ journalctl -b 0 -u systemd-logind
Dec. 13 09:12:13 xyz systemd[1]: Starting systemd-logind.service - User Login Management...
Dec. 13 09:12:13 xyz systemd-logind[1959]: New seat seat0.
Dec. 13 09:12:13 xyz systemd-logind[1959]: Watching system buttons on /dev/input/event0 (Lid Switch)
Dec. 13 09:12:13 xyz systemd-logind[1959]: Watching system buttons on /dev/input/event1 (Power Button)
Dec. 13 09:12:13 xyz systemd-logind[1959]: Watching system buttons on /dev/input/event4 (FRMW0001:00 32AC:0006)
Dec. 13 09:12:13 xyz systemd-logind[1959]: Watching system buttons on /dev/input/event2 (AT Translated Set 2 keyboard)
Dec. 13 09:12:13 xyz systemd[1]: Started systemd-logind.service - User Login Management.
Dec. 13 09:12:16 xyz systemd-logind[1959]: New session c1 of user gdm.
Dec. 13 09:12:30 xyz systemd-logind[1959]: New session 2 of user user1.
Dec. 13 09:12:31 xyz systemd-logind[1959]: Session c1 logged out. Waiting for processes to exit.
Dec. 13 09:12:31 xyz systemd-logind[1959]: Removed session c1.
Dec. 13 09:44:42 xyz systemd-logind[1959]: The system will suspend now!
Dec. 13 10:16:39 xyz systemd-logind[1959]: Operation 'sleep' finished.
Dec. 13 10:17:06 xyz systemd-logind[1959]: Session 2 logged out. Waiting for processes to exit.
Dec. 13 10:17:06 xyz systemd-logind[1959]: Removed session 2.
Dec. 13 10:17:06 xyz systemd-logind[1959]: New session c2 of user gdm.
Dec. 13 10:17:13 xyz systemd-logind[1959]: New session 5 of user user2.
Dec. 13 10:17:15 xyz systemd-logind[1959]: Session c2 logged out. Waiting for processes to exit.
Dec. 13 10:17:15 xyz systemd-logind[1959]: Removed session c2.
$ journalctl -b -1 -u systemd-logind
Dec. 12 23:01:56 xyz systemd[1]: Starting systemd-logind.service - User Login Management...
Dec. 12 23:01:56 xyz systemd-logind[2332]: New seat seat0.
Dec. 12 23:01:56 xyz systemd-logind[2332]: Watching system buttons on /dev/input/event0 (Lid Switch)
Dec. 12 23:01:56 xyz systemd-logind[2332]: Watching system buttons on /dev/input/event1 (Power Button)
Dec. 12 23:01:56 xyz systemd-logind[2332]: Watching system buttons on /dev/input/event4 (FRMW0001:00 32AC:0006)
Dec. 12 23:01:56 xyz systemd-logind[2332]: Watching system buttons on /dev/input/event2 (AT Translated Set 2 keyboard)
Dec. 12 23:01:56 xyz systemd[1]: Started systemd-logind.service - User Login Management.
Dec. 12 23:01:59 xyz systemd[1]: Stopping systemd-logind.service - User Login Management...
Dec. 12 23:01:59 xyz systemd[1]: systemd-logind.service: Deactivated successfully.
Dec. 12 23:01:59 xyz systemd[1]: Stopped systemd-logind.service - User Login Management.
$ journalctl -b -2 -u systemd-logind
Dec. 11 12:15:55 xyz systemd[1]: Starting systemd-logind.service - User Login Management...
Dec. 11 12:15:55 xyz systemd-logind[1751]: New seat seat0.
Dec. 11 12:15:55 xyz systemd-logind[1751]: Watching system buttons on /dev/input/event0 (Lid Switch)
Dec. 11 12:15:55 xyz systemd-logind[1751]: Watching system buttons on /dev/input/event1 (Power Button)
Dec. 11 12:15:55 xyz systemd-logind[1751]: Watching system buttons on /dev/input/event4 (FRMW0001:00 32AC:0006)
Dec. 11 12:15:55 xyz systemd-logind[1751]: Watching system buttons on /dev/input/event2 (AT Translated Set 2 keyboard)
Dec. 11 12:15:55 xyz systemd[1]: Started systemd-logind.service - User Login Management.
Dec. 11 12:15:58 xyz systemd-logind[1751]: New session c1 of user gdm.
Dec. 11 12:16:06 xyz systemd-logind[1751]: New session 2 of user user2.
Dec. 11 12:16:11 xyz systemd-logind[1751]: Session c1 logged out. Waiting for processes to exit.
Dec. 11 12:16:11 xyz systemd-logind[1751]: Removed session c1.
Dec. 11 13:05:06 xyz systemd-logind[1751]: The system will suspend now!
Dec. 11 13:05:18 xyz systemd-logind[1751]: Operation 'sleep' finished.
Dec. 11 13:05:31 xyz systemd-logind[1751]: Session 2 logged out. Waiting for processes to exit.
Dec. 11 13:05:31 xyz systemd-logind[1751]: Removed session 2.
Dec. 11 13:05:31 xyz systemd-logind[1751]: New session c2 of user gdm.
Dec. 11 13:05:36 xyz systemd-logind[1751]: New session 5 of user user1.
Dec. 11 13:05:38 xyz systemd-logind[1751]: Session c2 logged out. Waiting for processes to exit.
Dec. 11 13:05:38 xyz systemd-logind[1751]: Removed session c2.
Dec. 11 13:05:51 xyz systemd-logind[1751]: The system will suspend now!
Dec. 11 13:06:11 xyz systemd-logind[1751]: Operation 'sleep' finished.
Dec. 11 13:06:22 xyz systemd-logind[1751]: Session 5 logged out. Waiting for processes to exit.
Dec. 11 13:06:22 xyz systemd-logind[1751]: Removed session 5.
Dec. 11 13:06:22 xyz systemd-logind[1751]: New session c3 of user gdm.
Dec. 11 13:06:28 xyz systemd-logind[1751]: New session 8 of user user2.
Dec. 11 13:06:30 xyz systemd-logind[1751]: Session c3 logged out. Waiting for processes to exit.
Dec. 11 13:06:30 xyz systemd-logind[1751]: Removed session c3.
Dec. 11 13:33:56 xyz systemd-logind[1751]: The system will suspend now!
Dec. 11 14:18:24 xyz systemd-logind[1751]: Operation 'sleep' finished.
Dec. 11 17:26:04 xyz systemd-logind[1751]: The system will suspend now!
Dec. 11 17:33:21 xyz systemd-logind[1751]: Operation 'sleep' finished.
Dec. 11 20:16:35 xyz systemd-logind[1751]: The system will suspend now!
Dec. 11 20:32:36 xyz systemd-logind[1751]: Operation 'sleep' finished.
Dec. 11 21:02:37 xyz systemd-logind[1751]: Lid closed.
Dec. 11 21:02:37 xyz systemd-logind[1751]: Suspending...
Dec. 12 09:33:16 xyz systemd-logind[1751]: Lid opened.
Dec. 12 09:33:17 xyz systemd-logind[1751]: Operation 'sleep' finished.
Dec. 12 12:08:37 xyz systemd-logind[1751]: The system will suspend now!
Dec. 12 13:18:06 xyz systemd-logind[1751]: Operation 'sleep' finished.
Dec. 12 15:31:09 xyz systemd-logind[1751]: The system will suspend now!
Dec. 12 15:44:45 xyz systemd-logind[1751]: Operation 'sleep' finished.
Dec. 12 19:07:29 xyz systemd-logind[1751]: Lid closed.
Dec. 12 19:07:29 xyz systemd-logind[1751]: Suspending...
Dec. 12 20:28:44 xyz systemd-logind[1751]: Lid opened.
Dec. 12 20:28:45 xyz systemd-logind[1751]: Operation 'sleep' finished.
Dec. 12 21:51:44 xyz systemd-logind[1751]: The system will suspend now!
Dec. 12 21:53:21 xyz systemd-logind[1751]: Operation 'sleep' finished.
Dec. 12 23:00:54 xyz systemd-logind[1751]: The system will reboot now!
Dec. 12 23:00:54 xyz systemd-logind[1751]: System is rebooting.
Dec. 12 23:00:54 xyz systemd-logind[1751]: Session 8 logged out. Waiting for processes to exit.
Dec. 12 23:00:54 xyz systemd[1]: Stopping systemd-logind.service - User Login Management...
Dec. 12 23:00:54 xyz systemd-logind[1751]: Removed session 8.
Dec. 12 23:00:55 xyz systemd[1]: systemd-logind.service: Deactivated successfully.
Dec. 12 23:00:55 xyz systemd[1]: Stopped systemd-logind.service - User Login Management.
Dec. 12 23:00:55 xyz systemd[1]: systemd-logind.service: Consumed 6.408s CPU time.
