I just received my Framework 16 and love it (although I had to bend a few touchpad-side panels flat-er to make sure they didn’t protrude 0.3mm over each other [looks like a stamping issue making the corners curl up a little bit]).
Moving my ssd from Intel/NVidia (Dell Precision 5540) went fairly smooth, installed latest amdgpu drivers from AMD el9.3 repository.
However amdgpu driver (going through my Dell WD19TB Thunderbolt 3 dock) is buggy as all hell. I get tons of driver-side crashes.
Question: where do I post the crash dumps? Here? Is there a primary amdgpu bugzilla?
Examples
[ 3.736424] ------------[ cut here ]------------
[ 3.737650] WARNING: CPU: 8 PID: 512 at /tmp/amd.lrVohTD8/amd/amdgpu/../display/dc/link/link_factory.c:389 construct_phy+0xb68/0xdc0 [amdgpu]
[ 3.739663] Modules linked in: typec_displayport amdgpu(OE+) r8152 mii amddrm_ttm_helper(OE) amdttm(OE) amddrm_buddy(OE) amdxcp(OE) i2c_algo_bit drm_exec drm_suballoc_helper amd_sched(OE) amdkcl(OE) drm_display_helper crct10dif_pclmul crc32_pclmul crc32c_intel polyval_clmulni polyval_generic cec nvme ghash_clmulni_intel hid_multitouch hid_sensor_hub sha512_ssse3 video sha256_ssse3 sha1_ssse3 ccp nvme_core ucsi_acpi sp5100_tco typec_ucsi i2c_hid_acpi nvme_auth typec wmi i2c_hid v4l2loopback(OE) videodev mc scsi_dh_rdac scsi_dh_emc scsi_dh_alua ip6_tables ip_tables dm_multipath fuse i2c_dev
[ 3.743098] CPU: 8 PID: 512 Comm: (udev-worker) Tainted: G OE 6.8.9-200.fc39.x86_64 #1
[ 3.744812] Hardware name: Framework Laptop 16 (AMD Ryzen 7040 Series)/FRANMZCP07, BIOS 03.03 03/27/2024
[ 3.745915] RIP: 0010:construct_phy+0xb68/0xdc0 [amdgpu]
[ 3.749568] Code: 83 fe 01 74 45 48 8b 82 08 04 00 00 48 8b 40 10 48 8b 38 48 85 ff 74 04 48 8b 7f 08 89 f2 48 c7 c6 50 71 72 c1 e8 c8 57 ce d8 <0f> 0b 49 8b 87 d0 01 00 00 b9 0f 00 00 00 48 8b 80 f8 04 00 00 48
[ 3.751665] RSP: 0018:ffffb06640ebf228 EFLAGS: 00010246
[ 3.753456] RAX: 0000000000000000 RBX: ffff8e049a341b00 RCX: 0000000000000000
[ 3.754932] RDX: 0000000000000000 RSI: ffff8e12e1e218c0 RDI: ffff8e12e1e218c0
[ 3.756317] RBP: ffff8e0481848600 R08: 0000000000000000 R09: ffffb06643f3e820
[ 3.757778] R10: ffff8e0490494260 R11: ffff8e0490494260 R12: ffffb06640ebf294
[ 3.759337] R13: ffffffffc15c2e20 R14: 0000000000000002 R15: ffff8e04994ed000
[ 3.761056] FS: 00007fb6988d9980(0000) GS:ffff8e12e1e00000(0000) knlGS:0000000000000000
[ 3.762607] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 3.764161] CR2: 0000564f818d7268 CR3: 00000001189a6000 CR4: 0000000000f50ef0
[ 3.765792] PKRU: 55555554
[ 3.767372] Call Trace:
[ 3.768964] <TASK>
[ 3.770644] ? construct_phy+0xb68/0xdc0 [amdgpu]
[ 3.773394] ? __warn+0x81/0x130
[ 3.774692] ? construct_phy+0xb68/0xdc0 [amdgpu]
[ 3.777263] ? report_bug+0x171/0x1a0
[ 3.778659] ? handle_bug+0x3c/0x80
[ 3.780454] ? exc_invalid_op+0x17/0x70
[ 3.781777] ? asm_exc_invalid_op+0x1a/0x20
[ 3.783291] ? construct_phy+0xb68/0xdc0 [amdgpu]
[ 3.785810] ? construct_phy+0xb68/0xdc0 [amdgpu]
[ 3.787950] link_create+0x1e0/0x240 [amdgpu]
[ 3.789922] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.791660] ? dcn32_clk_mgr_construct+0x27f/0x300 [amdgpu]
[ 3.794175] create_links+0x138/0x500 [amdgpu]
[ 3.796712] dc_create+0x403/0x7b0 [amdgpu]
[ 3.798852] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.800567] amdgpu_dm_init.isra.0+0x2d5/0x2370 [amdgpu]
[ 3.803223] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.804703] ? prb_read_valid+0x1b/0x30
[ 3.806176] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.807808] ? console_unlock+0x78/0x120
[ 3.809174] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.810790] ? irq_work_queue+0x2f/0x60
[ 3.811094] usb 7-1.3.4: New USB device found, idVendor=0bda, idProduct=402e, bcdDevice= 0.01
[ 3.812198] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.813681] usb 7-1.3.4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 3.813686] usb 7-1.3.4: Product: USB Audio
[ 3.814805] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.816126] usb 7-1.3.4: Manufacturer: Generic
[ 3.817060] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.818419] usb 7-1.3.4: SerialNumber: 200901010001
[ 3.819423] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.822564] ? dev_printk_emit+0xa5/0xd0
[ 3.823762] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.825049] dm_hw_init+0x12/0x30 [amdgpu]
[ 3.827884] amdgpu_device_init+0x2188/0x2b80 [amdgpu]
[ 3.830178] amdgpu_driver_load_kms+0x19/0x190 [amdgpu]
[ 3.832547] amdgpu_pci_probe+0x1df/0x5f0 [amdgpu]
[ 3.834808] local_pci_probe+0x42/0xa0
[ 3.836290] pci_device_probe+0xc7/0x260
[ 3.837959] really_probe+0x19b/0x3e0
[ 3.839271] ? __pfx___driver_attach+0x10/0x10
[ 3.840957] __driver_probe_device+0x78/0x160
[ 3.842457] driver_probe_device+0x1f/0x90
[ 3.843901] __driver_attach+0xd2/0x1c0
[ 3.845425] bus_for_each_dev+0x85/0xd0
[ 3.846714] bus_add_driver+0x146/0x250
[ 3.848337] driver_register+0x59/0x100
[ 3.849707] ? __pfx_amdgpu_init+0x10/0x10 [amdgpu]
[ 3.852796] do_one_initcall+0x58/0x320
[ 3.854191] do_init_module+0x90/0x270
[ 3.855781] __do_sys_init_module+0x17f/0x1b0
[ 3.857240] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.858917] do_syscall_64+0x83/0x170
[ 3.860342] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.861722] ? __mod_memcg_lruvec_state+0xc5/0x170
[ 3.863318] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.864626] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.866177] ? set_ptes.isra.0+0x28/0x90
[ 3.867609] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.869012] ? do_anonymous_page+0x35c/0x6f0
[ 3.870570] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.871860] ? __handle_mm_fault+0xbb4/0xe40
[ 3.873500] ? update_process_times+0x9c/0xb0
[ 3.874811] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.876153] ? __count_memcg_events+0x69/0x100
[ 3.877727] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.879049] ? count_memcg_events.constprop.0+0x1a/0x30
[ 3.880489] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.881824] ? handle_mm_fault+0xa2/0x360
[ 3.883368] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.884815] ? do_user_addr_fault+0x304/0x690
[ 3.886058] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.887506] ? srso_alias_return_thunk+0x5/0xfbef5
[ 3.888825] entry_SYSCALL_64_after_hwframe+0x78/0x80
[ 3.889988] RIP: 0033:0x7fb6992c7b9e
[ 3.891455] Code: 48 8b 0d 95 12 0c 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 49 89 ca b8 af 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 62 12 0c 00 f7 d8 64 89 01 48
[ 3.892720] RSP: 002b:00007fff7f8b3928 EFLAGS: 00000246 ORIG_RAX: 00000000000000af
[ 3.894289] RAX: ffffffffffffffda RBX: 00005562b9b1a220 RCX: 00007fb6992c7b9e
[ 3.895773] RDX: 00007fb6993cd07d RSI: 000000000218723d RDI: 00007fb696200010
[ 3.897069] RBP: 00007fff7f8b39e0 R08: 00005562b9af8010 R09: 0000000000000007
[ 3.898502] R10: 0000000000000006 R11: 0000000000000246 R12: 00007fb6993cd07d
[ 3.899799] R13: 0000000000020000 R14: 00005562b9b1f110 R15: 00005562b9b33100
[ 3.901292] </TASK>
[ 3.902723] ---[ end trace 0000000000000000 ]---
[ 21.305004] ------------[ cut here ]------------
[ 21.305011] WARNING: CPU: 15 PID: 4684 at /tmp/amd.lrVohTD8/amd/amdgpu/../display/dc/link/link_dpms.c:1436 link_set_dpms_on+0xd5a/0xeb0 [amdgpu]
[ 21.305313] Modules linked in: vboxnetadp(OE) vboxnetflt(OE) vboxdrv(OE) xt_conntrack xt_MASQUERADE nf_conntrack_netlink xt_addrtype rpcrdma br_netfilter bridge stp llc overlay rdma_cm iw_cm ib_cm ib_core nft_masq nf_conntrack_netbios_ns nf_conntrack_broadcast nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nf_log_syslog nft_log nft_ct nft_chain_nat nf_tables ebtable_nat ebtable_broute ip6table_nat ip6table_mangle ip6table_raw ip6table_security iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 iptable_mangle iptable_raw iptable_security ip_set nfnetlink ebtable_filter ebtables ip6table_filter iptable_filter qrtr bnep btusb btrtl btintel btbcm btmtk bluetooth binfmt_misc uvcvideo uvc videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common squashfs vfat fat intel_rapl_msr intel_rapl_common edac_mce_amd kvm_amd kvm irqbypass snd_usb_audio snd_usbmidi_lib snd_ump snd_sof_amd_acp63 snd_rawmidi snd_sof_amd_vangogh snd_sof_amd_rembrandt
[ 21.305361] snd_sof_amd_renoir cros_ec_lpcs cros_ec snd_sof_amd_acp snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_hda_codec_realtek snd_sof_utils snd_hda_codec_generic snd_soc_core snd_compress mt7921e ac97_bus snd_hda_codec_hdmi snd_pcm_dmaengine mt7921_common mt792x_lib mt76_connac_lib snd_hda_intel snd_pci_ps snd_intel_dspcfg mt76 snd_intel_sdw_acpi snd_rpl_pci_acp6x snd_hda_codec snd_acp_pci mac80211 wmi_bmof snd_hda_core snd_acp_legacy_common snd_hwdep hid_sensor_als rapl snd_pci_acp6x pcspkr hid_sensor_trigger snd_seq hid_sensor_iio_common snd_seq_device snd_pcm industrialio_triggered_buffer libarc4 kfifo_buf industrialio snd_pci_acp5x snd_rn_pci_acp3x snd_acp_config k10temp thunderbolt snd_timer cfg80211 snd_soc_acpi i2c_piix4 snd soundcore snd_pci_acp3x rfkill amd_pmf amdtee amd_sfh tee platform_profile amd_pmc joydev nfsd auth_rpcgss nfs_acl lockd grace loop sunrpc zram hid_logitech_hidpp hid_logitech_dj typec_displayport amdgpu(OE) r8152 mii amddrm_ttm_helper(OE) amdttm(OE) amddrm_buddy(OE) amdxcp(OE)
[ 21.305409] i2c_algo_bit drm_exec drm_suballoc_helper amd_sched(OE) amdkcl(OE) drm_display_helper crct10dif_pclmul crc32_pclmul crc32c_intel polyval_clmulni polyval_generic cec nvme ghash_clmulni_intel hid_multitouch hid_sensor_hub sha512_ssse3 video sha256_ssse3 sha1_ssse3 ccp nvme_core ucsi_acpi sp5100_tco typec_ucsi i2c_hid_acpi nvme_auth typec wmi i2c_hid v4l2loopback(OE) videodev mc scsi_dh_rdac scsi_dh_emc scsi_dh_alua ip6_tables ip_tables dm_multipath fuse i2c_dev
[ 21.305437] CPU: 15 PID: 4684 Comm: kwin_wayland Tainted: G W OE 6.8.9-200.fc39.x86_64 #1
[ 21.305440] Hardware name: Framework Laptop 16 (AMD Ryzen 7040 Series)/FRANMZCP07, BIOS 03.03 03/27/2024
[ 21.305441] RIP: 0010:link_set_dpms_on+0xd5a/0xeb0 [amdgpu]
[ 21.305607] Code: e8 6b aa ff ff e9 bf fc ff ff 48 8b bb d8 01 00 00 48 89 de e8 37 3f d9 ff e9 ed fe ff ff c6 80 58 04 00 00 00 e9 03 f8 ff ff <0f> 0b e9 6f fd ff ff 48 8b 85 00 01 00 00 48 8d 54 24 44 4c 89 5c
[ 21.305609] RSP: 0018:ffffb0664d37b288 EFLAGS: 00010246
[ 21.305611] RAX: 0000000000000000 RBX: 0000000000000006 RCX: ffffffffc1726d78
[ 21.305613] RDX: 0000000000000008 RSI: ffff8e04827470c0 RDI: 0000000000000000
[ 21.305614] RBP: ffff8e0511500be0 R08: 0000000000000005 R09: 0000000000000000
[ 21.305615] R10: 0000000000000000 R11: ffff8e12e21a1780 R12: ffff8e0480f31b80
[ 21.305616] R13: ffff8e04e1061000 R14: ffff8e04e1061000 R15: ffff8e04a3940000
[ 21.305618] FS: 00007f81adf03a00(0000) GS:ffff8e12e2180000(0000) knlGS:0000000000000000
[ 21.305619] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 21.305621] CR2: 000055e9bb77a000 CR3: 0000000124b2c000 CR4: 0000000000f50ef0
[ 21.305622] PKRU: 55555554
[ 21.305623] Call Trace:
[ 21.305626] <TASK>
[ 21.305627] ? link_set_dpms_on+0xd5a/0xeb0 [amdgpu]
[ 21.305777] ? __warn+0x81/0x130
[ 21.305782] ? link_set_dpms_on+0xd5a/0xeb0 [amdgpu]
[ 21.305922] ? report_bug+0x171/0x1a0
[ 21.305927] ? handle_bug+0x3c/0x80
[ 21.305930] ? exc_invalid_op+0x17/0x70
[ 21.305938] ? asm_exc_invalid_op+0x1a/0x20
[ 21.305943] ? link_set_dpms_on+0xd5a/0xeb0 [amdgpu]
[ 21.306088] apply_single_controller_ctx_to_hw+0x2ff/0x430 [amdgpu]
[ 21.306256] dce110_apply_ctx_to_hw+0x1f0/0x320 [amdgpu]
[ 21.306405] dc_commit_state_no_check+0x434/0x17e0 [amdgpu]
[ 21.306565] dc_commit_streams+0x2a7/0x590 [amdgpu]
[ 21.306714] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.306721] amdgpu_dm_atomic_commit_tail+0x458/0x4720 [amdgpu]
[ 21.306897] ? update_load_avg+0x7e/0x800
[ 21.306901] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.306903] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.306905] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.306907] ? finish_task_switch.isra.0+0x94/0x2f0
[ 21.306910] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.306912] ? __schedule+0x41b/0x1720
[ 21.306916] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.306919] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.306923] ? schedule+0x32/0xd0
[ 21.306925] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.306927] ? schedule_timeout+0x151/0x160
[ 21.306930] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.306932] ? wait_for_completion_timeout+0x13e/0x170
[ 21.306934] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.306936] ? wait_for_completion_interruptible+0x139/0x1e0
[ 21.306940] commit_tail+0xac/0x160
[ 21.306944] drm_atomic_helper_commit+0x11a/0x140
[ 21.306947] drm_atomic_commit+0x97/0xd0
[ 21.306950] ? __pfx___drm_printfn_info+0x10/0x10
[ 21.306953] drm_mode_atomic_ioctl+0xb1e/0xd50
[ 21.306958] ? __pfx_drm_mode_atomic_ioctl+0x10/0x10
[ 21.306960] drm_ioctl_kernel+0xb2/0x110
[ 21.306964] drm_ioctl+0x280/0x500
[ 21.306966] ? __pfx_drm_mode_atomic_ioctl+0x10/0x10
[ 21.306971] amdgpu_drm_ioctl+0x4e/0x90 [amdgpu]
[ 21.307109] __x64_sys_ioctl+0x94/0xd0
[ 21.307113] do_syscall_64+0x83/0x170
[ 21.307116] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307118] ? amdgpu_drm_ioctl+0x71/0x90 [amdgpu]
[ 21.307243] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307246] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307248] ? syscall_exit_to_user_mode+0x83/0x230
[ 21.307251] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307252] ? do_syscall_64+0x90/0x170
[ 21.307254] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307256] ? mutex_lock+0x12/0x30
[ 21.307258] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307260] ? drm_mode_addfb2+0xda/0xf0
[ 21.307263] ? __pfx_drm_mode_addfb2_ioctl+0x10/0x10
[ 21.307265] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307267] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307269] ? __check_object_size+0x53/0x2e0
[ 21.307272] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307273] ? drm_ioctl+0x2af/0x500
[ 21.307276] ? __pfx_drm_mode_addfb2_ioctl+0x10/0x10
[ 21.307279] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307281] ? __pm_runtime_suspend+0x6f/0xd0
[ 21.307285] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307287] ? amdgpu_drm_ioctl+0x71/0x90 [amdgpu]
[ 21.307411] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307413] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307415] ? syscall_exit_to_user_mode+0x83/0x230
[ 21.307417] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307419] ? do_syscall_64+0x90/0x170
[ 21.307421] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307423] ? do_syscall_64+0x90/0x170
[ 21.307424] ? syscall_exit_to_user_mode+0x83/0x230
[ 21.307426] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307428] ? do_syscall_64+0x90/0x170
[ 21.307430] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307431] ? syscall_exit_to_user_mode+0x83/0x230
[ 21.307433] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307435] ? do_syscall_64+0x90/0x170
[ 21.307437] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307439] ? srso_alias_return_thunk+0x5/0xfbef5
[ 21.307441] entry_SYSCALL_64_after_hwframe+0x78/0x80
[ 21.307443] RIP: 0033:0x7f81b2b2f3ed
[ 21.307465] Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
[ 21.307467] RSP: 002b:00007ffc07dc6000 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[ 21.307469] RAX: ffffffffffffffda RBX: 00007ffc07dc60b0 RCX: 00007f81b2b2f3ed
[ 21.307470] RDX: 00007ffc07dc60b0 RSI: 00000000c03864bc RDI: 0000000000000013
[ 21.307471] RBP: 00007ffc07dc6050 R08: 0000000000000007 R09: 0000000000000007
[ 21.307472] R10: 000055e9ba572010 R11: 0000000000000246 R12: 000055e9babd9690
[ 21.307474] R13: 0000000000000013 R14: 000055e9bac77850 R15: 000055e9bac362c0
[ 21.307477] </TASK>
[ 21.307478] ---[ end trace 0000000000000000 ]---
[ 29.631060] ------------[ cut here ]------------
[ 29.631064] WARNING: CPU: 8 PID: 2581 at /tmp/amd.lrVohTD8/amd/amdgpu/../display/amdgpu_dm/amdgpu_dm_helpers.c:234 fill_dc_mst_payload_table_from_drm+0xad/0x1f0 [amdgpu]
[ 29.631372] Modules linked in: vboxnetadp(OE) vboxnetflt(OE) vboxdrv(OE) xt_conntrack xt_MASQUERADE nf_conntrack_netlink xt_addrtype rpcrdma br_netfilter bridge stp llc overlay rdma_cm iw_cm ib_cm ib_core nft_masq nf_conntrack_netbios_ns nf_conntrack_broadcast nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nf_log_syslog nft_log nft_ct nft_chain_nat nf_tables ebtable_nat ebtable_broute ip6table_nat ip6table_mangle ip6table_raw ip6table_security iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 iptable_mangle iptable_raw iptable_security ip_set nfnetlink ebtable_filter ebtables ip6table_filter iptable_filter qrtr bnep btusb btrtl btintel btbcm btmtk bluetooth binfmt_misc uvcvideo uvc videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common squashfs vfat fat intel_rapl_msr intel_rapl_common edac_mce_amd kvm_amd kvm irqbypass snd_usb_audio snd_usbmidi_lib snd_ump snd_sof_amd_acp63 snd_rawmidi snd_sof_amd_vangogh snd_sof_amd_rembrandt
[ 29.631432] snd_sof_amd_renoir cros_ec_lpcs cros_ec snd_sof_amd_acp snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_hda_codec_realtek snd_sof_utils snd_hda_codec_generic snd_soc_core snd_compress mt7921e ac97_bus snd_hda_codec_hdmi snd_pcm_dmaengine mt7921_common mt792x_lib mt76_connac_lib snd_hda_intel snd_pci_ps snd_intel_dspcfg mt76 snd_intel_sdw_acpi snd_rpl_pci_acp6x snd_hda_codec snd_acp_pci mac80211 wmi_bmof snd_hda_core snd_acp_legacy_common snd_hwdep hid_sensor_als rapl snd_pci_acp6x pcspkr hid_sensor_trigger snd_seq hid_sensor_iio_common snd_seq_device snd_pcm industrialio_triggered_buffer libarc4 kfifo_buf industrialio snd_pci_acp5x snd_rn_pci_acp3x snd_acp_config k10temp thunderbolt snd_timer cfg80211 snd_soc_acpi i2c_piix4 snd soundcore snd_pci_acp3x rfkill amd_pmf amdtee amd_sfh tee platform_profile amd_pmc joydev nfsd auth_rpcgss nfs_acl lockd grace loop sunrpc zram hid_logitech_hidpp hid_logitech_dj typec_displayport amdgpu(OE) r8152 mii amddrm_ttm_helper(OE) amdttm(OE) amddrm_buddy(OE) amdxcp(OE)
[ 29.631489] i2c_algo_bit drm_exec drm_suballoc_helper amd_sched(OE) amdkcl(OE) drm_display_helper crct10dif_pclmul crc32_pclmul crc32c_intel polyval_clmulni polyval_generic cec nvme ghash_clmulni_intel hid_multitouch hid_sensor_hub sha512_ssse3 video sha256_ssse3 sha1_ssse3 ccp nvme_core ucsi_acpi sp5100_tco typec_ucsi i2c_hid_acpi nvme_auth typec wmi i2c_hid v4l2loopback(OE) videodev mc scsi_dh_rdac scsi_dh_emc scsi_dh_alua ip6_tables ip_tables dm_multipath fuse i2c_dev
[ 29.631526] CPU: 8 PID: 2581 Comm: systemd-logind Tainted: G W OE 6.8.9-200.fc39.x86_64 #1
[ 29.631529] Hardware name: Framework Laptop 16 (AMD Ryzen 7040 Series)/FRANMZCP07, BIOS 03.03 03/27/2024
[ 29.631531] RIP: 0010:fill_dc_mst_payload_table_from_drm+0xad/0x1f0 [amdgpu]
[ 29.631774] Code: 29 4c 63 eb 49 83 fd 07 0f 83 f5 00 00 00 41 0f b6 7f 09 41 38 3c 24 75 dc 4b 8d 54 6d 00 31 c9 66 89 4c d4 38 41 39 de 75 2e <0f> 0b eb 2a 49 83 fe 07 0f 83 11 01 00 00 41 0f b7 5f 0c 0f b7 15
[ 29.631775] RSP: 0018:ffffb06644707188 EFLAGS: 00010246
[ 29.631778] RAX: ffffb06644707364 RBX: 0000000000000000 RCX: 0000000000000000
[ 29.631780] RDX: 0000000000000000 RSI: ffff8e049565dbf0 RDI: ffffb06644707240
[ 29.631781] RBP: ffffb066447071c0 R08: ffff8e049565d800 R09: 0000000000000000
[ 29.631782] R10: 00000000000000c0 R11: 0000000000012001 R12: ffffb066447071c0
[ 29.631783] R13: ffffb06644707290 R14: 0000000000000000 R15: ffffb06644707290
[ 29.631785] FS: 00007fb4c25309c0(0000) GS:ffff8e12e1e00000(0000) knlGS:0000000000000000
[ 29.631786] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 29.631787] CR2: 00007febf67217f0 CR3: 000000011282a000 CR4: 0000000000f50ef0
[ 29.631789] PKRU: 55555554
[ 29.631790] Call Trace:
[ 29.631792] <TASK>
[ 29.631793] ? fill_dc_mst_payload_table_from_drm+0xad/0x1f0 [amdgpu]
[ 29.632011] ? __warn+0x81/0x130
[ 29.632019] ? fill_dc_mst_payload_table_from_drm+0xad/0x1f0 [amdgpu]
[ 29.632223] ? report_bug+0x171/0x1a0
[ 29.632230] ? handle_bug+0x3c/0x80
[ 29.632235] ? exc_invalid_op+0x17/0x70
[ 29.632238] ? asm_exc_invalid_op+0x1a/0x20
[ 29.632245] ? fill_dc_mst_payload_table_from_drm+0xad/0x1f0 [amdgpu]
[ 29.632446] dm_helpers_dp_mst_write_payload_allocation_table+0xc0/0x110 [amdgpu]
[ 29.632644] link_set_dpms_off+0x533/0x990 [amdgpu]
[ 29.632911] dcn31_reset_hw_ctx_wrap+0x21c/0x440 [amdgpu]
[ 29.633147] ? reset_syncd_pipes_from_disabled_pipes+0xa8/0x180 [amdgpu]
[ 29.633397] dce110_apply_ctx_to_hw+0x55/0x320 [amdgpu]
[ 29.633633] dc_commit_state_no_check+0x434/0x17e0 [amdgpu]
[ 29.633856] dc_commit_streams+0x2a7/0x590 [amdgpu]
[ 29.634062] ? srso_alias_return_thunk+0x5/0xfbef5
[ 29.634070] amdgpu_dm_atomic_commit_tail+0x458/0x4720 [amdgpu]
[ 29.634335] ? srso_alias_return_thunk+0x5/0xfbef5
[ 29.634338] ? optc1_get_crtc_scanoutpos+0x7b/0xb0 [amdgpu]
[ 29.634570] ? srso_alias_return_thunk+0x5/0xfbef5
[ 29.634573] ? dc_stream_get_scanoutpos+0x6b/0x110 [amdgpu]
[ 29.634789] ? srso_alias_return_thunk+0x5/0xfbef5
[ 29.634793] ? srso_alias_return_thunk+0x5/0xfbef5
[ 29.634797] ? __pfx_amdgpu_crtc_get_scanout_position+0x10/0x10 [amdgpu]
[ 29.635001] ? srso_alias_return_thunk+0x5/0xfbef5
[ 29.635004] ? amdgpu_crtc_get_scanout_position+0x28/0x40 [amdgpu]
[ 29.635189] ? srso_alias_return_thunk+0x5/0xfbef5
[ 29.635192] ? drm_crtc_vblank_helper_get_vblank_timestamp_internal+0xf3/0x3b0
[ 29.635198] ? srso_alias_return_thunk+0x5/0xfbef5
[ 29.635200] ? wait_for_completion_timeout+0x13e/0x170
[ 29.635203] ? srso_alias_return_thunk+0x5/0xfbef5
[ 29.635205] ? drm_crtc_get_last_vbltimestamp+0x55/0x90
[ 29.635210] commit_tail+0xac/0x160
[ 29.635214] drm_atomic_helper_commit+0x11a/0x140
[ 29.635217] drm_atomic_commit+0x97/0xd0
[ 29.635220] ? __pfx___drm_printfn_info+0x10/0x10
[ 29.635224] drm_client_modeset_commit_atomic+0x203/0x250
[ 29.635229] drm_client_modeset_commit_locked+0x5a/0x160
[ 29.635232] __drm_fb_helper_restore_fbdev_mode_unlocked+0x5e/0xd0
[ 29.635236] drm_fb_helper_set_par+0x2f/0x40
[ 29.635238] fb_set_var+0x201/0x420
[ 29.635243] ? srso_alias_return_thunk+0x5/0xfbef5
[ 29.635245] ? place_entity+0x19/0xf0
[ 29.635248] ? srso_alias_return_thunk+0x5/0xfbef5
[ 29.635250] ? __flush_work.isra.0+0x1b3/0x2c0
[ 29.635253] ? enqueue_entity+0xce/0x530
[ 29.635256] ? srso_alias_return_thunk+0x5/0xfbef5
[ 29.635258] ? update_load_avg+0x7e/0x800
[ 29.635264] fbcon_blank+0x22b/0x350
[ 29.635270] do_unblank_screen+0xc0/0x1b0
[ 29.635273] complete_change_console+0x61/0x140
[ 29.635277] vt_ioctl+0xdb2/0x1510
[ 29.635282] tty_ioctl+0x4e2/0x8a0
[ 29.635289] __x64_sys_ioctl+0x94/0xd0
[ 29.635294] do_syscall_64+0x83/0x170
[ 29.635296] ? do_syscall_64+0x90/0x170
[ 29.635298] ? syscall_exit_to_user_mode+0x83/0x230
[ 29.635301] ? srso_alias_return_thunk+0x5/0xfbef5
[ 29.635303] ? do_syscall_64+0x90/0x170
[ 29.635304] ? srso_alias_return_thunk+0x5/0xfbef5
[ 29.635307] entry_SYSCALL_64_after_hwframe+0x78/0x80
[ 29.635309] RIP: 0033:0x7fb4c2f2f3ed
[ 29.635333] Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
[ 29.635335] RSP: 002b:00007ffd984cbbe0 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[ 29.635337] RAX: ffffffffffffffda RBX: 000000000000001e RCX: 00007fb4c2f2f3ed
[ 29.635338] RDX: 0000000000000001 RSI: 0000000000005605 RDI: 000000000000001e
[ 29.635339] RBP: 00007ffd984cbc30 R08: 00007ffd984cbbe0 R09: 0000557fcf1bd968
[ 29.635340] R10: 00007ffd984cbc10 R11: 0000000000000246 R12: 0000000000000000
[ 29.635341] R13: 0000557fcf1be340 R14: 00007ffd984cbcd8 R15: 00007ffd984cbce0
[ 29.635345] </TASK>
[ 29.635346] ---[ end trace 0000000000000000 ]---
[ 168.785009] ------------[ cut here ]------------
[ 168.785021] refcount_t: underflow; use-after-free.
[ 168.785035] WARNING: CPU: 6 PID: 6653 at lib/refcount.c:28 refcount_warn_saturate+0xbe/0x110
[ 168.785049] Modules linked in: uinput rfcomm snd_seq_dummy snd_hrtimer vboxnetadp(OE) vboxnetflt(OE) vboxdrv(OE) xt_conntrack xt_MASQUERADE nf_conntrack_netlink xt_addrtype rpcrdma br_netfilter bridge stp llc overlay rdma_cm iw_cm ib_cm ib_core nft_masq nf_conntrack_netbios_ns nf_conntrack_broadcast nft_fib_inet nft_fib_ipv4 nft_fib_ipv6 nft_fib nft_reject_inet nf_reject_ipv4 nf_reject_ipv6 nft_reject nf_log_syslog nft_log nft_ct nft_chain_nat nf_tables ebtable_nat ebtable_broute ip6table_nat ip6table_mangle ip6table_raw ip6table_security iptable_nat nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 iptable_mangle iptable_raw iptable_security ip_set nfnetlink ebtable_filter ebtables ip6table_filter iptable_filter qrtr bnep btusb btrtl btintel btbcm btmtk bluetooth binfmt_misc uvcvideo uvc videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common squashfs vfat fat intel_rapl_msr intel_rapl_common edac_mce_amd kvm_amd kvm irqbypass snd_usb_audio snd_usbmidi_lib snd_ump snd_sof_amd_acp63 snd_rawmidi
[ 168.785205] snd_sof_amd_vangogh snd_sof_amd_rembrandt snd_sof_amd_renoir cros_ec_lpcs cros_ec snd_sof_amd_acp snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_hda_codec_realtek snd_sof_utils snd_hda_codec_generic snd_soc_core snd_compress mt7921e ac97_bus snd_hda_codec_hdmi snd_pcm_dmaengine mt7921_common mt792x_lib mt76_connac_lib snd_hda_intel snd_pci_ps snd_intel_dspcfg mt76 snd_intel_sdw_acpi snd_rpl_pci_acp6x snd_hda_codec snd_acp_pci mac80211 wmi_bmof snd_hda_core snd_acp_legacy_common snd_hwdep hid_sensor_als rapl snd_pci_acp6x pcspkr hid_sensor_trigger snd_seq hid_sensor_iio_common snd_seq_device snd_pcm industrialio_triggered_buffer libarc4 kfifo_buf industrialio snd_pci_acp5x snd_rn_pci_acp3x snd_acp_config k10temp thunderbolt snd_timer cfg80211 snd_soc_acpi i2c_piix4 snd soundcore snd_pci_acp3x rfkill amd_pmf amdtee amd_sfh tee platform_profile amd_pmc joydev nfsd auth_rpcgss nfs_acl lockd grace loop sunrpc zram hid_logitech_hidpp hid_logitech_dj typec_displayport amdgpu(OE) r8152 mii amddrm_ttm_helper(OE)
[ 168.785353] amdttm(OE) amddrm_buddy(OE) amdxcp(OE) i2c_algo_bit drm_exec drm_suballoc_helper amd_sched(OE) amdkcl(OE) drm_display_helper crct10dif_pclmul crc32_pclmul crc32c_intel polyval_clmulni polyval_generic cec nvme ghash_clmulni_intel hid_multitouch hid_sensor_hub sha512_ssse3 video sha256_ssse3 sha1_ssse3 ccp nvme_core ucsi_acpi sp5100_tco typec_ucsi i2c_hid_acpi nvme_auth typec wmi i2c_hid v4l2loopback(OE) videodev mc scsi_dh_rdac scsi_dh_emc scsi_dh_alua ip6_tables ip_tables dm_multipath fuse i2c_dev
[ 168.785460] CPU: 6 PID: 6653 Comm: kwin_wayland Tainted: G W OE 6.8.9-200.fc39.x86_64 #1
[ 168.785468] Hardware name: Framework Laptop 16 (AMD Ryzen 7040 Series)/FRANMZCP07, BIOS 03.03 03/27/2024
[ 168.785472] RIP: 0010:refcount_warn_saturate+0xbe/0x110
[ 168.785480] Code: 01 01 e8 15 b7 88 ff 0f 0b e9 59 72 a6 00 80 3d 7d 74 f2 01 00 75 85 48 c7 c7 d0 ab b8 9a c6 05 6d 74 f2 01 01 e8 f2 b6 88 ff <0f> 0b e9 36 72 a6 00 80 3d 5b 74 f2 01 00 0f 85 5e ff ff ff 48 c7
[ 168.785485] RSP: 0018:ffffb0664e6bf9e0 EFLAGS: 00010286
[ 168.785491] RAX: 0000000000000000 RBX: 0000000000000001 RCX: 0000000000000027
[ 168.785496] RDX: ffff8e12e1d218c8 RSI: 0000000000000001 RDI: ffff8e12e1d218c0
[ 168.785500] RBP: 0000000000000001 R08: 0000000000000000 R09: 3b776f6c66726564
[ 168.785504] R10: 00000000756f6366 R11: 0000000063666572 R12: 0000000000000000
[ 168.785508] R13: ffff8e088d5c0068 R14: 000000000000000d R15: ffff8e088d5c0000
[ 168.785512] FS: 00007f1971295a00(0000) GS:ffff8e12e1d00000(0000) knlGS:0000000000000000
[ 168.785517] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 168.785522] CR2: 00007f078de7f5a0 CR3: 0000000127a56000 CR4: 0000000000f50ef0
[ 168.785527] PKRU: 55555554
[ 168.785530] Call Trace:
[ 168.785535] <TASK>
[ 168.785539] ? refcount_warn_saturate+0xbe/0x110
[ 168.785545] ? __warn+0x81/0x130
[ 168.785559] ? refcount_warn_saturate+0xbe/0x110
[ 168.785566] ? report_bug+0x171/0x1a0
[ 168.785576] ? srso_alias_return_thunk+0x5/0xfbef5
[ 168.785585] ? console_unlock+0x78/0x120
[ 168.785595] ? handle_bug+0x3c/0x80
[ 168.785603] ? exc_invalid_op+0x17/0x70
[ 168.785611] ? asm_exc_invalid_op+0x1a/0x20
[ 168.785623] ? refcount_warn_saturate+0xbe/0x110
[ 168.785631] dc_state_destruct+0xbe/0x400 [amdgpu]
[ 168.786223] dc_state_release+0x2e/0x60 [amdgpu]
[ 168.786478] dm_atomic_destroy_state+0x20/0x30 [amdgpu]
[ 168.786743] drm_atomic_state_default_clear+0x225/0x2e0
[ 168.786750] __drm_atomic_state_free+0x71/0xb0
[ 168.786753] drm_mode_atomic_ioctl+0x7b3/0xd50
[ 168.786760] ? __pfx_drm_mode_atomic_ioctl+0x10/0x10
[ 168.786763] drm_ioctl_kernel+0xb2/0x110
[ 168.786768] drm_ioctl+0x280/0x500
[ 168.786771] ? __pfx_drm_mode_atomic_ioctl+0x10/0x10
[ 168.786778] amdgpu_drm_ioctl+0x4e/0x90 [amdgpu]
[ 168.786962] __x64_sys_ioctl+0x94/0xd0
[ 168.786968] do_syscall_64+0x83/0x170
[ 168.786972] ? srso_alias_return_thunk+0x5/0xfbef5
[ 168.786975] ? srso_alias_return_thunk+0x5/0xfbef5
[ 168.786977] ? __check_object_size+0x53/0x2e0
[ 168.786981] ? srso_alias_return_thunk+0x5/0xfbef5
[ 168.786984] ? drm_ioctl+0x2af/0x500
[ 168.786987] ? __pfx_drm_mode_addfb2_ioctl+0x10/0x10
[ 168.786993] ? srso_alias_return_thunk+0x5/0xfbef5
[ 168.786996] ? __pm_runtime_suspend+0x6f/0xd0
[ 168.787000] ? srso_alias_return_thunk+0x5/0xfbef5
[ 168.787002] ? srso_alias_return_thunk+0x5/0xfbef5
[ 168.787005] ? syscall_exit_to_user_mode+0x83/0x230
[ 168.787008] ? srso_alias_return_thunk+0x5/0xfbef5
[ 168.787011] ? do_syscall_64+0x90/0x170
[ 168.787013] ? srso_alias_return_thunk+0x5/0xfbef5
[ 168.787016] ? srso_alias_return_thunk+0x5/0xfbef5
[ 168.787019] ? syscall_exit_to_user_mode+0x83/0x230
[ 168.787021] ? srso_alias_return_thunk+0x5/0xfbef5
[ 168.787024] ? do_syscall_64+0x90/0x170
[ 168.787027] ? srso_alias_return_thunk+0x5/0xfbef5
[ 168.787029] ? irqtime_account_irq+0x40/0xc0
[ 168.787033] ? srso_alias_return_thunk+0x5/0xfbef5
[ 168.787036] ? srso_alias_return_thunk+0x5/0xfbef5
[ 168.787039] entry_SYSCALL_64_after_hwframe+0x78/0x80
[ 168.787042] RIP: 0033:0x7f1975f2f3ed
[ 168.787068] Code: 04 25 28 00 00 00 48 89 45 c8 31 c0 48 8d 45 10 c7 45 b0 10 00 00 00 48 89 45 b8 48 8d 45 d0 48 89 45 c0 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 1a 48 8b 45 c8 64 48 2b 04 25 28 00 00 00
[ 168.787070] RSP: 002b:00007fff454e9750 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[ 168.787072] RAX: ffffffffffffffda RBX: 00007fff454e9800 RCX: 00007f1975f2f3ed
[ 168.787074] RDX: 00007fff454e9800 RSI: 00000000c03864bc RDI: 0000000000000015
[ 168.787076] RBP: 00007fff454e97a0 R08: 0000000000000002 R09: 0000000000000002
[ 168.787078] R10: 000055855f30a010 R11: 0000000000000246 R12: 000055856096e970
[ 168.787079] R13: 0000000000000015 R14: 0000558560b6f700 R15: 000055855fd6a9b0
[ 168.787084] </TASK>
[ 168.787086] ---[ end trace 0000000000000000 ]---
Hi,
All those dumps look more like a badly compiled kernel or corruption of some type.
If you compiled the kernel yourself, I suggest you do a “make clean” and them build it again.
If you did not compile it yourself, try to avoid the use of “out-of-tree” GPU drivers.
What does “badly compiled” mean?
This is Fedora 39 stock kernel with dkms-based amdgpu driver for el9.3 from AMD DNF repository. Can’t be any more vanilla than that.
Hi,
Try not to use dkms, and just use the amdgpu driver that comes with the kernel.
I did, same results.
I have filed the bugs here:
Looks like you have your bugs filed, which is good. I’d definitely consider testing against Fedora 40. I use 39 and 40 without issue myself. With bugs filed, as always, boot to a previous kernel for the time being.
Can’t move to 40 yett - MariaDB doesn’t have a 40 repo yet and there are conflicts. But I believe the kernel in 39 and 40 is identical right now and thus there shouldn’t be an amdgpu oops difference between the two.
Arcadiy_Ivanov1:
We’re up to 6 bugs now.
If you can provide a link, I will take a look. The screenshot is helpful to quantify, but outside of that…I’d need direct links.
