Previous setup with a MacBook Pro
Both screens connected via DisplayPort, one using a USB-C to DisplayPort cable made by CalDigit. Said cable worked at 60fps then, but doesn’t do that with the Framework so far.
Current setup
One screen via DP cable from the dock, one via HDMI on a Framework HDMI Expansion Card (which I understand is using DP Alt Mode). Both are downstream of the TS4.
Sway Output Config
### Output configuration
# Default wallpaper (more resolutions are available in /usr/share/backgrounds/sway/)
output * bg /home/leo/bg/SuperBIT_tarantula.png fill
# Example configuration:
# output HDMI-A-1 resolution 1920x1080 position 1920,0
# You can get the names of your outputs by running: swaymsg -t get_outputs
# Built-In Screen
output eDP-1 scale 2 pos 0 1080 adaptive_sync on
#output eDP-1 disable
# Left
output DP-3 mode 3840x2160@60Hz pos 0 0 scale 2
# Right
output DP-4 mode 3840x2160@60Hz pos 1920 0 scale 2
