I completely followed the guide here: Ubuntu 22.04 LTS Installation on the Framework Laptop 13.
But after playing a few minutes of youtube, the laptop can’t seem to connect to the wifi. At first, the system still says it’s connected, even though nothing loads. Clicking “Select Network” leads to a page that shows no wifi is detected:
, whereas “Wi-Fi Settings” shows a connection to my wifi?!
https://imgur.com/9v0wjw1
BIOS, CPU, and kernel versions:
Nothing I found seemed to help so far! Any help would be appreciated, thanks!
This guide is more up to date for ubuntu 23.04. Maybe helpful? Should be as it has steps for the 13th Gen Intel CPUs.
https://guides.frame.work/Guide/Ubuntu+23.04+Installation+on+the+Framework+Laptop+13/167?lang=en
@Scott_H Same issue after installing 23.04
First 90 lines of dmesg | grep iwl:
[ 3.992640] iwlwifi 0000:aa:00.0: enabling device (0000 → 0002)
[ 4.001422] iwlwifi 0000:aa:00.0: api flags index 2 larger than supported by driver
[ 4.001434] iwlwifi 0000:aa:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[ 4.001728] iwlwifi 0000:aa:00.0: loaded firmware version 72.a764baac.0 ty-a0-gf-a0-72.ucode op_mode iwlmvm
[ 4.250380] iwlwifi 0000:aa:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 4.427059] iwlwifi 0000:aa:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[ 4.427079] iwlwifi 0000:aa:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 4.427093] iwlwifi 0000:aa:00.0: WFPM_AUTH_KEY_0: 0x80
[ 4.427104] iwlwifi 0000:aa:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 4.427642] iwlwifi 0000:aa:00.0: loaded PNVM version 64acdc51
[ 4.443275] iwlwifi 0000:aa:00.0: Detected RF GF, rfid=0x10d000
[ 4.514382] iwlwifi 0000:aa:00.0: base HW address: 4c:03:4f:4f:52:36
[ 4.531176] iwlwifi 0000:aa:00.0 wlp170s0: renamed from wlan0
[ 5.248164] iwlwifi 0000:aa:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[ 5.248201] iwlwifi 0000:aa:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 5.248214] iwlwifi 0000:aa:00.0: WFPM_AUTH_KEY_0: 0x80
[ 5.248227] iwlwifi 0000:aa:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 176.050538] iwlwifi 0000:aa:00.0: Microcode SW error detected. Restarting 0x0.
[ 176.050914] iwlwifi 0000:aa:00.0: Start IWL Error Log Dump:
[ 176.050918] iwlwifi 0000:aa:00.0: Transport status: 0x0000004A, valid: 6
[ 176.050923] iwlwifi 0000:aa:00.0: Loaded firmware version: 72.a764baac.0 ty-a0-gf-a0-72.ucode
[ 176.050928] iwlwifi 0000:aa:00.0: 0x00000090 | ADVANCED_SYSASSERT
[ 176.050932] iwlwifi 0000:aa:00.0: 0x40808EF0 | trm_hw_status0
[ 176.050936] iwlwifi 0000:aa:00.0: 0x00000000 | trm_hw_status1
[ 176.050939] iwlwifi 0000:aa:00.0: 0x004DB5D2 | branchlink2
[ 176.050943] iwlwifi 0000:aa:00.0: 0x000088DC | interruptlink1
[ 176.050946] iwlwifi 0000:aa:00.0: 0x000088DC | interruptlink2
[ 176.050949] iwlwifi 0000:aa:00.0: 0x0000F6A6 | data1
[ 176.050951] iwlwifi 0000:aa:00.0: 0x00400000 | data2
[ 176.050954] iwlwifi 0000:aa:00.0: 0x00000000 | data3
[ 176.050957] iwlwifi 0000:aa:00.0: 0x98014656 | beacon time
[ 176.050960] iwlwifi 0000:aa:00.0: 0x00000000 | tsf low
[ 176.050963] iwlwifi 0000:aa:00.0: 0x00000000 | tsf hi
[ 176.050966] iwlwifi 0000:aa:00.0: 0x00000000 | time gp1
[ 176.050969] iwlwifi 0000:aa:00.0: 0x0A30990E | time gp2
[ 176.050972] iwlwifi 0000:aa:00.0: 0x00000001 | uCode revision type
[ 176.050975] iwlwifi 0000:aa:00.0: 0x00000048 | uCode version major
[ 176.050978] iwlwifi 0000:aa:00.0: 0xA764BAAC | uCode version minor
[ 176.050981] iwlwifi 0000:aa:00.0: 0x00000420 | hw version
[ 176.050984] iwlwifi 0000:aa:00.0: 0x00C80002 | board version
[ 176.050987] iwlwifi 0000:aa:00.0: 0x8037F400 | hcmd
[ 176.050990] iwlwifi 0000:aa:00.0: 0xE6FA8000 | isr0
[ 176.050992] iwlwifi 0000:aa:00.0: 0x01000000 | isr1
[ 176.050995] iwlwifi 0000:aa:00.0: 0x48F00002 | isr2
[ 176.050998] iwlwifi 0000:aa:00.0: 0x00C1401F | isr3
[ 176.051001] iwlwifi 0000:aa:00.0: 0x00200000 | isr4
[ 176.051003] iwlwifi 0000:aa:00.0: 0x053B001C | last cmd Id
[ 176.051006] iwlwifi 0000:aa:00.0: 0x0000F6A6 | wait_event
[ 176.051009] iwlwifi 0000:aa:00.0: 0x000000C4 | l2p_control
[ 176.051012] iwlwifi 0000:aa:00.0: 0x00001C20 | l2p_duration
[ 176.051015] iwlwifi 0000:aa:00.0: 0x00000007 | l2p_mhvalid
[ 176.051018] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_addr_match
[ 176.051020] iwlwifi 0000:aa:00.0: 0x00000009 | lmpm_pmg_sel
[ 176.051023] iwlwifi 0000:aa:00.0: 0x00000000 | timestamp
[ 176.051026] iwlwifi 0000:aa:00.0: 0x0000C8F8 | flow_handler
[ 176.051271] iwlwifi 0000:aa:00.0: Start IWL Error Log Dump:
[ 176.051274] iwlwifi 0000:aa:00.0: Transport status: 0x0000004A, valid: 7
[ 176.051278] iwlwifi 0000:aa:00.0: 0x20000070 | NMI_INTERRUPT_LMAC_FATAL
[ 176.051281] iwlwifi 0000:aa:00.0: 0x00000000 | umac branchlink1
[ 176.051284] iwlwifi 0000:aa:00.0: 0x8045F1D0 | umac branchlink2
[ 176.051287] iwlwifi 0000:aa:00.0: 0x8047EADA | umac interruptlink1
[ 176.051290] iwlwifi 0000:aa:00.0: 0x8047EADA | umac interruptlink2
[ 176.051293] iwlwifi 0000:aa:00.0: 0x00000002 | umac data1
[ 176.051296] iwlwifi 0000:aa:00.0: 0x8047EADA | umac data2
[ 176.051298] iwlwifi 0000:aa:00.0: 0x00000000 | umac data3
[ 176.051301] iwlwifi 0000:aa:00.0: 0x00000048 | umac major
[ 176.051304] iwlwifi 0000:aa:00.0: 0xA764BAAC | umac minor
[ 176.051307] iwlwifi 0000:aa:00.0: 0x0A309B08 | frame pointer
[ 176.051310] iwlwifi 0000:aa:00.0: 0xC088625C | stack pointer
[ 176.051312] iwlwifi 0000:aa:00.0: 0x0009010C | last host cmd
[ 176.051315] iwlwifi 0000:aa:00.0: 0x00000000 | isr status reg
[ 176.051529] iwlwifi 0000:aa:00.0: IML/ROM dump:
[ 176.051532] iwlwifi 0000:aa:00.0: 0x00000B03 | IML/ROM error/state
[ 176.051594] iwlwifi 0000:aa:00.0: 0x000085E1 | IML/ROM data1
[ 176.051657] iwlwifi 0000:aa:00.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
[ 176.051713] iwlwifi 0000:aa:00.0: Fseq Registers:
[ 176.051766] iwlwifi 0000:aa:00.0: 0x60000000 | FSEQ_ERROR_CODE
[ 176.051819] iwlwifi 0000:aa:00.0: 0x00440007 | FSEQ_TOP_INIT_VERSION
[ 176.051873] iwlwifi 0000:aa:00.0: 0x00080009 | FSEQ_CNVIO_INIT_VERSION
[ 176.051926] iwlwifi 0000:aa:00.0: 0x0000A652 | FSEQ_OTP_VERSION
[ 176.052018] iwlwifi 0000:aa:00.0: 0x00000002 | FSEQ_TOP_CONTENT_VERSION
[ 176.052180] iwlwifi 0000:aa:00.0: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 176.052342] iwlwifi 0000:aa:00.0: 0x00400410 | FSEQ_CNVI_ID
[ 176.052503] iwlwifi 0000:aa:00.0: 0x00400410 | FSEQ_CNVR_ID
[ 176.052664] iwlwifi 0000:aa:00.0: 0x00400410 | CNVI_AUX_MISC_CHIP
[ 176.052828] iwlwifi 0000:aa:00.0: 0x00400410 | CNVR_AUX_MISC_CHIP
[ 176.052991] iwlwifi 0000:aa:00.0: 0x00009061 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 176.053154] iwlwifi 0000:aa:00.0: 0x00000061 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 176.053527] iwlwifi 0000:aa:00.0: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[ 176.945886] iwlwifi 0000:aa:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x1f
Can you post the log lines of when the issue happens?
Hi @Andrew_Feng, welcome to the forums!
Please try the following from our troubleshooting guide: Ubuntu Wi-Fi Troubleshooting Guide
- Open a terminal and paste in one at a time:
rfkill unblock all
sudo rmmod iwlmvm && sudo modprobe iwlmvm
- And what is the output of:
cat /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
@Matt_Hartley the output of that says
[connection]
wifi.powersave = 2
, which seems desired.
@Anachron I restarted a few times without the wifi crashing after 5 minutes; but it eventually crashed after a few hours. Here is the result of dmesg | grep iwl. It seems like [ 274.210210] is when the wifi crashed.
[ 3.713840] iwlwifi 0000:aa:00.0: enabling device (0000 -> 0002)
[ 3.736321] iwlwifi 0000:aa:00.0: api flags index 2 larger than supported by driver
[ 3.736345] iwlwifi 0000:aa:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[ 3.736786] iwlwifi 0000:aa:00.0: loaded firmware version 72.a764baac.0 ty-a0-gf-a0-72.ucode op_mode iwlmvm
[ 4.013551] iwlwifi 0000:aa:00.0: Detected Intel(R) Wi-Fi 6 AX210 160MHz, REV=0x420
[ 4.189501] iwlwifi 0000:aa:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[ 4.189554] iwlwifi 0000:aa:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 4.189577] iwlwifi 0000:aa:00.0: WFPM_AUTH_KEY_0: 0x80
[ 4.189600] iwlwifi 0000:aa:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 4.192411] iwlwifi 0000:aa:00.0: loaded PNVM version 64acdc51
[ 4.210951] iwlwifi 0000:aa:00.0: Detected RF GF, rfid=0x10d000
[ 4.287073] iwlwifi 0000:aa:00.0: base HW address: 4c:03:4f:4f:52:36
[ 4.318384] iwlwifi 0000:aa:00.0 wlp170s0: renamed from wlan0
[ 4.985501] iwlwifi 0000:aa:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[ 4.985556] iwlwifi 0000:aa:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[ 4.985568] iwlwifi 0000:aa:00.0: WFPM_AUTH_KEY_0: 0x80
[ 4.985581] iwlwifi 0000:aa:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x0
[ 274.210210] iwlwifi 0000:aa:00.0: Error sending ECHO_CMD: time out after 2000ms.
[ 274.210226] iwlwifi 0000:aa:00.0: Current CMD queue read_ptr 507 write_ptr 509
[ 274.238865] WARNING: CPU: 14 PID: 116 at drivers/net/wireless/intel/iwlwifi/pcie/trans.c:2172 __iwl_trans_pcie_grab_nic_access+0x192/0x1a0 [iwlwifi]
[ 274.238937] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 274.239365] RIP: 0010:__iwl_trans_pcie_grab_nic_access+0x192/0x1a0 [iwlwifi]
[ 274.239451] iwl_trans_pcie_grab_nic_access+0x1a/0x50 [iwlwifi]
[ 274.239494] iwl_force_nmi+0xe3/0x100 [iwlwifi]
[ 274.239533] iwl_trans_sync_nmi_with_addr+0x14e/0x170 [iwlwifi]
[ 274.239574] iwl_trans_pcie_sync_nmi+0x47/0x80 [iwlwifi]
[ 274.239617] iwl_trans_txq_send_hcmd_sync+0x356/0x370 [iwlwifi]
[ 274.239676] iwl_trans_txq_send_hcmd+0xb8/0x170 [iwlwifi]
[ 274.239724] iwl_trans_send_cmd+0x81/0x110 [iwlwifi]
[ 274.239769] iwl_mvm_send_cmd_pdu+0x6f/0xd0 [iwlmvm]
[ 274.239828] iwl_mvm_recalc_multicast+0x60/0xb0 [iwlmvm]
[ 274.239866] iwl_mvm_configure_filter+0x62/0xa0 [iwlmvm]
[ 274.240121] iwlwifi 0000:aa:00.0: iwlwifi transaction failed, dumping registers
[ 274.240126] iwlwifi 0000:aa:00.0: iwlwifi device config registers:
[ 274.240314] iwlwifi 0000:aa:00.0: 00000000: 27258086 00100000 0280001a 00000000 00000004 00000000 00000000 00000000
[ 274.240319] iwlwifi 0000:aa:00.0: 00000020: 00000000 00000000 00000000 00248086 00000000 000000c8 00000000 00000100
[ 274.240324] iwlwifi 0000:aa:00.0: 00000040: 00028010 10008ec0 001b0c10 0045e812 10120000 00000000 00000000 00000000
[ 274.240327] iwlwifi 0000:aa:00.0: 00000060: 00000000 00080812 00000005 00000006 00000002 00000000 00000000 00000000
[ 274.240331] iwlwifi 0000:aa:00.0: 00000080: 000f0011 00002000 00003000 00000000 00000000 00000000 00000000 00000000
[ 274.240335] iwlwifi 0000:aa:00.0: 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 274.240339] iwlwifi 0000:aa:00.0: 000000c0: 00000000 00000000 c823d001 0d000008 00804005 00000000 00000000 00000000
[ 274.240342] iwlwifi 0000:aa:00.0: 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 274.240346] iwlwifi 0000:aa:00.0: 00000100: 14c10001 00100000 00000000 00462031 00002000 00002000 00000014 40000001
[ 274.240350] iwlwifi 0000:aa:00.0: 00000120: 0000000f 7a200460 00000000 00000000 00000000 00000000 00000000 00000000
[ 274.240354] iwlwifi 0000:aa:00.0: 00000140: 14c00000 ff000000 000000ff 15410018 00000000 0001001e 00481e1f 00000000
[ 274.240357] iwlwifi 0000:aa:00.0: iwlwifi device memory mapped registers:
[ 274.240395] iwlwifi 0000:aa:00.0: 00000000: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
[ 274.240399] iwlwifi 0000:aa:00.0: 00000020: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
[ 274.240414] iwlwifi 0000:aa:00.0: iwlwifi device AER capability structure:
[ 274.240438] iwlwifi 0000:aa:00.0: 00000000: 14c10001 00100000 00000000 00462031 00002000 00002000 00000014 40000001
[ 274.240441] iwlwifi 0000:aa:00.0: 00000020: 0000000f 7a200460 00000000
[ 274.240444] iwlwifi 0000:aa:00.0: iwlwifi parent port (0000:00:1d.0) config registers:
[ 274.240605] iwlwifi 0000:00:1d.0: 00000000: 51b08086 00100407 06040001 00810010 00000000 00000000 00aaaa00 200000f0
[ 274.240609] iwlwifi 0000:00:1d.0: 00000020: 7a207a20 0001fff1 00000000 00000000 00000000 00000040 00000000 000201ff
[ 274.240613] iwlwifi 0000:00:1d.0: 00000040: 01428010 00008001 00100000 09724c13 70120042 0044b200 01400000 00000008
[ 274.240617] iwlwifi 0000:00:1d.0: 00000060: 00000000 00080837 00000000 0000000e 00000002 00000000 00000000 00000000
[ 274.240620] iwlwifi 0000:00:1d.0: 00000080: 00019005 fee00338 00000000 00000000 0000a00d 0003f111 00000000 00000000
[ 274.240624] iwlwifi 0000:00:1d.0: 000000a0: c8030001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 274.240628] iwlwifi 0000:00:1d.0: 000000c0: 00000000 00000000 00000000 00000000 06008001 40011842 099e0008 00000000
[ 274.240632] iwlwifi 0000:00:1d.0: 000000e0: 00f3f700 8a778a77 00138006 00000000 00000150 50000300 01110fb5 01000004
[ 274.240635] iwlwifi 0000:00:1d.0: 00000100: 22010001 00200000 00000000 00060011 00000000 00002000 00000015 35000000
[ 274.240639] iwlwifi 0000:00:1d.0: 00000120: 00001f1b 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 274.240643] iwlwifi 0000:00:1d.0: 00000140: 00000000 00000000 00000000 00000000 2001001f 00000406 00000003 00000000
[ 274.240647] iwlwifi 0000:00:1d.0: 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 274.240650] iwlwifi 0000:00:1d.0: 00000180: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 274.240654] iwlwifi 0000:00:1d.0: 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 274.240657] iwlwifi 0000:00:1d.0: 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 274.240661] iwlwifi 0000:00:1d.0: 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 274.240664] iwlwifi 0000:00:1d.0: 00000200: a301001e 00b0283f 4058281f
[ 274.240676] iwlwifi 0000:aa:00.0: iwlwifi root port (0000:00:1d.0) AER cap structure:
[ 274.240694] iwlwifi 0000:00:1d.0: 00000000: 22010001 00200000 00000000 00060011 00000000 00002000 00000015 35000000
[ 274.240697] iwlwifi 0000:00:1d.0: 00000020: 00001f1b 00000000 00000000 00000000 00000000 00000000
[ 274.268734] WARNING: CPU: 14 PID: 116 at drivers/net/wireless/intel/iwlwifi/iwl-trans.h:1418 iwl_fwrt_dump_lmac_error_log+0x4c9/0x5b0 [iwlwifi]
[ 274.268790] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 274.269050] RIP: 0010:iwl_fwrt_dump_lmac_error_log+0x4c9/0x5b0 [iwlwifi]
[ 274.269132] iwl_fwrt_dump_error_logs+0x29/0x220 [iwlwifi]
[ 274.269180] iwl_mvm_nic_error+0x7a/0x130 [iwlmvm]
[ 274.269223] iwl_trans_sync_nmi_with_addr+0x7a/0x170 [iwlwifi]
[ 274.269263] iwl_trans_pcie_sync_nmi+0x47/0x80 [iwlwifi]
[ 274.269306] iwl_trans_txq_send_hcmd_sync+0x356/0x370 [iwlwifi]
[ 274.269360] iwl_trans_txq_send_hcmd+0xb8/0x170 [iwlwifi]
[ 274.269406] iwl_trans_send_cmd+0x81/0x110 [iwlwifi]
[ 274.269451] iwl_mvm_send_cmd_pdu+0x6f/0xd0 [iwlmvm]
[ 274.269496] iwl_mvm_recalc_multicast+0x60/0xb0 [iwlmvm]
[ 274.269534] iwl_mvm_configure_filter+0x62/0xa0 [iwlmvm]
[ 274.269782] iwlwifi 0000:aa:00.0: HW error, resetting before reading
[ 274.303570] iwlwifi 0000:aa:00.0: Loaded firmware version: 72.a764baac.0 ty-a0-gf-a0-72.ucode
[ 274.303585] iwlwifi 0000:aa:00.0: 0x00000000 | ADVANCED_SYSASSERT
[ 274.303591] iwlwifi 0000:aa:00.0: 0x00000000 | trm_hw_status0
[ 274.303594] iwlwifi 0000:aa:00.0: 0x00000000 | trm_hw_status1
[ 274.303597] iwlwifi 0000:aa:00.0: 0x00000000 | branchlink2
[ 274.303601] iwlwifi 0000:aa:00.0: 0x00000000 | interruptlink1
[ 274.303603] iwlwifi 0000:aa:00.0: 0x00000000 | interruptlink2
[ 274.303606] iwlwifi 0000:aa:00.0: 0x00000000 | data1
[ 274.303609] iwlwifi 0000:aa:00.0: 0x00000000 | data2
[ 274.303611] iwlwifi 0000:aa:00.0: 0x00000000 | data3
[ 274.303614] iwlwifi 0000:aa:00.0: 0x00000000 | beacon time
[ 274.303617] iwlwifi 0000:aa:00.0: 0x00000000 | tsf low
[ 274.303620] iwlwifi 0000:aa:00.0: 0x00000000 | tsf hi
[ 274.303622] iwlwifi 0000:aa:00.0: 0x00000000 | time gp1
[ 274.303625] iwlwifi 0000:aa:00.0: 0x00000000 | time gp2
[ 274.303628] iwlwifi 0000:aa:00.0: 0x00000000 | uCode revision type
[ 274.303631] iwlwifi 0000:aa:00.0: 0x00000000 | uCode version major
[ 274.303633] iwlwifi 0000:aa:00.0: 0x00000000 | uCode version minor
[ 274.303636] iwlwifi 0000:aa:00.0: 0x00000000 | hw version
[ 274.303639] iwlwifi 0000:aa:00.0: 0x00000000 | board version
[ 274.303642] iwlwifi 0000:aa:00.0: 0x00000000 | hcmd
[ 274.303644] iwlwifi 0000:aa:00.0: 0x00000000 | isr0
[ 274.303647] iwlwifi 0000:aa:00.0: 0x00000000 | isr1
[ 274.303650] iwlwifi 0000:aa:00.0: 0x00000000 | isr2
[ 274.303652] iwlwifi 0000:aa:00.0: 0x00000000 | isr3
[ 274.303655] iwlwifi 0000:aa:00.0: 0x00000000 | isr4
[ 274.303657] iwlwifi 0000:aa:00.0: 0x00000000 | last cmd Id
[ 274.303660] iwlwifi 0000:aa:00.0: 0x00000000 | wait_event
[ 274.303663] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_control
[ 274.303666] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_duration
[ 274.303669] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_mhvalid
[ 274.303671] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_addr_match
[ 274.303674] iwlwifi 0000:aa:00.0: 0x00000000 | lmpm_pmg_sel
[ 274.303677] iwlwifi 0000:aa:00.0: 0x00000000 | timestamp
[ 274.303679] iwlwifi 0000:aa:00.0: 0x00000000 | flow_handler
[ 274.331172] iwlwifi 0000:aa:00.0: 0x00000000 | ADVANCED_SYSASSERT
[ 274.331177] iwlwifi 0000:aa:00.0: 0x00000000 | umac branchlink1
[ 274.331180] iwlwifi 0000:aa:00.0: 0x00000000 | umac branchlink2
[ 274.331183] iwlwifi 0000:aa:00.0: 0x00000000 | umac interruptlink1
[ 274.331186] iwlwifi 0000:aa:00.0: 0x00000000 | umac interruptlink2
[ 274.331189] iwlwifi 0000:aa:00.0: 0x00000000 | umac data1
[ 274.331192] iwlwifi 0000:aa:00.0: 0x00000000 | umac data2
[ 274.331195] iwlwifi 0000:aa:00.0: 0x00000000 | umac data3
[ 274.331198] iwlwifi 0000:aa:00.0: 0x00000000 | umac major
[ 274.331201] iwlwifi 0000:aa:00.0: 0x00000000 | umac minor
[ 274.331204] iwlwifi 0000:aa:00.0: 0x00000000 | frame pointer
[ 274.331207] iwlwifi 0000:aa:00.0: 0x00000000 | stack pointer
[ 274.331210] iwlwifi 0000:aa:00.0: 0x00000000 | last host cmd
[ 274.331212] iwlwifi 0000:aa:00.0: 0x00000000 | isr status reg
[ 274.358471] iwlwifi 0000:aa:00.0: IML/ROM dump:
[ 274.358475] iwlwifi 0000:aa:00.0: 0x5A5A | IML/ROM SYSASSERT
[ 274.358478] iwlwifi 0000:aa:00.0: 0x5A5A5A5A | IML/ROM error/state
[ 274.385808] iwlwifi 0000:aa:00.0: 0x5A5A5A5A | IML/ROM data1
[ 274.413612] iwlwifi 0000:aa:00.0: 0x5A5A5A5A | IML/ROM WFPM_AUTH_KEY_0
[ 274.468879] iwlwifi 0000:aa:00.0: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[ 274.468903] iwlwifi 0000:aa:00.0: Failed to synchronize multicast groups update
[ 274.496833] iwlwifi 0000:aa:00.0: WRT: Failed to dump region: id=1, type=10
[ 274.525156] iwlwifi 0000:aa:00.0: WRT: Failed to dump region: id=2, type=11
[ 274.703804] iwlwifi 0000:aa:00.0: Failed to get monitor header
[ 274.703814] iwlwifi 0000:aa:00.0: WRT: Failed to fill region header: id=16, type=2
[ 274.825084] iwlwifi 0000:aa:00.0: WRT: Failed to dump region: id=21, type=10
[ 274.855686] iwlwifi 0000:aa:00.0: WRT: Failed to dump region: id=22, type=10
[ 274.981439] iwlwifi 0000:aa:00.0: mcast filter cmd error. ret=-5
[ 274.981454] iwlwifi 0000:aa:00.0: Failed to synchronize multicast groups update
[ 279.201735] iwlwifi 0000:aa:00.0: WFPM_UMAC_PD_NOTIFICATION: 0x5a5a5a5a
[ 279.232049] iwlwifi 0000:aa:00.0: WFPM_LMAC2_PD_NOTIFICATION: 0x5a5a5a5a
[ 279.262511] iwlwifi 0000:aa:00.0: WFPM_AUTH_KEY_0: 0x5a5a5a5a
[ 279.292458] iwlwifi 0000:aa:00.0: CNVI_SCU_SEQ_DATA_DW9: 0x5a5a5a5a
[ 279.352762] iwlwifi 0000:aa:00.0: SecBoot CPU1 Status: 0x5a5a5a5a, CPU2 Status: 0x5a5a5a5a
[ 279.382929] iwlwifi 0000:aa:00.0: WFPM_LMAC1_PD_NOTIFICATION: 0x5a5a5a5a
[ 279.413186] iwlwifi 0000:aa:00.0: HPM_SECONDARY_DEVICE_STATE: 0x5a5a5a5a
[ 279.443407] iwlwifi 0000:aa:00.0: WFPM_MAC_OTP_CFG7_ADDR: 0x5a5a5a5a
[ 279.473439] iwlwifi 0000:aa:00.0: WFPM_MAC_OTP_CFG7_DATA: 0x5a5a5a5a
[ 279.503498] iwlwifi 0000:aa:00.0: UMAC PC: 0x5a5a5a5a
[ 279.533755] iwlwifi 0000:aa:00.0: LMAC PC: 0x5a5a5a5a
[ 279.533761] iwlwifi 0000:aa:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 279.594379] WARNING: CPU: 14 PID: 822 at drivers/net/wireless/intel/iwlwifi/iwl-trans.h:1418 iwl_fwrt_dump_lmac_error_log+0x4c9/0x5b0 [iwlwifi]
[ 279.594466] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 279.594872] RIP: 0010:iwl_fwrt_dump_lmac_error_log+0x4c9/0x5b0 [iwlwifi]
[ 279.594971] iwl_fwrt_dump_error_logs+0x29/0x220 [iwlwifi]
[ 279.595018] iwl_mvm_nic_error+0x7a/0x130 [iwlmvm]
[ 279.595076] iwl_trans_sync_nmi_with_addr+0x7a/0x170 [iwlwifi]
[ 279.595116] iwl_trans_pcie_sync_nmi+0x47/0x80 [iwlwifi]
[ 279.595161] iwl_fw_dbg_error_collect+0x61/0xf0 [iwlwifi]
[ 279.595210] iwl_mvm_load_ucode_wait_alive+0x574/0x610 [iwlmvm]
[ 279.595248] ? __pfx_iwl_alive_fn+0x10/0x10 [iwlmvm]
[ 279.595285] iwl_run_unified_mvm_ucode+0xbb/0x260 [iwlmvm]
[ 279.595322] ? __pfx_iwl_wait_init_complete+0x10/0x10 [iwlmvm]
[ 279.595367] ? iwl_trans_pcie_grab_nic_access+0x31/0x50 [iwlwifi]
[ 279.595413] iwl_mvm_up+0x229/0xa70 [iwlmvm]
[ 279.595453] __iwl_mvm_mac_start+0x6f/0xf0 [iwlmvm]
[ 279.595492] iwl_mvm_mac_start+0x98/0x150 [iwlmvm]
[ 279.595926] iwlwifi 0000:aa:00.0: HW error, resetting before reading
[ 279.632238] iwlwifi 0000:aa:00.0: Loaded firmware version: 72.a764baac.0 ty-a0-gf-a0-72.ucode
[ 279.632251] iwlwifi 0000:aa:00.0: 0x00000000 | ADVANCED_SYSASSERT
[ 279.632257] iwlwifi 0000:aa:00.0: 0x00000000 | trm_hw_status0
[ 279.632261] iwlwifi 0000:aa:00.0: 0x00000000 | trm_hw_status1
[ 279.632264] iwlwifi 0000:aa:00.0: 0x00000000 | branchlink2
[ 279.632266] iwlwifi 0000:aa:00.0: 0x00000000 | interruptlink1
[ 279.632269] iwlwifi 0000:aa:00.0: 0x00000000 | interruptlink2
[ 279.632271] iwlwifi 0000:aa:00.0: 0x00000000 | data1
[ 279.632274] iwlwifi 0000:aa:00.0: 0x00000000 | data2
[ 279.632276] iwlwifi 0000:aa:00.0: 0x00000000 | data3
[ 279.632278] iwlwifi 0000:aa:00.0: 0x00000000 | beacon time
[ 279.632281] iwlwifi 0000:aa:00.0: 0x00000000 | tsf low
[ 279.632284] iwlwifi 0000:aa:00.0: 0x00000000 | tsf hi
[ 279.632286] iwlwifi 0000:aa:00.0: 0x00000000 | time gp1
[ 279.632288] iwlwifi 0000:aa:00.0: 0x00000000 | time gp2
[ 279.632291] iwlwifi 0000:aa:00.0: 0x00000000 | uCode revision type
[ 279.632294] iwlwifi 0000:aa:00.0: 0x00000000 | uCode version major
[ 279.632296] iwlwifi 0000:aa:00.0: 0x00000000 | uCode version minor
[ 279.632299] iwlwifi 0000:aa:00.0: 0x00000000 | hw version
[ 279.632301] iwlwifi 0000:aa:00.0: 0x00000000 | board version
[ 279.632304] iwlwifi 0000:aa:00.0: 0x00000000 | hcmd
[ 279.632306] iwlwifi 0000:aa:00.0: 0x00000000 | isr0
[ 279.632309] iwlwifi 0000:aa:00.0: 0x00000000 | isr1
[ 279.632311] iwlwifi 0000:aa:00.0: 0x00000000 | isr2
[ 279.632313] iwlwifi 0000:aa:00.0: 0x00000000 | isr3
[ 279.632316] iwlwifi 0000:aa:00.0: 0x00000000 | isr4
[ 279.632318] iwlwifi 0000:aa:00.0: 0x00000000 | last cmd Id
[ 279.632321] iwlwifi 0000:aa:00.0: 0x00000000 | wait_event
[ 279.632323] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_control
[ 279.632326] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_duration
[ 279.632328] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_mhvalid
[ 279.632331] iwlwifi 0000:aa:00.0: 0x00000000 | l2p_addr_match
[ 279.632333] iwlwifi 0000:aa:00.0: 0x00000000 | lmpm_pmg_sel
[ 279.632336] iwlwifi 0000:aa:00.0: 0x00000000 | timestamp
[ 279.632338] iwlwifi 0000:aa:00.0: 0x00000000 | flow_handler
[ 279.662540] iwlwifi 0000:aa:00.0: 0x00000000 | ADVANCED_SYSASSERT
[ 279.662545] iwlwifi 0000:aa:00.0: 0x00000000 | umac branchlink1
[ 279.662549] iwlwifi 0000:aa:00.0: 0x00000000 | umac branchlink2
[ 279.662551] iwlwifi 0000:aa:00.0: 0x00000000 | umac interruptlink1
[ 279.662555] iwlwifi 0000:aa:00.0: 0x00000000 | umac interruptlink2
[ 279.662557] iwlwifi 0000:aa:00.0: 0x00000000 | umac data1
[ 279.662560] iwlwifi 0000:aa:00.0: 0x00000000 | umac data2
[ 279.662563] iwlwifi 0000:aa:00.0: 0x00000000 | umac data3
[ 279.662566] iwlwifi 0000:aa:00.0: 0x00000000 | umac major
[ 279.662569] iwlwifi 0000:aa:00.0: 0x00000000 | umac minor
[ 279.662571] iwlwifi 0000:aa:00.0: 0x00000000 | frame pointer
[ 279.662574] iwlwifi 0000:aa:00.0: 0x00000000 | stack pointer
[ 279.662577] iwlwifi 0000:aa:00.0: 0x00000000 | last host cmd
[ 279.662580] iwlwifi 0000:aa:00.0: 0x00000000 | isr status reg
[ 279.692804] iwlwifi 0000:aa:00.0: IML/ROM dump:
[ 279.692807] iwlwifi 0000:aa:00.0: 0x5A5A | IML/ROM SYSASSERT
[ 279.692810] iwlwifi 0000:aa:00.0: 0x5A5A5A5A | IML/ROM error/state
[ 279.723016] iwlwifi 0000:aa:00.0: 0x5A5A5A5A | IML/ROM data1
[ 279.753129] iwlwifi 0000:aa:00.0: 0x5A5A5A5A | IML/ROM WFPM_AUTH_KEY_0
[ 279.783214] iwlwifi 0000:aa:00.0: Failed to start RT ucode: -110
[ 279.783220] iwlwifi 0000:aa:00.0: Failed to start RT ucode: -110
[ 279.783226] iwlwifi 0000:aa:00.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
[ 279.843413] iwlwifi 0000:aa:00.0: WRT: Failed to dump region: id=1, type=10
[ 280.024895] iwlwifi 0000:aa:00.0: Failed to get monitor header
[ 280.024903] iwlwifi 0000:aa:00.0: WRT: Failed to fill region header: id=16, type=2
[ 280.145868] iwlwifi 0000:aa:00.0: WRT: Failed to dump region: id=21, type=10
[ 280.269342] iwlwifi 0000:aa:00.0: WRT: Failed to dump region: id=1, type=10
[ 280.450477] iwlwifi 0000:aa:00.0: Failed to get monitor header
[ 280.450485] iwlwifi 0000:aa:00.0: WRT: Failed to fill region header: id=16, type=2
[ 280.571681] iwlwifi 0000:aa:00.0: WRT: Failed to dump region: id=21, type=10
[ 283.716725] iwlwifi 0000:aa:00.0: mac start retry 0
[ 283.717127] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 283.749079] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 283.750822] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 283.752340] iwlwifi 0000:aa:00.0: Failed to synchronize multicast groups update
[ 283.752599] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 283.754222] ? __iwl_err+0x180/0x190 [iwlwifi]
[ 283.754291] ? iwl_mvm_recalc_multicast+0x9b/0xb0 [iwlmvm]
[ 283.754920] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 283.756161] ? __iwl_err+0x180/0x190 [iwlwifi]
[ 283.756202] ? iwl_mvm_recalc_multicast+0x9b/0xb0 [iwlmvm]
[ 283.756715] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 283.758327] ? __iwl_err+0x180/0x190 [iwlwifi]
[ 283.758368] ? iwl_mvm_recalc_multicast+0x9b/0xb0 [iwlmvm]
[ 283.758759] iwlwifi 0000:aa:00.0: Failed to trigger RX queues sync (-5)
[ 283.758879] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 283.760238] ? __iwl_err+0x180/0x190 [iwlwifi]
[ 283.760276] ? iwl_mvm_recalc_multicast+0x9b/0xb0 [iwlmvm]
[ 283.760784] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 283.762162] ? __iwl_err+0x180/0x190 [iwlwifi]
[ 283.762200] ? iwl_mvm_recalc_multicast+0x9b/0xb0 [iwlmvm]
[ 283.762667] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 283.763870] ? __iwl_err+0x180/0x190 [iwlwifi]
[ 283.763908] ? iwl_mvm_recalc_multicast+0x9b/0xb0 [iwlmvm]
The rest in the next comment.
@Anachron log continued…
[ 283.764374] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 283.766000] ? __iwl_err+0x180/0x190 [iwlwifi]
[ 283.766038] ? iwl_mvm_recalc_multicast+0x9b/0xb0 [iwlmvm]
[ 283.766550] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 283.767740] ? __iwl_err+0x180/0x190 [iwlwifi]
[ 283.767777] ? iwl_mvm_recalc_multicast+0x9b/0xb0 [iwlmvm]
[ 283.768230] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 283.769359] ? __iwl_err+0x180/0x190 [iwlwifi]
[ 283.769395] ? iwl_mvm_recalc_multicast+0x9b/0xb0 [iwlmvm]
[ 283.769830] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 283.771114] ? __iwl_err+0x180/0x190 [iwlwifi]
[ 283.771150] ? iwl_mvm_recalc_multicast+0x9b/0xb0 [iwlmvm]
[ 283.771731] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 283.772996] ? __iwl_err+0x180/0x190 [iwlwifi]
[ 283.773032] ? iwl_mvm_recalc_multicast+0x9b/0xb0 [iwlmvm]
[ 283.773468] Modules linked in: ccm rfcomm snd_seq_dummy snd_hrtimer snd_hda_codec_hdmi snd_hda_codec_idt snd_hda_codec_generic ledtrig_audio cmac algif_hash algif_skcipher af_alg bnep binfmt_misc nls_iso8859_1 x86_pkg_temp_thermal intel_powerclamp snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi iwlmvm snd_hda_codec snd_hda_core coretemp mac80211 snd_hwdep kvm_intel i915 libarc4 snd_pcm kvm drm_buddy snd_seq_midi ttm irqbypass snd_seq_midi_event btusb crct10dif_pclmul polyval_clmulni snd_rawmidi polyval_generic mei_pxp mei_hdcp btrtl drm_display_helper iwlwifi btbcm uvcvideo ghash_clmulni_intel snd_seq sha512_ssse3 btintel cec videobuf2_vmalloc aesni_intel btmtk
[ 283.774668] ? __iwl_err+0x180/0x190 [iwlwifi]
[ 283.774704] ? iwl_mvm_recalc_multicast+0x9b/0xb0 [iwlmvm]
After looking at Ubuntu Wi-Fi Troubleshooting Guide, I entered nmcli radio and saw that wifi has been disabled.
I then entered nmcli radio wifi on and it started working again. This is so odd, I wonder why it was set to off all of a sudden.
I’ve restarted to test things out again and luckily (unlucky?) this time wifi failed within minutes.
This time dmesg | grep iwl simply repeats
iwlwifi 0000:aa:00.0: Hardware error detected. Restarting.
for a few hundred times.
Seems like hardware error to me…
Appreciate you using the guide.
Yes, it could be hardware. Please go ahead and open a ticket and link to this thread to cover what we’ve done thus far.
In the ticket, first thing we’re going to ask you to do will be to try 22.04 on a live USB - play Youtube like you did here and see if it replicates the failure. If it does, it’s a bad card. If it doesn’t, we will dig deeper.
Just to rule thinga ozt:
Are you dual-booting with Windows?
@Anachron Nope, just Ubuntu.
Hi @Andrew_Feng ,
Apart from Ubuntu, have you tried fedora live and see if the same symptom is happening?
I have the same symptom - after a random interval of time, wifi stops working, disconnects and is unable to find any networks. Issue is resolved after rebooting.
Sometimes it happens after minutes, sometimes it takes hours.
I’m on Arch Linux with kernel 6.10.7-arch1-1. The laptop is otherwise working great with Arch Linux (I have the refreshed AMD model with 2.8K display).
Next time the issue occurs, I will check the log files to see if it is the same issue as reported here. Is this a hardware fault?
I have the log output now from when the issue occurred the next time.
journalctl says
wpa_supplicant[746]: wlp1s0: WNM: Preferred List Available
wpa_supplicant[746]: wlp1s0: WNM: Disassociation Imminent - Disassociation Timer 100
wpa_supplicant[746]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-71 noise=9999 txrate=432300
wpa_supplicant[746]: wlp1s0: SME: Trying to authenticate with 18:6a:81:ec:b9:6e (SSID='...' freq=2437 MHz)
kernel: wlp1s0: disconnect from AP 18:6a:81:ec:b9:6f for new auth to 18:6a:81:ec:b9:6e
kernel: wlp1s0: authenticate with 18:6a:81:ec:b9:6e (local address=44:fa:66:23:31:8f)
kernel: wlp1s0: send auth to 18:6a:81:ec:b9:6e (try 1/3)
NetworkManager[597]: <info> [1725127306.0044] device (wlp1s0): supplicant interface state: completed -> authenticating
NetworkManager[597]: <info> [1725127306.0045] device (p2p-dev-wlp1s0): supplicant management interface state: completed -> authenticating
wpa_supplicant[746]: wlp1s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
wpa_supplicant[746]: wlp1s0: CTRL-EVENT-REGDOM-CHANGE init=USER type=COUNTRY alpha2=DE
kernel: wlp1s0: send auth to 18:6a:81:ec:b9:6e (try 2/3)
kernel: wlp1s0: send auth to 18:6a:81:ec:b9:6e (try 3/3)
kernel: wlp1s0: authentication with 18:6a:81:ec:b9:6e timed out
wpa_supplicant[746]: wlp1s0: Added BSSID 18:6a:81:ec:b9:6e into ignore list, ignoring for 10 seconds
wpa_supplicant[746]: wlp1s0: BSSID 18:6a:81:ec:b9:6e ignore list count incremented to 2, ignoring for 10 seconds
NetworkManager[597]: <info> [1725127306.4211] device (wlp1s0): supplicant interface state: authenticating -> disconnected
NetworkManager[597]: <info> [1725127306.4212] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating -> disconnected
NetworkManager[597]: <info> [1725127306.5210] device (wlp1s0): supplicant interface state: disconnected -> scanning
NetworkManager[597]: <info> [1725127306.5210] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected -> scanning
wpa_supplicant[746]: wlp1s0: SME: Trying to authenticate with 18:6a:81:ec:b9:6f (SSID='...' freq=5220 MHz)
kernel: wlp1s0: authenticate with 18:6a:81:ec:b9:6f (local address=44:fa:66:23:31:8f)
NetworkManager[597]: <info> [1725127307.3026] device (wlp1s0): supplicant interface state: scanning -> authenticating
NetworkManager[597]: <info> [1725127307.3026] device (p2p-dev-wlp1s0): supplicant management interface state: scanning -> authenticating
kernel: wlp1s0: send auth to 18:6a:81:ec:b9:6f (try 1/3)
kernel: wlp1s0: send auth to 18:6a:81:ec:b9:6f (try 2/3)
kernel: wlp1s0: send auth to 18:6a:81:ec:b9:6f (try 3/3)
kernel: wlp1s0: authentication with 18:6a:81:ec:b9:6f timed out
wpa_supplicant[746]: wlp1s0: Added BSSID 18:6a:81:ec:b9:6f into ignore list, ignoring for 10 seconds
NetworkManager[597]: <info> [1725127307.7225] device (wlp1s0): supplicant interface state: authenticating -> disconnected
NetworkManager[597]: <info> [1725127307.7226] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating -> disconnected
NetworkManager[597]: <info> [1725127308.2231] device (wlp1s0): supplicant interface state: disconnected -> scanning
NetworkManager[597]: <info> [1725127308.2232] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected -> scanning
wpa_supplicant[746]: wlp1s0: Removed BSSID 18:6a:81:ec:b9:6f from ignore list (clear)
wpa_supplicant[746]: wlp1s0: Removed BSSID 18:6a:81:ec:b9:6e from ignore list (clear)
NetworkManager[597]: <warn> [1725127321.9835] device (wlp1s0): link timed out.
NetworkManager[597]: <info> [1725127321.9838] device (wlp1s0): state change: activated -> failed (reason 'ssid-not-found', sys-iface-state:>
NetworkManager[597]: <info> [1725127321.9839] manager: NetworkManager state is now DISCONNECTED
avahi-daemon[1954]: Interface wlp1s0.IPv6 no longer relevant for mDNS.
avahi-daemon[1954]: Leaving mDNS multicast group on interface wlp1s0.IPv6 with address 2003:f3:737:da72:98fa:e0a8:bb64:214e.
NetworkManager[597]: <info> [1725127322.0632] device (wlp1s0): set-hw-addr: set MAC address to C6:19:32:E9:D7:5A (scanning)
NetworkManager[597]: <warn> [1725127324.3853] device (wlp1s0): Activation: failed for connection '...'
NetworkManager[597]: <info> [1725127324.3856] device (wlp1s0): supplicant interface state: scanning -> interface_disabled
NetworkManager[597]: <info> [1725127324.3857] device (p2p-dev-wlp1s0): supplicant management interface state: scanning -> interface_disabled
systemd[1]: Starting Network Manager Script Dispatcher Service...
wpa_supplicant[746]: wlp1s0: PMKSA-CACHE-REMOVED 18:6a:81:ec:b9:6e 0
wpa_supplicant[746]: wlp1s0: PMKSA-CACHE-REMOVED 18:6a:81:ec:b9:6f 0
wpa_supplicant[746]: wlp1s0: CTRL-EVENT-DSCP-POLICY clear_all
NetworkManager[597]: <info> [1725127324.4248] device (wlp1s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'manag>
avahi-daemon[1954]: Withdrawing address record for 2003:f3:737:da72:98fa:e0a8:bb64:214e on wlp1s0.
avahi-daemon[1954]: Joining mDNS multicast group on interface wlp1s0.IPv6 with address fe80::6991:f2c3:3f84:d302.
NetworkManager[597]: <info> [1725127324.4253] dhcp4 (wlp1s0): canceled DHCP transaction
avahi-daemon[1954]: Registering new address record for fe80::6991:f2c3:3f84:d302 on wlp1s0.*.
NetworkManager[597]: <info> [1725127324.4253] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
avahi-daemon[1954]: Withdrawing address record for fe80::6991:f2c3:3f84:d302 on wlp1s0.
NetworkManager[597]: <info> [1725127324.4254] dhcp4 (wlp1s0): state changed no lease
avahi-daemon[1954]: Leaving mDNS multicast group on interface wlp1s0.IPv6 with address fe80::6991:f2c3:3f84:d302.
NetworkManager[597]: <info> [1725127324.4255] dhcp6 (wlp1s0): canceled DHCP transaction
NetworkManager[597]: <info> [1725127324.4255] dhcp6 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
NetworkManager[597]: <info> [1725127324.4255] dhcp6 (wlp1s0): state changed no lease
avahi-daemon[1954]: Withdrawing address record for 192.168.2.116 on wlp1s0.
avahi-daemon[1954]: Leaving mDNS multicast group on interface wlp1s0.IPv4 with address 192.168.2.116.
avahi-daemon[1954]: Interface wlp1s0.IPv4 no longer relevant for mDNS.
systemd[1]: Started Network Manager Script Dispatcher Service.
NetworkManager[597]: <info> [1725127324.5355] device (wlp1s0): supplicant interface state: interface_disabled -> scanning
NetworkManager[597]: <info> [1725127324.5355] device (p2p-dev-wlp1s0): supplicant management interface state: interface_disabled -> scanning
NetworkManager[597]: <info> [1725127327.6974] device (wlp1s0): supplicant interface state: scanning -> disconnected
NetworkManager[597]: <info> [1725127327.6975] device (p2p-dev-wlp1s0): supplicant management interface state: scanning -> disconnected
NetworkManager[597]: <info> [1725127330.7602] device (wlp1s0): supplicant interface state: disconnected -> inactive
NetworkManager[597]: <info> [1725127330.7603] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected -> inactive
systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
And dmesg is showing
[ 1273.113958] wlp1s0: disconnect from AP 18:6a:81:ec:b9:6f for new auth to 18:6a:81:ec:b9:6e
[ 1273.365178] wlp1s0: authenticate with 18:6a:81:ec:b9:6e (local address=44:fa:66:23:31:8f)
[ 1273.379828] wlp1s0: send auth to 18:6a:81:ec:b9:6e (try 1/3)
[ 1273.387469] wlp1s0: authenticated
[ 1273.460201] wlp1s0: associate with 18:6a:81:ec:b9:6e (try 1/3)
[ 1273.499155] wlp1s0: RX ReassocResp from 18:6a:81:ec:b9:6e (capab=0x1411 status=0 aid=24)
[ 1273.532071] wlp1s0: associated
[ 1274.736256] wlp1s0: Limiting TX power to 20 (20 - 0) dBm as advertised by 18:6a:81:ec:b9:6e
[ 1310.873712] wlp1s0: disconnect from AP 18:6a:81:ec:b9:6e for new auth to 18:6a:81:ec:b9:6f
[ 1311.174411] wlp1s0: authenticate with 18:6a:81:ec:b9:6f (local address=44:fa:66:23:31:8f)
[ 1311.189921] wlp1s0: send auth to 18:6a:81:ec:b9:6f (try 1/3)
[ 1311.198409] wlp1s0: authenticated
[ 1311.263535] wlp1s0: associate with 18:6a:81:ec:b9:6f (try 1/3)
[ 1311.305103] wlp1s0: RX ReassocResp from 18:6a:81:ec:b9:6f (capab=0x1011 status=0 aid=11)
[ 1311.339365] wlp1s0: associated
[ 1311.410076] wlp1s0: Limiting TX power to 23 (23 - 0) dBm as advertised by 18:6a:81:ec:b9:6f
[ 4334.466719] wlp1s0: disconnect from AP 18:6a:81:ec:b9:6f for new auth to 18:6a:81:ec:b9:6e
[ 4334.689515] wlp1s0: authenticate with 18:6a:81:ec:b9:6e (local address=44:fa:66:23:31:8f)
[ 4334.704109] wlp1s0: send auth to 18:6a:81:ec:b9:6e (try 1/3)
[ 4334.711738] wlp1s0: authenticated
[ 4334.786331] wlp1s0: associate with 18:6a:81:ec:b9:6e (try 1/3)
[ 4334.822810] wlp1s0: RX ReassocResp from 18:6a:81:ec:b9:6e (capab=0x1411 status=0 aid=22)
[ 4334.855070] wlp1s0: associated
[ 4334.973033] wlp1s0: Limiting TX power to 20 (20 - 0) dBm as advertised by 18:6a:81:ec:b9:6e
[ 4688.216607] wlp1s0: disconnect from AP 18:6a:81:ec:b9:6e for new auth to 18:6a:81:ec:b9:6f
[ 4688.483318] wlp1s0: authenticate with 18:6a:81:ec:b9:6f (local address=44:fa:66:23:31:8f)
[ 4688.498792] wlp1s0: send auth to 18:6a:81:ec:b9:6f (try 1/3)
[ 4688.506414] wlp1s0: authenticated
[ 4688.579592] wlp1s0: associate with 18:6a:81:ec:b9:6f (try 1/3)
[ 4688.613697] wlp1s0: RX ReassocResp from 18:6a:81:ec:b9:6f (capab=0x1011 status=0 aid=19)
[ 4688.646958] wlp1s0: associated
[ 4688.647057] wlp1s0: Limiting TX power to 23 (23 - 0) dBm as advertised by 18:6a:81:ec:b9:6f
[ 5054.786441] wlp1s0: disconnect from AP 18:6a:81:ec:b9:6f for new auth to 18:6a:81:ec:b9:6e
[ 5055.061022] wlp1s0: authenticate with 18:6a:81:ec:b9:6e (local address=44:fa:66:23:31:8f)
[ 5055.075719] wlp1s0: send auth to 18:6a:81:ec:b9:6e (try 1/3)
[ 5055.083399] wlp1s0: authenticated
[ 5055.152972] wlp1s0: associate with 18:6a:81:ec:b9:6e (try 1/3)
[ 5055.195026] wlp1s0: RX ReassocResp from 18:6a:81:ec:b9:6e (capab=0x1411 status=0 aid=26)
[ 5055.228122] wlp1s0: associated
[ 5055.433186] wlp1s0: Limiting TX power to 20 (20 - 0) dBm as advertised by 18:6a:81:ec:b9:6e
[ 5596.216439] wlp1s0: disconnect from AP 18:6a:81:ec:b9:6e for new auth to 18:6a:81:ec:b9:6f
[ 5596.448350] wlp1s0: authenticate with 18:6a:81:ec:b9:6f (local address=44:fa:66:23:31:8f)
[ 5596.463813] wlp1s0: send auth to 18:6a:81:ec:b9:6f (try 1/3)
[ 5596.472935] wlp1s0: authenticated
[ 5596.546111] wlp1s0: associate with 18:6a:81:ec:b9:6f (try 1/3)
[ 5596.581924] wlp1s0: RX ReassocResp from 18:6a:81:ec:b9:6f (capab=0x1011 status=0 aid=28)
[ 5596.615737] wlp1s0: associated
[ 5596.730809] wlp1s0: Limiting TX power to 23 (23 - 0) dBm as advertised by 18:6a:81:ec:b9:6f
[ 5955.456378] wlp1s0: disconnect from AP 18:6a:81:ec:b9:6f for new auth to 18:6a:81:ec:b9:6e
[ 5955.714385] wlp1s0: authenticate with 18:6a:81:ec:b9:6e (local address=44:fa:66:23:31:8f)
[ 5955.728992] wlp1s0: send auth to 18:6a:81:ec:b9:6e (try 1/3)
[ 5955.736985] wlp1s0: authenticated
[ 5955.806059] wlp1s0: associate with 18:6a:81:ec:b9:6e (try 1/3)
[ 5955.851067] wlp1s0: RX ReassocResp from 18:6a:81:ec:b9:6e (capab=0x1411 status=0 aid=15)
[ 5955.883875] wlp1s0: associated
[ 5956.039737] wlp1s0: Limiting TX power to 20 (20 - 0) dBm as advertised by 18:6a:81:ec:b9:6e
[ 6245.686383] wlp1s0: disconnect from AP 18:6a:81:ec:b9:6e for new auth to 18:6a:81:ec:b9:6f
[ 6245.940217] wlp1s0: authenticate with 18:6a:81:ec:b9:6f (local address=44:fa:66:23:31:8f)
[ 6245.955689] wlp1s0: send auth to 18:6a:81:ec:b9:6f (try 1/3)
[ 6245.963134] wlp1s0: authenticated
[ 6246.035985] wlp1s0: associate with 18:6a:81:ec:b9:6f (try 1/3)
[ 6246.070024] wlp1s0: RX ReassocResp from 18:6a:81:ec:b9:6f (capab=0x1011 status=0 aid=8)
[ 6246.101551] wlp1s0: associated
[ 6246.171204] wlp1s0: Limiting TX power to 23 (23 - 0) dBm as advertised by 18:6a:81:ec:b9:6f
[ 6632.942350] perf: interrupt took too long (2517 > 2500), lowering kernel.perf_event_max_sample_rate to 79200
[ 6642.696983] cros-ec-dev cros-ec-dev.2.auto: Some logs may have been dropped...
[ 6975.746300] wlp1s0: disconnect from AP 18:6a:81:ec:b9:6f for new auth to 18:6a:81:ec:b9:6e
[ 6975.981078] wlp1s0: authenticate with 18:6a:81:ec:b9:6e (local address=44:fa:66:23:31:8f)
[ 6975.995711] wlp1s0: send auth to 18:6a:81:ec:b9:6e (try 1/3)
[ 6976.003353] wlp1s0: authenticated
[ 6976.075865] wlp1s0: associate with 18:6a:81:ec:b9:6e (try 1/3)
[ 6976.116971] wlp1s0: RX ReassocResp from 18:6a:81:ec:b9:6e (capab=0x1411 status=0 aid=16)
[ 6976.149730] wlp1s0: associated
[ 6976.659569] wlp1s0: Limiting TX power to 20 (20 - 0) dBm as advertised by 18:6a:81:ec:b9:6e
[ 8210.903772] perf: interrupt took too long (3168 > 3146), lowering kernel.perf_event_max_sample_rate to 63000
[ 9569.135601] wlp1s0: disconnect from AP 18:6a:81:ec:b9:6e for new auth to 18:6a:81:ec:b9:6f
[ 9569.373892] wlp1s0: authenticate with 18:6a:81:ec:b9:6f (local address=44:fa:66:23:31:8f)
[ 9569.389425] wlp1s0: send auth to 18:6a:81:ec:b9:6f (try 1/3)
[ 9569.397189] wlp1s0: authenticated
[ 9569.468785] wlp1s0: associate with 18:6a:81:ec:b9:6f (try 1/3)
[ 9569.507994] wlp1s0: RX ReassocResp from 18:6a:81:ec:b9:6f (capab=0x1011 status=0 aid=22)
[ 9569.540876] wlp1s0: associated
[ 9569.562295] wlp1s0: Limiting TX power to 23 (23 - 0) dBm as advertised by 18:6a:81:ec:b9:6f
[ 9976.068885] wlp1s0: disconnect from AP 18:6a:81:ec:b9:6f for new auth to 18:6a:81:ec:b9:6e
[ 9978.006688] wlp1s0: authenticate with 18:6a:81:ec:b9:6e (local address=44:fa:66:23:31:8f)
[ 9978.021299] wlp1s0: send auth to 18:6a:81:ec:b9:6e (try 1/3)
[ 9978.128668] wlp1s0: send auth to 18:6a:81:ec:b9:6e (try 2/3)
[ 9978.237727] wlp1s0: send auth to 18:6a:81:ec:b9:6e (try 3/3)
[ 9978.348739] wlp1s0: authentication with 18:6a:81:ec:b9:6e timed out
[ 9979.305318] wlp1s0: authenticate with 18:6a:81:ec:b9:6f (local address=44:fa:66:23:31:8f)
[ 9979.319602] wlp1s0: send auth to 18:6a:81:ec:b9:6f (try 1/3)
[ 9979.424070] wlp1s0: send auth to 18:6a:81:ec:b9:6f (try 2/3)
[ 9979.531092] wlp1s0: send auth to 18:6a:81:ec:b9:6f (try 3/3)
[ 9979.635371] wlp1s0: authentication with 18:6a:81:ec:b9:6f timed out
Trying to turn wifi on and off with nmcli r wifi off and nmcli r wifi on does NOT fix the issue.
What DOES help is reloading the kernel module with
# modprobe -r mt7921e
# modprobe mt7921e
after which dmesg is showing
[14483.749571] mt7921e 0000:01:00.0: ASIC revision: 79220010
[14483.831839] mt7921e 0000:01:00.0: HW/SW Version: 0x8a108a10, Build Time: 20240716163242a
[14483.848444] mt7921e 0000:01:00.0: WM Firmware Version: ____000000, Build Time: 20240716163327
[14484.981753] mt7921e 0000:01:00.0 wlp1s0: renamed from wlan0
[14488.499438] wlp1s0: authenticate with 18:6a:81:ec:b9:6e (local address=44:fa:66:23:31:8f)
[14488.654541] wlp1s0: send auth to 18:6a:81:ec:b9:6e (try 1/3)
[14488.677249] wlp1s0: authenticate with 18:6a:81:ec:b9:6e (local address=44:fa:66:23:31:8f)
[14488.687760] wlp1s0: send auth to 18:6a:81:ec:b9:6e (try 1/3)
[14488.693305] wlp1s0: authenticated
[14488.697402] wlp1s0: associate with 18:6a:81:ec:b9:6e (try 1/3)
[14488.722053] wlp1s0: RX AssocResp from 18:6a:81:ec:b9:6e (capab=0x1411 status=0 aid=25)
[14488.752455] wlp1s0: associated
[14488.833798] wlp1s0: Limiting TX power to 20 (20 - 0) dBm as advertised by 18:6a:81:ec:b9:6e
Unfortunately, I can’t spot any particular error message in there - it looks like it “just” stops working.
