I’m running Fedora 39 (Kinoite) on an 11th-Gen Intel and trying to update from 3.16 to 3.17 via fwupd/LVFS keeps failing.
$ fwupdmgr get-results <Device ID>
System Firmware:
Device ID: <REDACTED>
Previous version: 0.0.3.16
Update State: Failed
Update Error: failed to run update on reboot: expected 0.0.3.17 and got 0.0.3.16
Last modified: 2024-04-16 21:35
GUID: <REDACTED>
Device Flags: • Internal device
• Updatable
• System requires external power source
• Supported on remote server
• Needs a reboot after installation
• Cryptographic hash verification is available
• Device is usable for the duration of the update
$ sudo fwupdmgr get-updates <Device ID>
System Firmware:
Current Version: 0.0.3.16
Update:
New Version: 0.0.3.17
$ sudo fwupdmgr update <Device ID>
Devices with no available firmware updates:
• UEFI Device Firmware
So the get-updates command says there’s an update available, but the update command says that there isn’t?
And there doesn’t seem to be a way to force it to retry the update after a failure; I tried sudo fwupdmgr clear-status <Device ID> and it didn’t seem to do anything.
How do I install this update? Preferably without flashing via a USB drive, as I don’t have one on-hand.
