[RESPONDED] NixOS Fingerprint Sensor undetected
Hey there, I have installed fprintd on my new NixOS machine (Framework 13, intel 11th or 12th gen)
I’ve added the following to my configuration.nix:
services.fwupd.enable = true;
services.fprintd.enable = true;
services.fprintd.tod.enable = true;
services.fprintd.tod.driver = pkgs.libfprint-2-tod1-goodix;
#... System packages section
pkgs.fprintd # installed
but fprintd-enroll gives me the “no compatible devices found” thing. I previously had ubuntu installed, but this is a fresh wipe. What should I do from here?
I obviously rebuilt and switched.
First do a Double check with Fedora 39 Live and Ubuntu 22.04 Live if Fingerprint device is detected or not.
Did you try without the tod?
i forgot to respond to this with my fix. the tod thing did indeed break it; removing the line makes it work.
For anyone stumbling on this thread, all I had to do on NixOS unstable was
  1. import my framework’s nixos-hardware configuration NixOS on the Framework Laptop 13 - Framework Guides
  2. run fprintd-enroll and follow the prompts
