Device: Framework 13 11th Gen i5-1135G7
Distro: Ubuntu 22.04.3
Kernel: 6.1.0-1021-oem
Firmware: 3.17
Hi Community,
Every so often (maybe every hour or so?) my wifi disconnects, and asks me to resubmit my password, or just stays disconnected.
When looking at logs I see the following:
3:20:07 PM wpa_supplicant: WPA: No PMK set for PTK derivation
3:17:46 PM kernel: iwlwifi 0000:aa:00.0: Unhandled alg: 0x703
3:17:17 PM kernel: iwlwifi 0000:aa:00.0: Unhandled alg: 0x703
3:00:02 PM systemd: Failed to start Service for snap application firmware-updater.firmware-notifier.
1:55:45 PM wpa_supplicant: WPA: No PMK set for PTK derivation
12:45:11 PM kernel: iwlwifi 0000:aa:00.0: Unhandled alg: 0x703
12:00:09 PM bluetoothd: profiles/input/hog-lib.c:report_map_read_cb() Report Map read failed: Request attribute has encountered an unlikely error
12:00:07 PM systemd: Failed to start Service for snap application firmware-updater.firmware-notifier.
11:04:09 AM kernel: cros_ec_lpcs cros_ec_lpcs.0: packet too long (65402 bytes, expected 248)
10:48:02 AM gdm-session-wor: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
10:47:59 AM systemd: Failed to start Application launched by gnome-session-binary.
10:47:57 AM gdm-session-wor: gkr-pam: unable to locate daemon control file
10:47:48 AM gnome-session-b: GLib-GIO-CRITICAL: g_bus_get_sync: assertion 'error == NULL || *error == NULL' failed
10:47:47 AM canonical-livep: Task "refresh" returned an error: livepatch check failed: POST request to "https://livepatch.canonical.com/v1/client/68bc786425f54bf3a64289e64bc2eb76/updates" failed, retrying in 30s.
10:47:47 AM bluetoothd: src/device.c:set_wake_allowed_complete() Set device flags return status: Invalid Parameters
10:47:47 AM kernel: ACPI Error: Aborting method \_SB.IETM._OSC due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
10:47:47 AM thermald: Unsupported conditions are present
10:47:46 AM kernel: cros-usbpd-charger cros-usbpd-charger.2.auto: Unexpected number of charge port count
The disconnect happens exactly when that “wpa-supplicant” error hits. Tried searching for this but I don’t get any real results helping me with a solution. Thanks for your time!
