I’m interested in a Framework Laptop 16 (when it releases) and whether firmware updating without Windows is possible is a major factor for me. I have seen that Framework is registered as a firmware vendor on LVFS, but are UEFI & other firmware updates distributed through that channel regularly, and will this be the case for the 16?
They distribute updates for the 13 via LVFS so I would assume the 16 will be the same. Nobody on the forum can give an answer with certainty but it’s a safe bet.
Welcome to forum btw. Most questions you are likely to have can be answered like this one if you use the search function.
Our plan is yes!
