hmm, where is this info from? Panelook, or?
@mxxivcz with reagard to your 15.6 FHD eDP display-if you had to a USB C converter, it wouldnât be the end of the world right?
Yes, Panelook. It would be great if eDP connector on mobo has 4 lanes. Is it possible that the panel in current Frameworks uses just 2 lanes (the resolution is not that too high), but mobo has 4 lanes available?
I was looking a bit more into documentation. In https://github.com/FrameworkComputer/Mainboard/blob/main/Electrical/Pinouts.md there are four EDP_TXP_x / EDP_TXN_x pins.
@ajtakrajta with reagard to your 15.6 FHD eDP display-if you had to a USB C converter, it wouldnât be the end of the world right?
You are right, USB-C convertor would be fine. It can be rather small: https://www.aliexpress.com/item/33046726903.html
I am looking into that possibility and will do some tests isolating 2 of the lanes. @Kieran_Levin itâd be wonderful to have insights on this! Iâm currently working on a custom adapter for the Framework display and trying to grok this specific point.
Weâve done some preliminary software tests on the Framework discord, and it seems the current display does indeed utilize all 4 lanes available. Bummer! I have to get my Framework hardware and see about lane isolation, but Iâm not sure this is as plug&play as PCIe is in that regard, sadly
Does this mean you canât use a lesser resolution display which only uses 2 lanes? I would have though it still would work but you say the display must use all 4 lanes? Thatâs okay if we change out the screen to a higher res options correct?
I do not yet know and Iâd like to check. I havenât had an opportunity to check that yet, sadly. Itâs very likely it will work, but I wouldnât be surprised if we didnât get an image.
If you have the Framework eDP cable, you can use a 40 pin to 30 pin adapter on the other end to force only two lanes to attach. Those are simple adapters and cheap on e.g. eBay.
No. These adapters are between two pinouts: non-touch 30-pin and touch-enabled 30-pin 40-pin, they donât work with the 40-pin high-res pinout that the Framework cable uses.
- if you find one that works with high-res, thatâd be cool. The ones that Iâve seen, donât, and itâs visible if you take a look at how these pinouts are structured.
Youâre right, my bad.
Not sure if any of you are still digging, but I found this:
DIY DisplayPort to eDP passive adapter | deprecated brain dump (wordpress.com)
In regard to this:
Wouldnât it be reasonable to assume that because the DP spec covers detecting connected lanes, that the two ends of the chain have negotiated using all 4 lanes at slower speed since all 4 are available?
Came across this thread on a Google search, thought I would bump just to link to my thread - a 40-pin to 30-pin adapter is absolutely possible: 40pin eDP (Framework/4Lane) to 30pin eDP(2 lane) - #15 by Dylan_Evans
