SD card reader failure
Hi!
I was pretty excited to see the SD card reader was finally shipping! I finally got it today, slammed it in my FW and popped my camera card in to suck those goodies onto my disk.
Well, that was a disappointment. First off, just plugging the card in takes a long time to load the partition table. From the kernel messages:
Nov 22 12:52:38 angela kernel: usb 2-1: new SuperSpeed USB device number 2 using xhci_hcd
Nov 22 12:52:38 angela kernel: usb 2-1: New USB device found, idVendor=32ac, idProduct=0009, bcdDevice= 0.02
Nov 22 12:52:38 angela kernel: usb 2-1: New USB device strings: Mfr=3, Product=4, SerialNumber=2
Nov 22 12:52:38 angela kernel: usb 2-1: Product: SD Expansion Card
Nov 22 12:52:38 angela kernel: usb 2-1: Manufacturer: Framework
Nov 22 12:52:38 angela kernel: usb 2-1: SerialNumber: 000000000002
Nov 22 12:52:39 angela kernel: SCSI subsystem initialized
Nov 22 12:52:39 angela kernel: usb-storage 2-1:1.0: USB Mass Storage device detected
Nov 22 12:52:39 angela kernel: scsi host0: usb-storage 2-1:1.0
Nov 22 12:52:39 angela kernel: usbcore: registered new interface driver usb-storage
Nov 22 12:52:39 angela kernel: usbcore: registered new interface driver uas
Nov 22 12:52:40 angela kernel: scsi 0:0:0:0: Direct-Access     Generic  MassStorageClass 0002 PQ: 0 ANSI: 6
Nov 22 12:52:40 angela kernel: scsi 0:0:0:0: Attached scsi generic sg0 type 0
Nov 22 12:52:41 angela kernel: sd 0:0:0:0: [sda] Spinning up disk...
Nov 22 12:52:44 angela kernel: ..
Nov 22 12:52:46 angela kernel: .ready
Nov 22 12:52:46 angela kernel: sd 0:0:0:0: [sda] 124735488 512-byte logical blocks: (63.9 GB/59.5 GiB)
Nov 22 12:52:46 angela kernel: sd 0:0:0:0: [sda] Write Protect is off
Nov 22 12:52:46 angela kernel: sd 0:0:0:0: [sda] Mode Sense: 21 00 00 00
Nov 22 12:52:46 angela kernel: sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
Nov 22 12:52:46 angela kernel:  sda: sda1
Nov 22 12:52:46 angela kernel: sd 0:0:0:0: [sda] Attached SCSI removable disk
That’s five seconds to load a few kilobytes!!
And the trouble doesn’t stop there. Trying to load thumbs from the card leads to I/O errors:
Nov 22 12:55:47 angela kernel: sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=21s
Nov 22 12:55:47 angela kernel: sd 0:0:0:0: [sda] tag#0 Sense Key : Aborted Command [current]
Nov 22 12:55:47 angela kernel: sd 0:0:0:0: [sda] tag#0 Add. Sense: Incompatible medium installed
Nov 22 12:55:47 angela kernel: sd 0:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 00 00 80 00 00 00 01 00
Nov 22 12:55:47 angela kernel: I/O error, dev sda, sector 32768 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0
Nov 22 12:55:47 angela kernel: Buffer I/O error on dev sda1, logical block 0, lost sync page write
boom. there were a couple of those… e.g.
Nov 22 12:57:25 angela kernel: Buffer I/O error on dev sda1, logical block 5141, lost async page write
Nov 22 12:57:25 angela kernel: Buffer I/O error on dev sda1, logical block 5142, lost async page write
Nov 22 12:57:25 angela kernel: Buffer I/O error on dev sda1, logical block 5143, lost async page write
Nov 22 12:57:28 angela kernel: sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=1s
Nov 22 12:57:28 angela kernel: sd 0:0:0:0: [sda] tag#0 Sense Key : Aborted Command [current]
Nov 22 12:57:28 angela kernel: sd 0:0:0:0: [sda] tag#0 Add. Sense: Data phase CRC error detected
Nov 22 12:57:28 angela kernel: sd 0:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 00 00 94 29 00 00 02 00
Nov 22 12:57:28 angela kernel: I/O error, dev sda, sector 37929 op 0x1:(WRITE) flags 0x100000 phys_seg 2 prio class 0
Nov 22 12:57:28 angela kernel: Buffer I/O error on dev sda1, logical block 5161, lost async page write
Nov 22 12:57:28 angela kernel: Buffer I/O error on dev sda1, logical block 5162, lost async page write
I was kind of terrified: is my SD card dying? It loaded a couple of thumbnails, but was so slow that I aborted everything and just switched to old (and I mean ooold) USB-A/SD card reader, which works “fine” (~16MB/s). I was hoping the new card reader would benefit from the much faster USB-4 bus, but right now it seems to just not be working at all.
Here’s what the SD card looks like when plugged in the other adapter:
Nov 22 13:00:28 angela kernel: usb 3-4: New USB device found, idVendor=0bda, idProduct=0119, bcdDevice=19.81
Nov 22 13:00:28 angela kernel: usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Nov 22 13:00:28 angela kernel: usb 3-4: Product: USB2.0-CRW
Nov 22 13:00:28 angela kernel: usb 3-4: Manufacturer: Generic
Nov 22 13:00:28 angela kernel: usb 3-4: SerialNumber: 20090815198100000
Nov 22 13:00:28 angela kernel: usb-storage 3-4:1.0: USB Mass Storage device detected
Nov 22 13:00:28 angela kernel: scsi host1: usb-storage 3-4:1.0
Nov 22 13:00:53 angela kernel: usb 3-4: new high-speed USB device number 101 using xhci_hcd
Nov 22 13:00:53 angela kernel: usb 3-4: New USB device found, idVendor=0bda, idProduct=0119, bcdDevice=19.81
Nov 22 13:00:53 angela kernel: usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Nov 22 13:00:53 angela kernel: usb 3-4: Product: USB2.0-CRW
Nov 22 13:00:53 angela kernel: usb 3-4: Manufacturer: Generic
Nov 22 13:00:53 angela kernel: usb 3-4: SerialNumber: 20090815198100000
Nov 22 13:00:53 angela kernel: usb-storage 3-4:1.0: USB Mass Storage device detected
Nov 22 13:00:53 angela kernel: scsi host0: usb-storage 3-4:1.0
Nov 22 13:00:54 angela kernel: scsi 0:0:0:0: Direct-Access     Generic- SD/MMC           1.00 PQ: 0 ANSI: 0 CCS
Nov 22 13:00:54 angela kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Nov 22 13:00:55 angela kernel: sd 0:0:0:0: [sda] 124735488 512-byte logical blocks: (63.9 GB/59.5 GiB)
Nov 22 13:00:55 angela kernel: sd 0:0:0:0: [sda] Write Protect is off
Nov 22 13:00:55 angela kernel: sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
Nov 22 13:00:55 angela kernel: sd 0:0:0:0: [sda] No Caching mode page found
Nov 22 13:00:55 angela kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Nov 22 13:00:55 angela kernel:  sda: sda1
Nov 22 13:00:55 angela kernel: sd 0:0:0:0: [sda] Attached SCSI removable disk
The device is detected instantaneously (well, it takes 2 seconds for the whole process, compared to 8 seconds for the FW card reader). On the old SD card reader, i can read off the card with a reliable 16.8MB/s:
anarcat@angela:~$ sudo pv -barte /dev/sda > /dev/null
 132MiO 0:00:08 [16,9MiO/s] [16,6MiO/s] ETA 1:01:09
Note that the first number is instant rate and the second is the average over the whole transfer.
Writing zeros to the card is, of course, slower, but seems to settle around something similar:
anarcat@angela:~[64]$ sudo sh -c "pv -barte /dev/zero > /mnt/test"
2,31GiO 0:00:14 [15,6MiO/s] [ 169MiO/s]
Note that those writes are buffered by the kernel and don’t count the flush time required at umount time, which is why you get that 10x write speed for the average rate: lots of stuff went out to the kernel cache.
Could this be a driver issue?
  • OS: Debian GNU/Linux “stable” (bookworm)
  • Kernel: 6.10 kernel (Linux angela 6.10.11+bpo-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.10.11-1~bpo12+1 (2024-10-03) x86_64 GNU/Linux)
  • Framework 12th gen
Hmm… It looks like I might have experience some connectivity problem: maybe the card wasn’t jacked in all the way correctly?
Because now I tried again, and the performance is stellar. Connect in ~2s:
Nov 22 13:35:14 angela kernel: usb 2-1: new SuperSpeed USB device number 3 using xhci_hcd
Nov 22 13:35:14 angela kernel: usb 2-1: New USB device found, idVendor=32ac, idProduct=0009, bcdDevice= 0.02
Nov 22 13:35:14 angela kernel: usb 2-1: New USB device strings: Mfr=3, Product=4, SerialNumber=2
Nov 22 13:35:14 angela kernel: usb 2-1: Product: SD Expansion Card
Nov 22 13:35:14 angela kernel: usb 2-1: Manufacturer: Framework
Nov 22 13:35:14 angela kernel: usb 2-1: SerialNumber: 000000000002
Nov 22 13:35:14 angela kernel: usb-storage 2-1:1.0: USB Mass Storage device detected
Nov 22 13:35:14 angela kernel: scsi host1: usb-storage 2-1:1.0
Nov 22 13:35:15 angela kernel: usb 3-4: USB disconnect, device number 101
Nov 22 13:35:15 angela kernel: scsi 1:0:0:0: Direct-Access     Generic  MassStorageClass 0002 PQ: 0 ANSI: 6
Nov 22 13:35:15 angela kernel: sd 1:0:0:0: Attached scsi generic sg0 type 0
Nov 22 13:35:15 angela kernel: sd 1:0:0:0: [sda] 124735488 512-byte logical blocks: (63.9 GB/59.5 GiB)
Nov 22 13:35:15 angela kernel: sd 1:0:0:0: [sda] Write Protect is off
Nov 22 13:35:15 angela kernel: sd 1:0:0:0: [sda] Mode Sense: 21 00 00 00
Nov 22 13:35:15 angela kernel: sd 1:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
Nov 22 13:35:16 angela kernel:  sda: sda1
Nov 22 13:35:16 angela kernel: sd 1:0:0:0: [sda] Attached SCSI removable disk
Transfer rate is basically gigabit:
5,75GiO 0:01:04 [92,5MiO/s] [92,1MiO/s] ETA 0:09:57
Writing is slower, closer to the other reader, probably the SD card limits there:
anarcat@angela:~$ sudo sh -c "pv -barte /dev/zero > /mnt/test"
21,3GiO 0:04:52 [83,7MiO/s] [74,6MiO/s]
If you encounter any more issues, I would recommend reaching out to Framework Support as if there really is a hardware issue, they may be able to provide you a free replacement.
I’m slowly connecting the docs here. I have found a similar issue with the storage card which at first I mapped to the storage card itself, completely forgetting i have had this issue here with the SD card, but also with a USB-A card, see [SOLVED] USB-A Expansion Card stops working until unplugged - #14 by anarcat.
Further tests show the problems might be specific with this one port, and i’m in a conversation with support about how to fix that, stay tuned!
have you ever figured out what was the issue? i’m seeing the same error messages (google led me here) with specific SD Cards. i’ve tried two different SanDisk Extreme 32GB (which are confirmed working in another device) and both throw these errors every time i connect them and are unusable. however any other card i’ve tried, even in the same SD-microSD adapter worked without issues (i’ve tried two different Kingston Industrial cards and one Samsung Ultimate PRO card). so it seems like a compatibility issue?
attaching a portion of dmesg output for reference
[86398.334189] usb 2-3: new SuperSpeed USB device number 16 using xhci_hcd
[86398.348454] usb 2-3: New USB device found, idVendor=32ac, idProduct=0009, bcdDevice= 0.02
[86398.348467] usb 2-3: New USB device strings: Mfr=3, Product=4, SerialNumber=2
[86398.348472] usb 2-3: Product: SD Expansion Card
[86398.348475] usb 2-3: Manufacturer: Framework
[86398.348478] usb 2-3: SerialNumber: 000000000002
[86398.350063] usb-storage 2-3:1.0: USB Mass Storage device detected
[86398.350883] scsi host0: usb-storage 2-3:1.0
[86399.203157] ucsi_acpi USBC000:00: unknown error 0
[86399.203173] ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
[86399.367924] scsi 0:0:0:0: Direct-Access     Generic  MassStorageClass 0002 PQ: 0 ANSI: 6
[86399.945746] sd 0:0:0:0: [sda] 62309376 512-byte logical blocks: (31.9 GB/29.7 GiB)
[86399.946463] sd 0:0:0:0: [sda] Write Protect is off
[86399.946475] sd 0:0:0:0: [sda] Mode Sense: 21 00 00 00
[86399.947118] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[86400.040679]  sda: sda1 sda2 sda3
[86400.041182] sd 0:0:0:0: [sda] Attached SCSI removable disk
[86400.052968] scsi_io_completion_action: 3 callbacks suppressed
[86400.052983] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[86400.052994] sd 0:0:0:0: [sda] tag#0 Sense Key : Aborted Command [current]
[86400.052999] sd 0:0:0:0: [sda] tag#0 Add. Sense: Data phase CRC error detected
[86400.053005] sd 0:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 00 00 00 08 00 00 08 00
[86400.053008] blk_print_req_error: 27 callbacks suppressed
[86400.053011] I/O error, dev sda, sector 8 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[86400.151101] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[86400.151116] sd 0:0:0:0: [sda] tag#0 Sense Key : Aborted Command [current]
[86400.151123] sd 0:0:0:0: [sda] tag#0 Add. Sense: Data phase CRC error detected
[86400.151129] sd 0:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 00 00 00 08 00 00 08 00
[86400.151134] I/O error, dev sda, sector 8 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[86400.151149] buffer_io_error: 8 callbacks suppressed
[86400.151152] Buffer I/O error on dev sda, logical block 1, async page read
[86400.450258] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[86400.450269] sd 0:0:0:0: [sda] tag#0 Sense Key : Aborted Command [current]
[86400.450273] sd 0:0:0:0: [sda] tag#0 Add. Sense: Data phase CRC error detected
[86400.450276] sd 0:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 00 01 30 00 00 00 08 00
[86400.450279] I/O error, dev sda, sector 77824 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[86400.542245] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[86400.542262] sd 0:0:0:0: [sda] tag#0 Sense Key : Aborted Command [current]
[86400.542269] sd 0:0:0:0: [sda] tag#0 Add. Sense: Data phase CRC error detected
[86400.542275] sd 0:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 00 01 30 00 00 00 08 00
[86400.542279] I/O error, dev sda, sector 77824 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[86400.542296] Buffer I/O error on dev sda2, logical block 0, async page read
[86400.560347] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[86400.560355] sd 0:0:0:0: [sda] tag#0 Sense Key : Aborted Command [current]
[86400.560358] sd 0:0:0:0: [sda] tag#0 Add. Sense: Data phase CRC error detected
[86400.560362] sd 0:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 00 00 50 00 00 00 08 00
[86400.560364] I/O error, dev sda, sector 20480 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[86400.649818] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[86400.649833] sd 0:0:0:0: [sda] tag#0 Sense Key : Aborted Command [current]
[86400.649839] sd 0:0:0:0: [sda] tag#0 Add. Sense: Data phase CRC error detected
[86400.649845] sd 0:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 00 00 50 00 00 00 08 00
[86400.649849] I/O error, dev sda, sector 20480 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[86400.649864] Buffer I/O error on dev sda1, logical block 512, async page read
[86400.677251] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[86400.677258] sd 0:0:0:0: [sda] tag#0 Sense Key : Aborted Command [current]
[86400.677261] sd 0:0:0:0: [sda] tag#0 Add. Sense: Data phase CRC error detected
[86400.677264] sd 0:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00
[86400.677266] I/O error, dev sda, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[86400.767303] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[86400.767320] sd 0:0:0:0: [sda] tag#0 Sense Key : Aborted Command [current]
[86400.767360] sd 0:0:0:0: [sda] tag#0 Add. Sense: Data phase CRC error detected
[86400.767368] sd 0:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 00 00 00 00 00 00 08 00
[86400.767373] I/O error, dev sda, sector 0 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[86400.767388] Buffer I/O error on dev sda, logical block 0, async page read
What do you have plugged into each expansion slot?
Do you have the FW13 Intel 12th or some other model?
it’s a FW12 (sorry i know this is a FW13 thread but the error i have is identical so i gave it a try anyway), i’ve tried all 4 expansion slots and they behave identically (as i’d expect considering the FW12 doesn’t have significant differences in features between the ports)
so far, the conclusion with support has been that the port itself is buggy, possibly the entire board, which would require swapping out the board. and, indeed, i see the problem with other devices, and not on other ports.
now, if it happens on all ports, it might more likely be an issue with the card. try another card?
i have :slight_smile: it’s linked to a specific SD card model for me, multiple (otherwise known good) cards of the same model (SanDisk Extreme) don’t work and every other card i have works. if it was a hardware issue and not compatibility issue for you i’ll have to assume my is a different problem that just happens to manifest in the same errors being logged
