Hardware & OS Environment:
Machine: Framework Laptop 13 AMD Ryzen AI 5 340
OS: openSUSE Leap 16.0 (KDE Plasma with Wayland)
Configuration: Secureboot disabled
Issue:
When I perform a clean installation of openSUSE Leap 16.0, the laptop shuts down and reboots perfectly. Immediately after applying the initial system updates (via zypper up or “Update all” in the Discover GUI), the machine has issues with reboot and power off.
When initiating a shutdown or reboot, the screen goes black, but the keyboard remains backlit and the machine continues drawing power. It requires a hard reset via the physical power button every time.
Troubleshooting already performed (failed):
I removed the quiet and splash kernel parameters to monitor the raw shutdown output. The logs confirm that this is not a hung application or a stalled systemd service. User-space termination is completely clean:
systemdsuccessfully stops all services. -
All filesystems, loop devices, and block devices are successfully unmounted and detached.
The absolute final message printed to the screen is:
systemd-shutdown[1]: Powering off.
The deadlock occurs precisely at the reboot(RB_POWER_OFF) system call, where the updated kernel fails to execute the ACPI handoff to the motherboard to cut power.
Initramfs: Rebuilt the initial RAM filesystem using
dracut -f --regenerate-all. -
ACPI Parameters: Appended
acpi=forceto the GRUB boot line. -
SELinux: Placed SELinux into permissive mode (
enforcing=0) to bypass a minor Plymouth AVC search denial observed in the shutdown logs. -
Plymouth: Completely disabled the splash daemon at the kernel level using
plymouth.enable=0.
Are any other Ryzen AI 300 series users experiencing this regression on recent kernels, and are there any specific AMD scatter-gather or MediaTek driver workarounds recommended for this current build?
Thank you
