Six month Review
Hey guys, I wanted to give a six-month review of my experience with the Framework 13, so here it goes. I was fortunate to receive the Framework as a Christmas and birthday present from my parents. Originally, I would have gotten a laptop for graduation, but since the Framework is upgradeable, I ended up receiving it early and have absolutely loved it for the past few months. Here’s my configuration:
  • Ryzen 5 7640u
  • 2x8GB Crucial CT2K8G56C46S5 RAM (16GB, which is fine for my needs as I’m not doing anything too demanding)
  • SX Hynix P41 Platinum 1TB SSD
  • 2x USB-C expansion cards
  • 1x USB-A expansion card
  • 1x HDMI 3rd gen expansion card
  • 1 extra USB-A expansion card (not in the laptop)
  • Bought the Framework charger
  • Running Windows 11
My workload admittedly isn’t super taxing; I use G Suite for school work—Google Drive, Google Docs, Gmail, etc. I also watch YouTube and listen to Spotify primarily with earbuds. Since graduating high school, I mainly use the Framework for general web browsing and media consumption. I’ve also made some software tweaks that addressed a few of my initial concerns about the Framework (which I’ll touch on later).
Pros:
Screen: I love the screen; it’s extremely bright compared to my Chromebook, and it’s nice and sharp. The 16:10 aspect ratio is perfect for schoolwork, especially for reading PDFs. Although it’s not touchscreen, which I initially wished for, knowing that it’s a Framework means there’s always the option to upgrade. For people like me who use it for schoolwork or non-gaming activities, the stock screen is accurate and ideal.
Keyboard: The keyboard is fantastic and very comfortable to type on. Initially, I mentioned in my review that the F12 key couldn’t be remapped, but a community tool now allows for remapping. I currently have mine set to open the task manager.
Physical shutoff switches for camera and mic: These are excellent for privacy and battery life, as I frequently disable the camera and mic.
Performance: Performance has been great with no noticeable fan noise or heat output. The only hiccup I encountered was when running a modded version of NCAA 14 through RPCS3; otherwise, it handles everything else smoothly.
Build quality: The build quality is top-notch, and the laptop feels sturdy. Being disabled, I’m quite tough on my tech, and the Framework has held up beautifully, aside from a few scratches on the bottom cover. The great thing is that if something breaks, I can easily replace it.
Battery life: I average about 7-9 hours daily, which was a pleasant surprise. I was initially concerned about battery life due to accessibility issues with outlets (since I’m in a wheelchair), but so far, it hasn’t been an issue. I even bought a 65W 24,000 mAh battery bank, but I rarely need to use it.
Cons:
  • I initially encountered an occasional Watchdog blue screen error, which has been resolved with a new BIOS update.
  • There’s a slight screen wobble, which doesn’t bother me much but might annoy others.
  • Removing the expansion cards can be tricky; they haven’t loosened up much over six months, though I don’t swap them frequently.
  • There are only 4 expansion ports; however, new options like Josh Cook’s dual USB-C card are becoming available.
  • The lack of a touchscreen remains my biggest pain point. A touchscreen would greatly enhance usability, especially for someone like me. I was hoping one would be available by now.
  • Initially, there was no full-size SD card reader expansion card, but that’s no longer the case, and I plan to order it when it’s in stock.
  • The absence of a numpad, while not a big deal, would have been a nice addition.
Battery life optimizations: Here are a few things I did to maximize battery life:
  • Keep camera & mic disabled and enable them only when needed.
  • Keep Bluetooth off and turn it on only when necessary.
  • Keep keyboard backlight off unless needed.
  • Set the power LED to the dimmest setting in the BIOS.
  • Set the iGPU to auto in the BIOS.
  • Keep Windows battery saver on all the time.
  • Set the laptop to best battery life mode.
  • Minimize startup apps.
  • Keep screen brightness between 0-25%, as even the lowest setting is bright enough.
  • Set hibernate to start when the lid is closed to avoid battery drain.
Sound/AirPods: If you’re experiencing issues with AirPods on Windows 11, disabling the AirPods mic in Windows settings can resolve frequent disconnection problems. Additionally, using the FX Sound app with a specific sound profile can significantly enhance speaker performance.
Conclusion: I love this laptop and plan to use it as my daily driver for years to come. I don’t have many complaints aside from the minor ones listed above. I feel extremely fortunate to have received this as a gift and appreciate it greatly. Moving forward, my biggest hopes are for Framework to release a version with a navy blue bezel and touchscreen. If they could make that happen, it would be the ultimate upgrade for me. If you have any questions, feel free to ask!
Just a small correction, the FW 13 is 3:2 and not 16:10. I’m glad you are enjoying the laptop! I use mine for schoolwork as well
Other than the Chromebook, what other devices do you have end-user experience with as a baseline expectation / comparison for a 2023/2024 purchase?
Can you describe “I’m quite tough on my tech” in details? (People can be tough on tech, with or without disability. Want to get a sense of what ‘quite tough’ is from your perspective.).
Thank you for sharing it here as well!
This setting allocates RAM for the iGPU, does it affect battery life?
Everything else is a matter of opinion that many might agree with you, but this one…how would this even be possible in the size category…I mean you would need some seriously tiny hands for it to be usable. The cut off has been 15.6 or now 16 inch display laptops. In a FW13 it would be pretty ludicrous.
There is nowhere near enough space to have a numpad with any normal layout on a laptop the size of the Framework Laptop 13. The Framework Laptop 16 has an optional numpad (and even that uses a 10% narrower than standard numpad).
I suppose a numpad could be below the keyboard (alongside the trackpad), but that would be highly unusual and not something I’ve seen.
Afaik that should not have any effect on battery life, just memory management.
With 16 GB total ram setting it to auto means that 7.75 GB of the ram is dedicated exclusively to the CPU, 0.5 GB is dedicated exclusively to the iGPU, and 7.75 GB is dynamically allocated between the two depending on where it is needed.
With 16 GB total ram setting it to game optimized mode means that 7 GB of the ram is dedicated exclusively to the CPU, 2 GB is dedicated exclusively to the iGPU, and 7 GB is dynamically allocated between the two depending on where it is needed.
IMO the name of the setting is terrible. The setting exists because some programs (mainly older games and AI tools) cannot handle using the dynamically allocated iGPU ram and only use the dedicated iGPU ram. The setting makes it possible to increase the amount that is dedicated exclusively to the iGPU (to an amount that is high enough for the old games that can’t handle the dynamic ram, but not enough for the AI tools).
I am hopeful that future Windows versions bring more seamless handling of the dynamically allocated memory (like Linux has done in 6.10) and make that setting obsolete.
Yup my bad about the aspect ratio, I think I got the 16’s ratio mixed up with the 13 but either way it’s great for school!
Other than the Chromebook, I haven’t had a laptop in quite a few years. I received a Lenovo Yoga laptop from my parents around 2016, and I suspect it came with a bad HDD because it was super slow. Not knowing anything about tech, I didn’t know how to fix the laptop, so I started learning about building PCs and built my first PC in 2017 (i5-6600K & an RX 480). Then a couple of years later, I did a full system rebuild of everything except the RAM and GPU (I was too broke to afford a new GPU). Right now, it’s running a 12600K. I thought about upgrading the GPU, but I’m going off to college soon and not bringing my PC with me, so I got the FW.
As for being tough on tech, I broke one of the hinges on that Lenovo when it fell off a desk. I regularly drop my phone about 15 times a day. I’ve accidentally run over my phone with my wheelchair a couple of times. I’ve dropped my iPad and cracked a few different screen protectors. My chair has a USB port with a phone charger plugged into it, and I’ve gone through about 15-20 chargers in 2-3 years. The chargers break when I forget to tie them up, and they get run over by my chair. As for the FW, I’m not super careful with it, so it’s got a couple of scratches on the underside.
@Kyle_Reis @Charlie_6 I don’t really know if it does but I saw it on a FW battery management post so I decided why not?
Well, they are very close, while the 13" is 3:2, the 16" at 16:10 is 3.2:2, so almost the same ratio.
@nadb @Kyle_Reis as for the numpad i’m talking about maybe something like this?
