Small power bank solves an 11th gen 13 laptop problem
Hello community,
If you are having the same problem with powering on the 11th gen 13 laptop, I have discovered a solution. A small portable power bank can power on the laptop if you are nowhere near electricy. The same power bank and type C coil that charges your phone can power on the laptop. Because I cannot return the laptop to Framework, this power bank solution is a marvelous discovery and I am glad I tested the thought that came to my mind----“try the power bank ans see.”
Good idea. The problem isnt as bad as it was 18 months ago. Back then you had to take the whole machine apart to get it working again. Now, apply power, reset the clock and away you go.
