Curious if any one running Steam on a Framework Windows. I am trying with an external monitor and have not found the secret sauce.
Absolutely running it. It works great.
I do notice, as I use workspaces, that when I come back the UI does not update. You have to move between the Store and Library to correct it. Seems like a redraw isn’t being triggered because of changing the workspace.
But with regard to your question, what seems to be the problem?
keep getting an error message that says Graphics device does not meet the application’s minimum specs? Running Windows 11
Nevermind it was the Intel drivers… Sorry for clogging up the chat.
It’s all good, Imma edit your title to mark this as solved! Glad it’s working now
