Hello. I’ve just had a fresh install of Garuda Linux (240428) (which is based on Arch) on My FW16 with Bios 3.03.
I’ve noticed that The 7700S has a driver installed (cause its the same as the iGPU) but is not recognized. I’ve installed GOverlay and Mangohud, and even reinstalled the linux-video, and that worked for like, one session only. So I’m quite confused…
Pre-Reinstall, I had Garuda installed BEFORE the 3.03 bios update, and did said bios update in said install, and it worked mostly fine (primarily, ALVR+SteamVR now had issues) so now that I’ve freshly installed this OS, I’m at a loss…
Some logs~
inxi -g
Graphics:
Device-1: AMD Navi 33 [Radeon RX 7600/7600 XT/7600M XT/7600S/7700S / PRO
W7600] driver: amdgpu v: kernel
Device-2: AMD Phoenix1 driver: amdgpu v: kernel
Device-3: Realtek Laptop Camera driver: uvcvideo type: USB
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1
compositor: kwin_wayland driver: X: loaded: amdgpu
unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu,amdgpu
resolution: 2133x1333
API: EGL v: 1.5 drivers: radeonsi,swrast
platforms: wayland,x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.4-arch1.2
renderer: AMD Radeon 780M (radeonsi gfx1103_r1 LLVM 18.1.8 DRM 3.57
6.10.1-zen1-1-zen)
API: Vulkan v: 1.3.279 drivers: radv,llvmpipe surfaces: xcb,xlib,wayland
vulkaninfo --summary
ERROR: [../mesa-24.1.4/src/amd/vulkan/radv_physical_device.c:1938] Code 0 : Could not open device /dev/dri/renderD128: Invalid argument (VK_ERROR_INCOMPATIBLE_DRIVER)
VULKANINFO
Vulkan Instance Version: 1.3.279
Instance Extensions: count = 24
VK_EXT_acquire_drm_display : extension revision 1
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 10
VK_EXT_debug_utils : extension revision 2
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_EXT_headless_surface : extension revision 1
VK_EXT_surface_maintenance1 : extension revision 1
VK_EXT_swapchain_colorspace : extension revision 4
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 23
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities : extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2 : extension revision 2
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_portability_enumeration : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities : extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
VK_LUNARG_direct_driver_loading : extension revision 1
Instance Layers: count = 13
VK_LAYER_AEJS_DeviceChooserLayer Device chooser layer 1.3.0 version 1
VK_LAYER_ALVR_capture ALVR display intercept layer 1.0.68 version 1
VK_LAYER_FROG_gamescope_wsi_x86_64 Gamescope WSI (XWayland Bypass) Layer (x86_64) 1.3.221 version 1
VK_LAYER_INTEL_nullhw INTEL NULL HW 1.1.73 version 1
VK_LAYER_MANGOAPP_overlay Mangoapp Layer 1.3.0 version 1
VK_LAYER_MANGOHUD_overlay_x86_64 Vulkan Hud Overlay 1.3.0 version 1
VK_LAYER_MESA_device_select Linux device selection layer 1.3.211 version 1
VK_LAYER_MESA_overlay Mesa Overlay layer 1.3.211 version 1
VK_LAYER_VALVE_steam_fossilize_32 Steam Pipeline Caching Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_fossilize_64 Steam Pipeline Caching Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_overlay_32 Steam Overlay Layer 1.3.207 version 1
VK_LAYER_VALVE_steam_overlay_64 Steam Overlay Layer 1.3.207 version 1
VK_LAYER_VKBASALT_post_processing a post processing layer 1.3.223 version 1
Devices:
GPU0:
apiVersion = 1.3.278
driverVersion = 24.1.4
vendorID = 0x1002
deviceID = 0x15bf
deviceType = PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
deviceName = AMD Radeon 780M (RADV GFX1103_R1)
driverID = DRIVER_ID_MESA_RADV
driverName = radv
driverInfo = Mesa 24.1.4-arch1.2
conformanceVersion = 1.3.0.0
deviceUUID = 00000000-c500-0000-0000-000000000000
driverUUID = 414d442d-4d45-5341-2d44-525600000000
GPU1:
driverVersion = 0.0.1
vendorID = 0x10005
deviceID = 0x0000
deviceType = PHYSICAL_DEVICE_TYPE_CPU
deviceName = llvmpipe (LLVM 18.1.8, 256 bits)
driverID = DRIVER_ID_MESA_LLVMPIPE
driverName = llvmpipe
driverInfo = Mesa 24.1.4-arch1.2 (LLVM 18.1.8)
conformanceVersion = 1.3.1.1
deviceUUID = 6d657361-3234-2e31-2e34-2d6172636800
driverUUID = 6c6c766d-7069-7065-5555-494400000000
lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e8
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Device 14e9
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14ea
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14ed
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14ed
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14ea
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14ee
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14ee
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14ea
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 19h USB4/Thunderbolt PCIe tunnel
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14ea
00:04.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 19h USB4/Thunderbolt PCIe tunnel
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14ea
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14eb
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14eb
00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14eb
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 71)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f7
01:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 XL Upstream Port of PCI Express Switch (rev 12)
02:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 XL Downstream Port of PCI Express Switch (rev 12)
03:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Navi 33 [Radeon RX 7600/7600 XT/7600M XT/7600S/7700S / PRO W7600] (rev c1)
03:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Navi 31 HDMI/DP Audio
04:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. OM3PDP3 NVMe SSD (rev 01)
05:00.0 Network controller: MEDIATEK Corp. MT7922 802.11ax PCI Express Wireless Network Adapter
06:00.0 Non-Volatile memory controller: SK hynix Platinum P41/PC801 NVMe Solid State Drive
c5:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Phoenix1 (rev c2)
c5:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Rembrandt Radeon High Definition Audio Controller
c5:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 19h (Model 74h) CCP/PSP 3.0 Device
c5:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15b9
c5:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15ba
c5:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 63)
c5:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
c6:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 14ec
c6:00.1 Signal processing controller: Advanced Micro Devices, Inc. [AMD] AMD IPU Device
c7:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 14ec
c7:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15c0
c7:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15c1
c7:00.5 USB controller: Advanced Micro Devices, Inc. [AMD] Pink Sardine USB4/Thunderbolt NHI controller #1
c7:00.6 USB controller: Advanced Micro Devices, Inc. [AMD] Pink Sardine USB4/Thunderbolt NHI controller #2
glxinfo | grep 'OpenGL Renderer'
OpenGL renderer string: AMD Radeon 780M (radeonsi, gfx1103_r1, LLVM 18.1.8, DRM 3.57, 6.10.1-zen1-1-zen)
glxinfo -B
name of display: :1
display: :1 screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
Vendor: AMD (0x1002)
Device: AMD Radeon 780M (radeonsi, gfx1103_r1, LLVM 18.1.8, DRM 3.57, 6.10.1-zen1-1-zen) (0x15bf)
Version: 24.1.4
Accelerated: yes
Video memory: 2048MB
Unified memory: no
Preferred profile: core (0x1)
Max core profile version: 4.6
Max compat profile version: 4.6
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.2
Memory info (GL_ATI_meminfo):
VBO free memory - total: 648 MB, largest block: 648 MB
VBO free aux. memory - total: 29922 MB, largest block: 29922 MB
Texture free memory - total: 648 MB, largest block: 648 MB
Texture free aux. memory - total: 29922 MB, largest block: 29922 MB
Renderbuffer free memory - total: 648 MB, largest block: 648 MB
Renderbuffer free aux. memory - total: 29922 MB, largest block: 29922 MB
Memory info (GL_NVX_gpu_memory_info):
Dedicated video memory: 2048 MB
Total available memory: 33093 MB
Currently available dedicated video memory: 648 MB
OpenGL vendor string: AMD
OpenGL core profile version string: 4.6 (Core Profile) Mesa 24.1.4-arch1.2
OpenGL core profile shading language version string: 4.60
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL version string: 4.6 (Compatibility Profile) Mesa 24.1.4-arch1.2
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 24.1.4-arch1.2
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
mhwd -l # Same as Settings Manager -> Hardware Configuration or Driver Manager
> 0000:03:00.0 (0300:1002:7480) Display controller ATI Technologies Inc:
NAME VERSION FREEDRIVER TYPE
video-linux 2021.08.29 true PCI
video-modesetting 2020.07.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:c5:00.0 (0300:1002:15bf) Display controller ATI Technologies Inc:
Simple Tests I’ve installed vkdevicechooser which is a utility that lets you specify which GPU you want to use on a program. It’s similar to DRI_PRIME
ENABLE_DEVICE_CHOOSER_LAYER=1 VULKAN_DEVICE_INDEX=0 vkcube
Using Vulkan device index 0
Selected GPU 0: AMD Radeon 780M (RADV GFX1103_R1), type: IntegratedGpu
ENABLE_DEVICE_CHOOSER_LAYER=1 VULKAN_DEVICE_INDEX=1 vkcube
Using Vulkan device index 1
Selected GPU 0: llvmpipe (LLVM 18.1.8, 256 bits), type: Cpu
Any help would be greatly appreciated.
