You somehow enabled the metrics overlay. IIRC it can be disabled under Performance → Settings in AMD’s software.
Thanks
Since I have not played with that feature I have no idea how it was activated but now I know how to shut it down I’m very happy!!!
Maybe it’s using the same hotkeys as some other software, so you inadvertently activated it that way.
