[SOLVED] Really disappointed in the battery - 1360p
1360p, WD 1TB SSD (SN850X), 32GB Memory (Recommended Corsair sticks). 3x USB-C, 1x USB-A
Ubuntu 23.04 w/ recommended framework patches, TLP, sleep mode set to deep.
Coming from a Macbook Pro and a work XPS 15, where I’ve been very used to not thinking about battery, and just shutting the lid (even in Linux on the XPS).
The framework seems to have dropped about 40% in sleep over a period of 18 hours. I’ve been writing this post and seen it drop two percent, it dropped another 3 in the 15 minutes beforehand.
Have I got a faulty unit, or is battery management terrible? I haven’t had to think about battery use in about 8 years in the Mac world, it really stings to have to watch it like a hawk and bring a charger.
I want to love this thing - the screen is great, as is the form factor, keyboard, expansion, mouse, general ethos. The battery life feels like being plunged back a decade though - Is this the normal? If so, it needs to go back!
EDIT: Sat here at 25% brightness, only chrome open with this single tab, UPower is showing 10.85W drain, which feels rather high, given the backlight is too dim for sensible use.
Counter intuitive maybe, but does the 13gen CPU “support” this? What happens with s2idle instead?
That’s crazy high, what does powertop blame?
Seeing the following in powertop
Summary: 733.1 wakeups/second,  0.0 GPU ops/seconds, 0.0 VFS ops/sec and 22.1% C
                Usage       Events/s    Category       Description
              3.3 ms/s     199.2        Timer          tick_sched_timer
              3.7 ms/s     195.2        Interrupt      [43] idma64.2
             73.9 ms/s      91.7        Interrupt      [14] INTC1055:00
              8.4 ms/s      55.0        Process        [PID 24741] /opt/google/c
            545.2 µs/s      24.0        Process        [PID 15] [rcu_preempt]
              1.9 ms/s      22.6        Timer          hrtimer_wakeup
             31.8 ms/s       9.3        Process        [PID 2823] /usr/bin/gnome
             30.9 ms/s       9.4        kWork          intel_atomic_commit_work
              1.8 ms/s      18.1        Interrupt      [181] i915
            121.9 µs/s       9.7        kWork          psi_avgs_work
             23.1 ms/s       0.4        Process        [PID 277] [irq/164-PIXA38
            215.2 µs/s       9.2        kWork          intel_atomic_cleanup_work
             17.2 µs/s       6.3        kWork          intel_atomic_helper_free_
For comparison here’s my 11th gen. I don’t even run TLP on this machine. I’m not sure what to suggest, things I’d look into on your machine is what is related to idma64.2 and especially INTC1055:00.
The battery reports a discharge rate of 6.26 W
The energy consumed was 126 J
The estimated remaining time is 7 hours, 21 minutes
Summary: 411.9 wakeups/second,  0.0 GPU ops/seconds, 0.0 VFS ops/sec and 10.6% CPU use
              3.2 ms/s     229.7        Timer          tick_sched_timer
             39.4 ms/s       9.4        Process        [PID 2731] /usr/bin/gnome-shell
            484.6 µs/s      24.4        Process        [PID 16] [rcu_preempt]
            130.6 µs/s      17.0        kWork          psi_avgs_work
            670.2 µs/s      11.2        Timer          hrtimer_wakeup
             86.9 µs/s      10.6        kWork          engine_retire
             13.0 ms/s       4.4        Process        [PID 3851] /usr/bin/tilix --gapplication-service
             30.4 µs/s       9.4        kWork          toggle_allocation_gate
             14.6 ms/s       3.6        Process        [PID 11526] /usr/lib64/firefox/firefox
             23.6 µs/s       8.8        kWork          rps_work
            547.0 µs/s       8.4        Interrupt      [145] i915
            315.5 µs/s       6.1        Interrupt      [0] HI_SOFTIRQ
             12.1 ms/s      0.15        Process        [PID 15046] /usr/lib64/firefox/firefox -contentproc -childID 15 -isForBrowser -prefsLen 32569 -prefMapSize 247730 -jsInitLen 23
              2.0 ms/s       3.9        Process        [PID 1396] /usr/lib/systemd/systemd-oomd
             86.3 µs/s       4.4        kWork          __intel_wakeref_put_work
             80.3 µs/s       4.4        kWork          intel_atomic_cleanup_work
              0.0 µs/s       4.3        kWork          intel_atomic_commit_work
            327.8 µs/s       2.9        Process        [PID 15055] /usr/lib64/firefox/firefox -contentproc -childID 15 -isForBrowser -prefsLen 32569 -prefMapSize 247730 -jsInitLen 23
            293.2 µs/s       2.8        kWork          kcryptd_crypt
            189.6 µs/s       2.5        kWork          __i915_gem_free_work
             11.8 µs/s       2.5        Interrupt      [6] tasklet(softirq)
             61.3 µs/s       2.1        Interrupt      [142] nvme0q5
             15.6 µs/s       2.0        kWork          intel_display_power_put_async_w
             23.2 µs/s       1.9        Process        [PID 69] [kcompactd0]
              0.8 ms/s       1.5        Process        [PID 1430] /usr/libexec/iio-sensor-proxy
             16.4 µs/s       1.8        Timer          watchdog_timer_fn
You might be on to something there - thanks.
Both of those are touchpad interrupts - discussed over here.
It sounds like this may be the source of the issue while awake, which is great as presumably its fixable (although that thread hasn’t been touched bar me in 2 months), which will help at least with the wake power consumption.
Having not really done anything with the device other than write these couple of posts, I’m now down at 16% having slept overnight, which seems pretty unusable.
Looks like 23.04 is not officially supported. Have you tried 22.04?
Hi @Bdav,
Do try s2idle for suspend, reboot.
What expansion modules do you have installed? Are they older gen modules or new/firmware upgraded?
Many thanks for the response - have udpated to s2idle in grub config, updated, rebooted and it appears as the default in mem_sleep now so will see what happens overnight.
Nothing much to speak of on the expansions - 3x USB-C and 1x USB-A, not connected to anything else.
Hi there I have the 12th gen Ubuntu 22.04 and the idle works like a charm from day one. I never power off the computer, and when its unplugged I get it in the morning maybe with 5 or 10% less, unsure exactely but its very acceptable.
Today I have been using it uplugged at a meeting, working for maybe one hour on the go…and back at hotel It says 4 hours left.
Its pretty consistent I get 5 hours ish battery.
Now running kernel 6.1 OEM thingy
6.1.0-1013-oem
Ha yes, western digital seams a prety bad option with bugs , don t understand why they are using it. Got a samsung and no problems there
Made the changes as suggested by @Matt_Hartley , as well as removing the USB-A - We’re looking a lot lot better now:
 ~  python3 /opt/batterylog/batterylog.py                                  ✔
Slept for 10.03 hours
Used 3.44 Wh, an average rate of 0.34 W
At 0.34/Wh drain you battery would be empty in 144.60 hours
For your 60.25 Wh battery this is 0.57%/hr or 13.65%/day
I will try again with the USB-A in and see if I get similar!
Many thanks for the pointers.
Similar time, with USB-A also in. Negligible difference (i.e. still acceptable drain) - many thanks!
I suspect deep sleep isn’t (well) supported on the 13th gen.
Slept for 10.58 hours
Used 3.61 Wh, an average rate of 0.34 W
At 0.34/Wh drain you battery would be empty in 145.13 hours
For your 60.25 Wh battery this is 0.57%/hr or 13.58%/day
As a point of comparison:
$ cat /sys/power/mem_sleep
[s2idle] deep
$ /opt/batterylog/batterylog.py
Slept for 13.05 hours
Used 8.62 Wh, an average rate of 0.66 W
At 0.66/Wh drain you battery would be empty in 67.65 hours
For your 53.47 Wh battery this is 1.24%/hr or 29.67%/day
System summary:
CPU: 12-core (4-mt/8-st) 12th Gen Intel Core i7-1260P (-MST AMCP-)
speed/min/max: 2209/400/4700:3400 MHz Kernel: 6.1.0-1014-oem x86_64
Up: 1d 51m Mem: 3791.9/31801.0 MiB (11.9%) Storage: 1.83 TiB (18.1% used)
Procs: 432 Shell: Sudo inxi: 3.3.13
Expansion modules: 1 x USB-A, 1 x USB-C, 1 x microSDXC and 1 x 1 TB.
Dino
@truffaldino I’d be interested to see yours without the cards.
This would be an interesting comparable for sure.
Think this can be marked as resolved. Unless we’re still really disappointed.
For battery drain numbers, maybe head over here:
As a comparison for you @Bdav
My framework is 13th Gen 1340p, 32GB RAM. 3 x USB C and 1 x USB A. I’m on Fedora 38.
Slept for 12.96 hours
Used 5.00 Wh, an average rate of 0.39 W
At 0.39/Wh drain you battery would be empty in 49.16 hours
For your 54.84 Wh battery this is 0.70%/hr or 16.90%/ day
Alright, consensus is to mark this solved?
Yesterday presented the first opportunity I’ve had to remove all cards and close the lid for a meaningful amount of time.
$ inxi
speed/min/max: 2183/400/4700:3400 MHz Kernel: 6.1.0-1014-oem x86_64
Up: 2d 18h 53m Mem: 2828.2/31801.0 MiB (8.9%)
Storage: 465.76 GiB (39.7% used) Procs: 447 Shell: Bash inxi: 3.3.13
s2idle [deep]
Slept for 15.92 hours
Used 2.82 Wh, an average rate of 0.18 W
At 0.18/Wh drain you battery would be empty in 286.73 hours
For your 53.62 Wh battery this is 0.33%/hr or 7.92%/day
That’s almost 12 days of idle time. Even though I’ve read most of the “battery life” threads on the forum, I was surprised by how much energy the cards consume while doing nothing.
Dino
While pondering the difference in the battery discharge rate captured in my two contributions to this thread I had a wtf moment. I seldom, if ever, examine /sys/power/mem_sleep. When I pasted its content into my original post I didn’t notice that it was [s2idle]. I explicitly set it to [deep] on the command line:
$ cat / proc / cmdline
BOOT_IMAGE=/vmlinuz-6.1.0-1014-oem root=/dev/mapper/sysvg-root ro quiet splash mem_sleep_default=deep
I’ve no idea what caused it to change. Nevertheless, the mem_sleep during my original batterylog capture was s2idle; the most-recent one was deep.
Dino
edit: a bug in the forum posting tool is preventing me from pasting or typing ‘proc’ and ‘cmdline’ separated by forward slashes. Attempting to save a post with that character sequence pops up a message box that says: “403 forbidden”…
Thanks @truffaldino - thats really interesting. Would be interesting to see the original in [deep] - I think you’ve confirmed though that the standby draw on the cards is a big issue - as noted by the post linked further up.
@Matt_Hartley - Many thanks, yes in terms of the core laptop itself this all looks great now, thanks for looking it over. I’d suggest theres still work (presumably in Firmware) to do around the stby current draw on the non-USB-C cards.
