I have a Wacom One S displayless tablet that I’m trying to use with my Framework13. The tablet turns on when plugged in and it shows up in the connected USB devices but gives no input to my laptop when I move the pen over the tablet and doesn’t show up in the Wacom Tablet Finder app. I have Fedora 40 OS and I know the tablet works on other devices so it’s not an issue with the tablet itself from what I can tell. Does anyone know what I can do to have the tablet work with my FW13?
Likely a Linux compatibility problem than an FW13 compatibility problem IMHO.
I use my Wacom successfully on Linux Mint with the OpenTabletDriver https://opentabletdriver.net/. I needed it as I wanted custom mapping of the tablet surface. Can be finicky to set up, but once done, works well. If you run into issues post here.
I installed OpenTabletDriver and now it’s working, thank you so much!!
