CachyOS
Which release version?
Latest rolling
Which kernel are you using?
linux-cachyos: 6.18.2-1
linux-cachyos-lts: 6.12.63-1
Latest, 3.04
Which Framework Laptop 16 model are you using? (AMD Ryzen™ 7040 Series)
AI-300
I’ve installed CachyOS using pretty much all defaults (secure boot is off). Custom partitioning is a 4GiB unencrypted boot partition and everything else as an encrypted btrfs partition.
After rebooting, the bootloader pops up no problem.
After selecting my boot option, the screen just turns black, the power to the keyboard and the LED matrix input modules are completely cut off.
The power button light is on, and pressing it quickly will turn off the system immediately, don’t need to hold it.
I’ve tried everything I can think of and it just doesn’t work…
Booting from usb works 100% of the time.
