I can’t find similar topic from naive searching so maybe I’m an outlier in the statistics? Anyway, the problem is when I put some very light force on some of the keys they will squeak like rubbing a balloon. It only happens to several keys. The worst key happens to be “J” and I happen to be a vim user, so it’s quite annoying. When typing quickly (hammering the keys) there is no such noise but when pressing “J” slowly it will appear. Anyone has similar experience? Is replacing the keyboard the only solution?
I’m also having the same issue with my framework 13. Some keys are worse than others and it only creaks with light pressure.
Same here, mostly with spacebar, and only when I’m using it at a certain angle or with light pressure.
i’m also experiencing the same issue. On every of my 3 keyboards i have owned for my framework 13….
I have this issue and I am able to remedy it temporarily by removing the input module and tightening the screw that fastens the rubber membrane keyboard to the input cover.
