Put it this way: you can take the cards out and plug them into any other device. They’re just individual adapters, like dongles.
I know the USB ones are for certain. I’m almost certain the other ports work the same way, but maybe someone else can confirm. Same should be true for the storage card - you can plug it into your phone and use it like a flash drive.
Therefore you don’t need to do anything, you can unplug them anytime you want, they’re nothing unique, just usbc, that’s the idea!
For anyone unaware - Best practice is to unmount the filesystem before removing the storage card. Maybe “eject” it too. Same for sd-card storage etc.
Other things may be best to remove from use at the software or system level before unplugging them. But adapter cards like USB, DVI, HDMI cards, yeah, unplug - replug at will.
