So has anyone had the fingerprint reader work in Linux and Windows? I had a working fingerprint reader in Linux till I installed Windows and loaded the FP driver. Now in Linux the FP reader just disconects. I did have some FP loaded in a linux install but have never used it in Windows. Kind of sucks and no idea how to fix it have tried everything I have read.
Yes, installed windows 10 first, on primary, set up a fingerprint. Then Ubuntu 21.04, on an expansion card. With a bit of trial and error, following the instructions above, have fingerprint there also.
Trying to install fprintd on Ubuntu 21.10 I’m getting the following error when running meson builddir
Configuring fprintd.service using configuration
data/meson.build:27:0: ERROR: Function does not take positional arguments.
Also I have used fprintd-enroll and it worked for a day… but now the fingerprints have disappeared.
Running Ubuntu 21.10
As an aside:
Why is there no threading on this forum? I feel like github issues or even stackexchange would be 1000x more useful for managing framework issues/questions.
Hmm not sure what happened. I had perfect finger print on multiple linux installs. Had to use python script to de-register some fingerprints. Then once windows was installed it has stopped working in linux.
This looks like an issue specifically with meson 0.60 exposing a bug in the fprintd meson build file.
Here’s another project hit by the same issue (see the last comment in the thread):
You might consider filing a bug with fprintd or checking if they fixed it in the mainline codebase.
Meanwhile you could probably apply the equivalent of their fix:
Mark me down as another person with the windows/linux incompatibility. Installed Arch first, could register and use fingerprints without issue. After installing windows and registering fingerprint there (should’ve known better), fingerprint stopped working in Arch. Python script to delete fingerprint database (run with root in Arch) returns:
<me>% sudo python3 ~/.scripts/libfprint_delete_device_prints.py -d
<__gi__.FpiDeviceGoodixMoc object at 0x7f312f9fdb00 (FpiDeviceGoodixMoc at 0x55b5458681e0)>
goodixmoc
UID714BC975_XXXX_MOC_B0
libusb: error [udev_hotplug_event] ignoring udev action change
(process:2861): libfprint-ERROR **: 09:23:55.088: parse fingerlist error
zsh: trace trap sudo python3 ~/.scripts/libfprint_delete_device_prints.py -d
Not the biggest issue in the world, but would love a method to completely eliminate windows from the fprint system and only use it with linux, if possible. I’ve tried uninstalling/reinstalling libfprint and fprintd, screwing with USB, to no avail.
Hi davis ladd, I followed your guide and it worked well except that I needed to change the “ninja -C builddir install” part to get it to actually install, otherwise I couldn’t proceed.
Once I got everything installed, though, and set up PAM, I rebooted to find it still didn’t work. I get timeouts of over 20 seconds any time I should enter my password. Turns out fprintd is not starting up. It seems there is a regression in libgusb?
FYI I am using Pop OS, but all of the actual packages are Ubuntu, etc., not overridden by Pop.
Yes Snee it sucks worked fine then load windows and bricked on the Linux end. I wish there was a way to erase the memory in the module don’t care if windows or linux at this point.
Thanks to @Davis_Ladd and @Ian_Cleary and everyone else in this thread for the info. I’m on Xubuntu 21.10 and had to do a few extra things to get the fingerprint reader working. I hope you don’t mind I post the full list of what I did (most of it is what you guys already posted with a few extras):
First thing: In addition to the other guides, I had to install libpam-fprintd for fprintd-enroll to work (it timed out without it)
sudo apt install gtk-doc-tools libfprint-2-dev libgirepository1.0-dev libgusb-dev libpam-wrapper libpam0g-dev libpamtest0-dev libpolkit-gobject-1-dev libxml2-utils python3-pip python3-pypamtest git gettext valgrind libpam-fprintd
Next few bits are standard for the other guides
sudo pip install meson
pip install ninja gobject python-dbusmock
git clone https://gitlab.freedesktop.org/libfprint/libfprint.git
cd libfprint && git fetch origin && git checkout v1.92.1
Then
nano meson_options.txt
…and change the drivers>value option from ‘default’ to ‘goodixmoc’
Next, I had to add the install option when building libfprint
meson builddir
Next bit for fprintd is the same but with the install option again when building
git clone https://gitlab.freedesktop.org/libfprint/fprintd.git
cd fprintd && git fetch origin && git checkout v1.92.0
meson builddir
Next, run
fprintd-enroll
…and follow the prompts. If you’re coming from a Thinkpad like I did, note that you place your finger on the reader… don’t swipe it. You’d think it’d be obvious, but I’m an idiot
Finally, run
sudo pam-auth-update
…and check on the fingerprint auth option.
Now I am prompted in XFCE on login and sudo prompts. Thanks everyone for the info!
Sadly, I don’t remember exactly.
The instructions I followed were at the top of this thread, and I had similar problems.
Maybe there are some hints in the original posts?
I did have to combine some things mentioned, like adding am install parameter to the build.
I’m having an issue where my fingerprint reader originally worked perfectly (yesterday, when I got the laptop) and suddenly, while I can enroll fingerprints just fine, I can’t seem to ever verify them - neither with fprintd-verify nor with any system login / PAM / sudo etc. It was working sporadically earlier today (though, somehow, not quite as well) but now it’s just not working at all.
I’m starting to wonder if this is a hardware issue maybe, because I do see that the USB device for the fingerprint reader gets reset every time fprintd starts doing something.
Could anybody who has fingerprints working properly tell me if they see this in their system logs every time a fingerprint action occurs?
Nov 04 02:23:14 geary kernel: usb 3-9: reset full-speed USB device number 2 using xhci_hcd
Nov 04 02:23:14 geary upowerd[925]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb3/3-9
Edit: okay, I actually figured it out. There is something funky going on with fprintd or the goodixmoc driver inside of it.
I noticed that when I ran the fingerprint delete script, it always showed the fingerprint data for the previous time I ran the enrollment, rather than the most recent time. It was most obvious when I tried to use different fingers.
So, because of that, the data that was in the /var/lib/fprint/$USER/goodixmoc folder did not match what was on the fingerprint reader.
I found that I could trick the system by taking a backup of what was in that folder, running fingerprint enrolment again, discarding that new data, and overwriting the old data over it.
Basically,
sudo cp -r /var/lib/fprint/$USER/goodixmoc /tmp/mocbackup
sudo fprintd-enroll -f right-index-finger $USER
sudo rm -r /var/lib/fprint/$USER/goodixmoc
sudo cp -r /tmp/mocbackup /var/lib/fprint/$USER/goodixmoc
sudo rm -r /tmp/mocbackup
Once I did that, it started working fine again!
I’m going to try to figure out how to reproduce this and then write a bug for fprintd. But in the mean time, if anyone has this issue, this is apparently the way to solve it.
Replace both instances of
ninja -C builddir
With
That fixed that issue for me, albeit in a different distro
I’m facing this error, and I also cannot enroll any fingerprints. Does anyone know where I may have gone wrong?
@AndrewGurn Your instructions worked great on Xubuntu 20.10, except that for some reason I got an older version of Ninja. A quick internet search got me on the correct version for the guide, not a big deal. When I rebooted into Windows 11, my fingerprint no longer allowed me to sign in. I reset the biometrics for Windows, then I couldn’t use my fingerprint in Xubuntu. Any ideas?
@CSab6482 that’s the error that anybody who has used the fingerprint scanner with Windows is getting. Not sure how to fix it yet. I personally think it’s probably on the libfprint side, need to skip over unparseable entries.
Looks like you got the same issue as the guy above you. I’m not dual booting Windows, so I got nothing.
Hi everyone,
I have submitted a patch to libfprint that might help a little bit with the dual boot situation. I am not sure how to get things reliably working with both Linux and Windows at the same time, but I think the patch I’ve submitted will at least make it possible to reset the device so it works again.
If anyone is interested in testing it I can put together a guide on how to compile it and make it work. And here’s a python script that will invoke the clear_storage() function (won’t work without this patch, though)
#! /usr/bin/python3
import gi
gi.require_version('FPrint', '2.0')
from gi.repository import FPrint
ctx = FPrint.Context()
for dev in ctx.get_devices():
print(dev)
print(dev.get_driver())
print(dev.props.device_id);
dev.open_sync()
dev.clear_storage_sync()
print("All prints deleted.")
dev.close_sync()
Wow, that worked perfectly! (only tested on Linux, not Windows) You’re a lifesaver
