[TRACKING] Hard freezing on Fedora 36 with the new 12th gen system
This definitely isn’t limited to Fedora. On my Manjaro system, after upgrading to the 12th gen board, I too am seeing hard freezes and hangs that last for a few minutes, then the mouse moves for a moment, then it hangs again.
I’m also on Wayland, haven’t tried X.org yet. Also on the SN850 but I’m fully updated this isn’t an SSD thing that I can tell. For me the issue seems to be more prevalent AFTER resuming from deep sleep. However I have had it trigger not having suspended at all.
@arredoluis So, we have a very close setup; 12th gen DIY, Fedora 36 on an SN850. I have noticed, every once in a while, a brief soft/graphical lock, but the system has never fully locked. To answer your question, I think the longest I have had it on for a continuous boot was a little over 2 days; and that, I did reset/poweroff by choice.
I’m curious, what processor did you opt for, and what RAM?
Presumably, you’re using the GNOME edition of Manjaro? Curious, what Mesa version do you have, and what kernel?
I had this lockup and error message. You can also pull more info with cat /sys/class/drm/card0/error.
I finally landed a stable system today with Arch/i3wm.
My first issue was that I was using the Xorg Intel Video drivers (xf86-video-intel). The last commit was a year ago and they appear to be incompatible with 12th Gen. Removing xf86-video-intel and xf86-video-vesa lets the kernel fallback to modestting and i915 which has better support right now.
$ inxi -G
Graphics:
  Device-1: Intel Alder Lake-P Integrated Graphics driver: i915 v: kernel
  Device-2: Realtek Laptop Camera type: USB driver: uvcvideo
  Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3 driver: X:
    loaded: modesetting gpu: i915 resolution: 2256x1504~60Hz
The next thing I ran into was screen tearing and artifacting. This appears to be a known issue with i3 but I didn’t have any problems on 11th Gen. The solution to that was to run a compositor. Mutter should work and be included with GNOME but I went with picom. This accelerated the GPU hangs and the trick turned out to be switching to the OpenGL renderer picom --backed glx --vsync.
Hopefully this helps someone else!
Same symptoms here: opening the Settings app, then navigating to Keyboard → View and customize shortcuts froze graphics and input twice in a row. Not even SysRq + REISUB worked. Sound, on the other hand, kept going.
Machine: i7-1260p with SN850
OS: Arch with GNOME
First log:
Aug 21 19:18:52 laptop gnome-character[2027]: JS LOG: Characters Application exiting
Aug 21 19:18:59 laptop kernel: Asynchronous wait on fence 0000:00:02.0:gnome-shell[1436]:252 timed out (hint:intel_atomic_commit_ready [i915])
Aug 21 19:19:01 laptop kernel: i915 0000:00:02.0: [drm] GPU HANG: ecode 12:1:0020fffe, in gnome-control-c [2189]
Aug 21 19:19:01 laptop kernel: i915 0000:00:02.0: [drm] Resetting chip for stopped heartbeat on rcs0
Second log:
Aug 21 19:17:24 laptop gnome-character[7651]: JS LOG: Characters Application exiting
Aug 21 19:17:32 laptop kernel: Asynchronous wait on fence 0000:00:02.0:gnome-shell[1647]:ec2a timed out (hint:intel_atomic_commit_ready [i915])
Aug 21 19:17:35 laptop kernel: i915 0000:00:02.0: [drm] GPU HANG: ecode 12:1:0020fffe, in gnome-control-c [7764]
Aug 21 19:17:35 laptop kernel: i915 0000:00:02.0: [drm] Resetting chip for stopped heartbeat on rcs0
Aug 21 19:17:35 laptop kernel: i915 0000:00:02.0: [drm] *ERROR* rcs0 reset request timed out: {request: 00000001, RESET_CTL: 00000001}
Aug 21 19:17:35 laptop kernel: i915 0000:00:02.0: [drm] gnome-control-c[7764] context reset due to GPU hang
Aug 21 19:17:35 laptop kernel: i915 0000:00:02.0: [drm] GuC firmware i915/adlp_guc_70.1.1.bin version 70.1
Aug 21 19:17:35 laptop kernel: i915 0000:00:02.0: [drm] HuC firmware i915/tgl_huc_7.9.3.bin version 7.9
Aug 21 19:17:35 laptop kernel: i915 0000:00:02.0: [drm] HuC authenticated
Aug 21 19:17:35 laptop kernel: i915 0000:00:02.0: [drm] GuC submission enabled
Aug 21 19:17:35 laptop kernel: i915 0000:00:02.0: [drm] GuC SLPC enabled
Aug 21 19:17:53 laptop systemd-logind[872]: Power key pressed short.
@arredoluis as this doesn’t seem specific to Fedora, what do you think of editing the subject? Might give it more visibility.
Something I noticed which might or might not be related: if I boot the machine, bring up the BIOS, and do nothing for a couple of minutes, fan and temperature increase constantly. Does anyone else experience this?
Yes, I experience this as well. I actually can be ‘doing things’ in the BIOS menus and it still happens. Basically, any powered on state that isn’t booted into an OS, it seems to happen. Think I’ve seen others mention this elsewhere as well…
I am. My mesa version is 22.1.6-1 and my kernel is 5.19.1-3.
@M4X what’s the output of
$ lspci -k | grep -A3 VGA
00:02.0 VGA compatible controller: Intel Corporation Alder Lake-P Integrated Graphics Controller (rev 0c)
	Subsystem: Device f111:0002
	Kernel driver in use: i915
	Kernel modules: i915
and
$ inxi -G
Graphics:
  OpenGL: renderer: Mesa Intel Graphics (ADL GT2) v: 4.6 Mesa 22.1.6
@Eddie_Zaneski
~$ lspci -k | grep -A3 VGA
~$ inxi -G
Graphics:
  Display: wayland server: X.Org v: 22.1.3 with: Xwayland v: 22.1.3
    compositor: gnome-shell v: 42.4 driver: X: loaded: intel
    unloaded: modesetting,vesa gpu: i915 resolution: 1128x752~60Hz
@M4X yea I think you’re using the Xorg Intel driver when you want to be using modesetting.
…loaded: intel
unloaded: modesetting…
Try removing them, rebuilding initramfs, and rebooting.
pacman -Rsu xf86-video-intel
pacman -Rsu xf86-video-vesa
mkinitcpio -p linux
For folks seeing a hard freeze issue, could you share:
  1. Which distro you are using (most reports here are for Fedora 36, but there are some mentions of other distros).
  2. Which kernel you are on (you can run “uname -v” to check)
  3. Whether you’ve adjusted any kernel parameters, like setting the workaround to disable to ALS (module_blacklist=hid_sensor_hub)
  4. What model of SSD you are using
  5. What circumstances you are seeing the freeze during (e.g. when using a specific application like Settings or uncorrelated to a specific application)
Done, but a crucial piece of information is still missing, i.e. how do I buy you a beer?
In other words, the above fixed the freeze. Thanks @Eddie_Zaneski !
@nrp :
  • Distro: Arch
  • Kernel: #1 ZEN SMP PREEMPT_DYNAMIC Wed, 17 Aug 2022 14:28:00 +0000
  • Additional kernel parameters: none
  • SSD: SN850 bought together with the laptop, with no attempt at updating firmware
  • Circumstances: whenever accessing Gnome Settings → Keyboard → View and customize shortcuts
And:
  • Fix: removing xf86-video-intel and xf86-video-vesa as suggested by @Eddie_Zaneski above.
Do you still have hardware acceleration in, for example, Firefox?
Looks like I do. CPU stays low on 8K videos, and about:support shows:
HW_COMPOSITING:
available by default
OPENGL_COMPOSITING:
WEBRENDER:
WEBRENDER_QUALIFIED:
WEBRENDER_COMPOSITOR:
disabled by default: Disabled by default
blocklisted by env: Blocklisted by gfxInfo
blocked by runtime: Cannot be enabled in release or beta
WEBRENDER_PARTIAL:
WEBRENDER_SHADER_CACHE:
WEBRENDER_OPTIMIZED_SHADERS:
WEBRENDER_ANGLE:
unavailable by env: OS not supported
WEBRENDER_DCOMP_PRESENT:
disabled by user: User disabled via pref
unavailable by env: Requires Windows 10 or later
unavailable by runtime: Requires ANGLE
WEBRENDER_SOFTWARE:
WEBGPU:
blocked by runtime: WebGPU cannot be enabled in release or beta
X11_EGL:
DMABUF:
VAAPI:
disabled by default: VAAPI is disabled by default
VP8_HW_DECODE:
VP9_HW_DECODE:
DMABUF_SURFACE_EXPORT:
blocked by default: Blocklisted by gfxInfo
@nrp
I am also seeing these hard freezes. Here is the information you requested:
Framework 12th gen DIY i7-1260P
  1. Fedora 36 (Wayland)
  2. Linux framework 5.18.17-200.fc36.x86_64 #1 SMP PREEMPT_DYNAMIC Thu Aug 11 14:36:06 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
  3. args=“ro rootflags=subvol=root rd.luks.uuid=luks-7f6bf378-c530-43fe-8a9b-cbcbc768fa66 rhgb quiet module_blacklist=hid_sensor_hub”
  4. WD SN850 (WDS500G1X0E-00AFY0)
  5. For me it has only ever happend in Gnome Settings, in various menus. Menus I recall it happening in: Accessibility, Power. It doesn’t happen everytime I go to these menus or Gnome Settings, though. I haven’t recognized any other patterns.
Appreciate any attention given to fixing this if possible!
@nrp
For me, I have gotten the random lock-ups in gnome, but more so after coming out of deep sleep. Coming out of deep sleep is really bad with lock-ups and the screen flickering sometimes.
  • Manjaro
  • Wayland
  • Linux framework-manjaro 5.19.1-3-MANJARO #1 SMP PREEMPT_DYNAMIC Sat Aug 13 06:34:52 UTC 2022 x86_64 GNU/Linux
  • GRUB_CMDLINE_LINUX_DEFAULT=“quiet cryptdevice=UUID=f4b6f1c0-1866-48b5-bb34-cbc1810a1054:luks-f4b6f1c0-1866-48b5-bb34-cbc1810a1054 root=/dev/mapper/luks-f4b6f1c0-1866-48b5-bb34-cbc1810a1054 splash apparmor=1 security=apparmor udev.log_priority=3 mem_sleep_default=deep nvme.noacpi=1”
  • WD SN850 (WDS200T1X0E-00AFY0) - fully updated
@nrp Here’s my config
  1. Fedora 36
  2. Kernel: 5.18.18-200.fc36.x86_64
  3. No additional kernel parameters
  4. SSD: WD SN850
  5. Freezes when using gnome settings (has been a while since I have tested)
Just thought I’d share that I’ve not yet experienced any hard freezes on F36 and the one difference between my setup and the ones posted here is that I’m using a different SSD (Samsung 970 Evo Plus).
@nrp
Had my first hard lock-up earlier (though, I have previously seen similar but brief lockups, that ended under 20 seconds.) This time, full lock, with screen still showing frozen display (i.e. didn’t blank), and CPU fan kicked up really quick into high after about 1 minute of sitting locked; after this, noticeable temp ramp over maybe 1.5 to 2 minutes, thru chassis. Forced power off w/ long button press, due to concern about heat.
  1. Fedora 36
  2. 5.18.18-200.fc36.x86_64
  3. I did set that exact ALS sensor workaround that you mention, via the grubby method found in Fedora install guide. Otherwise, kernel untouched.
  4. SN850
  5. Just browsing w/ Firefox (maybe there was a terminal open on another workspace, but nothing running in it, if so.) Maybe 10 or so tabs, some sites with probably mildly heavy javascript (Indeed, browser client of Discord, nothing else with any weight at all.)
