Transfer speed limited to 1.3GB/S between nVME SSDs on Laptop 16 & Linux
Hello,
I am using a Laptop 16 with the Dual M.2 extension card Under Ubuntu Desktop 22.04.1
So I have 3 nVME SSDs in the system, the 2 WD on the motherboard and 1 Lexar NM790 2TB on the extension card.
I am using my laptop as a desktop, meaning the cover is closed, AC is always on, using external screen (HDMI via laptop port).
Other devices connected are keyboard, mouse, webcam, bar code scanner and infra-red sound remote control; all via a USB (via USB-A laptop port) Dell docking station.
Last is an external 2.5Gb/s RJ45 network interface via laptop USB-C port.
WIFI and Bluetooth are off.
When I benchmark each SSD individually, results comply with SSD specs (between 5000 and 7000 MB/s for sequential load).
The problem is that transferring big ISO files (close to sequential load) from any SSD to any other one (so being on motherboard or on extension card) is limited to a deceptive 1.3GB/s !
Copying my big “Document” tree (close to random small files load), the speed is around 650MB/s (half the speed for random small files looking normal to me).
For copying big ISO files, I was expecting to see something between 4 and 5GB/s as transfer speed.
Is that normal or is there something wrong somewhere ?
Thanks for your help
Eric Collart
You may be running into a similar issue I ran into with my usb4 ssd, benchmarks usually are multi threaded, single threaded coppy can’t saturate the ssd anywhere near as well. Sequential single threaded dd maxed out at a bit under 2GB/s which led me down a whole rabbit hole before I figured out that a multi threaded benchmark saturated the full usb4 link just fine.
In your case all your ssds have their own dedicated pcie4x4 links to the cpu so bandwidth itself should not be an issue. The ssds themselves being the limit is also not likely as they are tlc drives with pretty good native flash speeds so even after the slc cache is full they should be able to do a lot more than 1.3GB/s.
Hello,
thanks a lot for your interresting reply !
I used Copy/Paste with Nautilus (file manager for Ubuntu) to perform this copy test and it can be it is single threaded, I don’t know.
I will do another test with rsync that is multithreaded and give the result here…
Is there any other tools I could use (preferably using GUI) to do such test in good condition ?
Again, thanks a lot for your very appreciated help
Eric
I used kdiskmark but that doesn’t test coppy between drives.
Hello again,
it seems we are not lucky under Linux as I tried rsync (from terminal), Grsync and FreeFileSync with no luck: they all stuck to 1.3GB/S max !
A small search on internet reveals work done by developpers around multi-copy/multithreaded tool is really old (10 years or more)…
I have a friend running Windows 11 (with an Intel CPU) and there is no such limitation, the copy reaches more than 4GB/s…
As 1.3GB/s is already not so bad for me and as I don’t want to cheat with my OS, this thread can be terminated as unsolved.
Eric Collart
Afaik rsync is single threaded and relatively compzte intensive no not a very good test here.
there is a good chance windows copy is multi threaded but you could test it yourself using windows to go or something.
Hello,
Testing with Windows To Go looks a good test to me as my friend’s PC is not a Framework laptop…
I’ll try that path but it will take some time …
I’ll also open a support ticket pointing to this post so they’ll be aware and, who knows, have any kind of official answer…
Huge thanks again to you, I wish you the very best 2025 possible.
Eric
The drag and drop of a bunch of files appears to do a multi-threaded copy.
Hello,
I finally get a Windows To Go to boot Windows 10 and the speed transfer is 2.4GB/s under Windows !
To perform that test, I used 2 nVME SSDs on Dual M.2 adapter, 1 is a gen4 Lexar NM790 (the target of the copy test) and the 2nd is a gen3 Adata SX8200PNP (the source of the copy test) both formatted in NTFS. Given the fact that the source SSD is a nVME gen3, a transfer speed of 2.4GB/s is very good !
I redo the very same test using same SSDs (and same NTFS partitions) but booting Ubuntu 24.04 (not a live key) and the transfer speed was … 1.2GB/s !!!
I think it’s clear that it is Linux that is limiting the transfer speed on my Laptop 16 !
I will update the opened support ticket on that subject.
Anyone seeing same trouble ?
Eric Collart
Same problem with something that’s not ntfs?
Yes, the original test was done using ext4 partitions and gave similar results…
Eric
have you found a way to do a multi threaded copy on linux.
I assume you tested both the target and source ssd individually using kdiskmark or something and got reasonable values?
Hello,
Yes, I used kdiskmark on all SSDs individually and results are close to specs so looking normal…
It is the copy between 2 SSD that seems to be limited…
I don’t know if copy under Linux is single or multi-threaded but it should not be a problem if the software can use available bandwidth…
Close to specs using Windows, limited speed using Linux; both on same hardware => problem is Linux software !
Eric Collart
The copy being multi threaded is a part of the software and is likely the reason the software can’t use the available bandwidth.
What file manager are you using to do the copy on linux? Have you tried different ones?
Hello,
As mentioned along that conversation, I do the test with Nautilus using cut & paste (not the best but, again, it works fine under Windows).
I used once FreeFileSync but it was also capping at 1.3GB/s …
For me this thread is becoming too long and starts running in circle even if I really appreciate all efforts done so far…
I am now expecting some feedback from the support ticket I opened also.
For me, even if it is not normal, I can work with 1.3GB/s as I, by far, prefer Linux to Windows.
Eric
It might be wort trying one of the quite rediculous ammounts of other file managers than nautilus and see if those are faster. I have unfortunately not found one jet that completely covers the feature set of windows explorer that I normally use, gotta hand that to microsoft, it’s a pretty nice piece of software.
I am quite curious what results that is going to yield.
I will of course update this article with any constructive reply from support.
Among all tests done, I did one with a Live of Fedora 41 and results are similar (but Fedora also uses Nautilus).
When I’ll be more motivated, I’ll try with some other distros live and we’ll see… Suggestions welcome…
Eric
You don’t need special distros you can just install the file managers separately, there is a ton of them though and finding one you like may be somewhat difficult. I tried myself through a bunch of those last year and I do remember some having settings for multithreaded copy.
I can find multithreaded download file manager but no indication for local file manager.
I will investigate backup tools… This speed limitation looks crazy and frustrating to me…
Eric
As an unga bunga test you could just try to do multiple nautilus transfers at the same time and see how much the bandwidth adds up there.
