I can appreciate the performance gains from leaving CPU boost on, but honestly, I don’t like hearing the fans spin up and I have some concerns about the fan intake being on the bottom of the laptop. Is there a way to turn off CPU boost to keep things more quiet more often? I’m not worried about limiting the clock speed to something slower - I’m not doing CPU-intensive work on this machine.
to follow up on this:
joined the Framework Discord server and asked the same question - sounds like Framework Chromebooks don’t have the same firmware / BIOS setup as the Windows, Linux, or DIY editions. So turning off Intel Turbo-boost might not be an option (yet).
Unfortunately, it seems like no one who has a Chromebook edition has reported to the user-sourced BIOS guide here. Hopefully that can be updated soon. It’s possible Framework could offer you some help with this, in which case opening up a support ticket is the way to go if you haven’t already. Definitely report back here if you’re able to get an answer, and sorry I can’t be more helpful, I don’t have the Chromebook Edition and don’t know enough about ChromeOS to know if there is a solution within the operating system.
I’m sorry for the wrong information!
I’ve deleted my post. Good luck!
No problem at all! I’m not perturbed in the slightest.
I have reached out to support a la @Azure 's suggestion and I’ll report back when they get back to me!
Support got back to me. Unfortunately with ChromeOS, our assumptions have been confirmed - no way to access the BIOS for now. Hopefully, Google introduces a way to configure BIOS-level settings via chrome://flags later on!
@Fletch or someone using Framework Chromebook. Could you install dmidecode on your Chrome OS?
How to install dmidecode
If you can access Debian-based Linux, you can install it by the command:
$ sudo apt install dmidecode
If you can access Fedora-based Linux, you can install it by the command:
$ sudo dnf install dmidecode
How to check the BIOS info
Here is the result of the commands below on my Framework Laptop Intel 11 gen. Not Chromebook Edition. I think you see different info about your BIOS on your Chromebook Edition. I am curious to know your result by the commands.
$ sudo dmidecode -s bios-vendor
INSYDE Corp.
$ sudo dmidecode -s bios-version
03.10
$ sudo dmidecode | less
BIOS Information
Vendor: INSYDE Corp.
Version: 03.10
Release Date: 07/19/2022
Address: 0xE0000
Runtime Size: 128 kB
ROM Size: 12 MB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
8042 keyboard services are supported (int 9h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 3.16
@junaruga , thanks for your suggestion!
dmidecode did install successfully, however, even running with sudo the files are off-limits:
fletch@penguin:~$ sudo dmidecode -s bios-vendor
/sys/firmware/dmi/tables/smbios_entry_point: Permission denied
/dev/mem: No such file or directory
fletch@penguin:~$ sudo dmidecode -s bios-version
fletch@penguin:~$ sudo dmidecode | less
fletch@penguin:~$
This was done from within the Linux container. I am curious if someone were to set their Chromebook to developer mode, if they would be able to use crosh to run these commands. However, I like using the stable branch of ChromeOS which means this has turned into more of a thought experiment than something pragmatic for me.
@Fletch thanks for the report! OK. Interesting. What I know is ChromeOS is a Linux-based OS. I have not used ChromeOS. If the result is done within the Linux container, perhaps, there may be a way to run a Linux container in a privileged mode that’s like Docker. I hope we will find a way to see the BIOS info.
I found a clue to access the BIOS from this thread on Reddit. And the developer mode document is this: ChromiumOS Docs - Developer Mode
Caution: Modifications you make to the system are not supported by Google, may cause hardware, software or security issues and may void warranty.
