[Tutorial] Improve sound quality on integrated speakers
When looking at https://equalizerapo.com/contact.html
…and please note that we’re not the official developer of this software, therefore issues related to source codes are beyond our expertise. In such cases we advise you to contact the developer directly. We are here to help if you need any assistance with setting up the Equalizer APO.
and
This website should be used only as an informative source and not as an official reference.
So not the official source, maybe the sourceforge page is the project home?
I found adding thin rubber pads to the top and bottom of the speakers helped. They also helped firm up the keyboard when placed on other flat areas under the keyboard. They are the smallest ones in this set. About 1mm thick and 6mm in diameter.
https://www.amazon.co.uk/gp/product/B0140WM84O/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Yes, it seems like that is where the code lives - as well as the releases.
Thanks! That really does help. Now if I can only get the whole thing to stop rattling at any volume over 50%.
I’m running Ubuntu 22.04 and was able to get EasyEffects working after I uninstalled PulseAudio and replaced it with PipeWire following this guide then I was able to see my outputs and adjust the EQ from there.
On another note I have the 80db speakers and the presets do definitely reduce the muddiness of them as well. I can’t say how accurate the sounds are now as I have no way of testing the audio other than to listen but I’m enjoying it a lot more now
I think the best thing to do is fire up some tunes you know well and just adjust till you like what you hear the most. Don’t worry about “accuracy” go for what sounds good to you.
@elagil
I am using your APO file with Easy Effects (Fedora Linux) and it does sound a lot better! I also decreased the input by -5db.
I got a question, were you able to automatically create the 5-band eq, or did you create it manually? If automatic, why not include more bands?
Thank you
That’s great to hear!
This is a manually created profile. I could add more bands, but there is not much benefit to that, as the achieved flatness is already satisfactory.
Also, equalizing minor deviations from the flat target is not always a good choice, as they could be caused by measurement errors, diffraction, the influence of the room, or other factors.
Agree. This is a sweet spot for a community-level profile. Anything more would be very specific to the measurement environment.
I think perhaps a disclaimer at the top that in my tests this pretty much doubles power consumption when audio is being played:
Interesting find! I would have to test on Windows as well.
It does not seem like I can change such old posts (opening post) anymore.
Many people have found that the built-in microphone sounds very distorted in Linux. If you’re already got Easy Effects running for your output profile, you can also switch to the inputs tab and add an AutoGain filter to fix that.
Are there significant differences in running Equalizer APO vs running FxSound?
(i.e. batter life, DPC latency, etc?)
(e.g. see the similar work done by ‘banzai_420’ on:https://www.reddit.com/r/framework/comments/18cngrn/improving_perceived_sound_quality_on_the_fw13/
After briefly checking what FxSound offers, I don’t see the capability of defining Q-factor for filters, or arbitrarily setting center frequencies. The latter might be possible, though.
Therefore, it does not qualify for use with my preset. You will probably not be able to replicate my filter curve.
@elagil Is there maybe a possibility for you to create a custom equalizer profile for the Framework 16 as well? I think there should be quite some room for improvement, the stock tuning is not on point and sounds pretty bad, at least compared to my excellent Samsung Series 9 laptop speakers.
Sure, if someone sent me the device to measure it :wink:
Without measurements, I cannot create a filter.
Alright, I kinda hoped that you maybe ordered one yourself or know someone who did. If you’d be residing somewhere along the Hamburg-Berlin latitude I would’ve brought my FW 16 to your door, but I guess you are unfortunately more remote than that. :sweat_smile:
I’ve had trouble with bad trebble resonance causing a high picth shrill sound on certain frequencies.
After a lot of testing, this is the EQ I got that almost completely removes it. Notes that I have the louder 80DB speakers so use this as a platform to tune your own.
Hope this helps someone!
