I’m currently converting my 11th-gen mainboard to a standalone server in the CoolerMaster case.
I had previously applied the RTC battery fix, soldering and cutting the mainboard.
However, now that there is no more main battery, each power disconnect resets all the BIOS settings, which is very inconvenient, especially because I use the “start when power plugged” setting (which is never applied because immediately forgotten).
So I’d like to revert the RTC fix. Do I need to “repair” the PCB trace that was cut? Or is it enough to just remove the fake-RTC and put back the real RTC?
EDIT: I never cut the trace, actually. I got all mixed up by reading the previous version of the fix now, and not remembering properly what I had actually done.
