I am a product design student, I’ve decided to base a project around reparability in electronic products. Headphones stand out to me as an easily breakable and a hard to fix product. My project will aim to tackle these problems and create a new product.
Framework is a big inspiration for this project and im curious about what the community thinks to this idea and would love to hear any input.
So …
Do you think this would be a viable product? What Features should it have? What can I do to make it Reparable? How would this idea manifest itself? Any ideas or inspiration would be helpful.
A log of high-end “audiophile” headphones have repair parts available, ear pads, cords, things like that. One feature might be offering that at a reasonable price
A): Make everything that bends swivels or moves in other ways out of metal. No need to be repairable if it doesn’t break.
B) No wire, have the headphone have a mini-xlr or at least TRRS plug
C) If you want it to also be wireless, make the battery replaceable and some kind of standard form factor, e.g. 14250
D) If there is software, open source it
E) Use a form factor for the earpads, that’s compatible with a major brand, like beyerdynamic. So that replacements can be had, even long after you lost interest in the product
You should check out the DT770’s from beyerdynamic. They are legendary for their build quality. Metal band, no rotating parts, hard plastic cans. In particular the DT770 Pro since they have a detachable cable. I bought them for the -40 C winters in canada to use as earmuffs tbh, I have no doubt that they’ll outlast most things I own.
Your idea is very viable. Focus on using durable materials for moving parts, replaceable earpads and batteries, and modular wiring. Open-source software and standard connectors can extend lifespan. Designing for easy disassembly will make repairs simple and keep the product sustainable.
