Hello, I have a background in network engineering, custom desktop building, and I’m just delving into some PCB design.
Here are my thoughts about what needs to be done for me to get one of these laptops. And I know many others will agree with the point I am going to lay out.
Starting with a basic list of thing, I will go in more detail further on;
- Independently upgradeable DGPU (not EGPU)
- 6 expansion ports. And more HAT variety.
- Multigenerational CPU socket.
- Different display options.
- More laptop sizes
- LTE modem
That’s the short list. I have this idea that I think would accommodate pretty much all of those. I personally like 15” laptops. The next step down for me is tiny like a 6” laptop. Anything else I would just use my phone or something. So if you where to make a 15” model with the battery up the middle with the CPU/MB on the left you could have the cooling towards the back and back side. You could then have 3 expansion HAT slot towards the front side of the laptop. You could then use the entire right side as a “large addin card”. Could put in a DGPU and it could follow the same cooling and HAT principles as the CPU board for a total of 6 ports, 3 per board. Or you could make it a HDD spot, Second battery, dedicated capture card, ODD drive in place of the 3 HAT ports, whatever you could think of that would fit in the space. Would just be connected via a 16x ribbon cable I would think under the main battery.
As for the screen. There should be touch and non touch versions I feel of every display possible. With that said, there should be a 4K option, an OLED (possibly 4k) option, there should be high refresh rate versions with VRR support VA Or IPS type. It should also be nice if the webcam was swappable with a windows hello version.
It would be nice if the CPU could be socketed, but I totally get it if it can’t with power budgets and the like, a DGPU addin card would also probably facilitate needing a better power in that USB C.
I think there needs to be more HAT versions, some with more multiple ports. Perhaps a wider HAT as well. It would be nice if the one HAT could have 2 USB A ports as an example, Or how about Ethernet, Or an Cellular modem, or a full length M.2 slot in an enclosure, mini mouse?, separated audio jacks, how about a recessed USB port for mouse dongles, as mentioned above what about being able to swap say all the IO on the right side with like a disc drive or capture card inputs, hot swappable HDD bay. The list goes on.
I have I have made a point and sparked some thoughts, but for me a computer is just not that useful without a DGPU unless it’s absolutely tiny. Love the project by the way, would probably instantly make this my new daily driver if the things mentioned where to be addressed
and preferably real home/end/pgup/pgdn. Like the Lenovo Yoga3 1470 that I’m currently using
