- USB-C
- 2nd USB-C
- 3rd USB-C
- 4th USB-C
- USB-A
- 2nd USB-A
- HDMI
- DisplayPort
- MicroSD
- 250GB Storage
- 1TB Storage
0 voters
We’d love to hear which Expansion Cards you’d configure in your Framework Laptop. You can select up to four options in the poll.
0 voters
My default setup will probably be 2x USB-C and 2x USB-A, kinda like how the Razer Blade Stealth is configured.
I’m holding on for confirmation that the USB-C will do thunderbolt. I have docking stations that use the USB-C/TB and if I can port replicate that way, I won’t need external display, freeing up another slot for USB-A or MicroSD.
I just need one usb-c, display port for a desktop setup with my monitor I was gonna replace, and use the last two slots for 1tb each for storing my media
Full size SD, RJ45, twin USB-A, twin USB-C.
I’m with @Ben_S; I’m not sure what the point is voting when I’m holding out for ethernet. (And possibly dual-port cards, since having less than five ports is near-showstopper for me. Dual-height cards FTW!
Or at least dual USB-C, maybe solving the not-enough-space problem by having one port be power in only.)
Yeah, that sounds spot-on, actually.
I’m going with 2x USB C, 1x USB A, 1x HDMI. I need USB C on both sides mainly so I can easily charge on either side of the laptop, and I need the USB A for a USB Drives, and an HDMI for easy monitor connectivity.
