Keep losing Bluetooth and WIFI ?
Framework sent me a new 11th Gen motherboard as i was having problems with the RTC battery and the laptop would not power up on battery power only when the charger was plugged in (RTC battery would go flat). Problem started with new board. Running Windows 11 pro (new install and key) Framework sent a replacement WIFI and BT card the standard one. BIOS is the latest and the drivers.
Hello! This may be a problem with the antennas!
They’re known to be a bit fragile, and it’d be a good idea to check them out
However, there may be damage that’s not visible, and it may be worth replacing them with some $3 cables off aliexpress!
