Just noticed that suddenly my wireless card (original AX210 no vPro version from Framework) started massively consuming power, for no particular reason.
I tried switching to the flight mode but apparently nothing had changed. Usually it takes around 1.5 W even in active mode.
I’m using Kubuntu 21.10 with TLP installed. My WiFi base station operates in 5GHz mode and is couple of meters away, signal level is around 83% to 100%.
Update: When I unplugged the charger and plugged it back again it dropped down to usual values of ~2 to ~4 W.
