I woke up to a dead laptop that wont even load the bios, the post code it gives is GGRGGGGGRRGG and after orange light its all green. Can you guys help?
Edit: missed the third red light
You may have found this already, but in case you didn’t: it’s guide to interpreting the flashed code.
However, if the board is confused due to a depleted CMOS battery, I’m not sure the flashed codes are trustworthy.
At what point can we actually ask for a permanent fix / some kind of a recall? Can we even just start with asking if this question can be asked?
To whatever you seem to think is related in your first reply to this thread.
according to the post code, it appears that you have an issue with VCCIN_AUX, Fan Detection, and CPU reaching S0 state. I would recommend contacting support, so that they can help you if you are having hardware issues.
So, my laptop was working fine(it was having the bug where it needed to be plugged into power on, but I updated the firmware and BIOS and it seemed ok). It has been sitting in my bag for about a month, and now will not power on, nor will it charge(charger connects but no light comes on). I tried reseating the battery but that did not work. Has anyone had this issue to this extent?
EDIT: And yes, I made sure the charger works; it charges my tablet just fine.
What is this CMOS battery exactly for? To power the internal clock? Why does it last only 3 weeks? What does deplet that battery that fast? Can it be replaced?
Did you follow Fully Resetting the Mainboard State - Framework Guides completely? It asks you to disconnect BOTH the main battery and the CMOS coin cell and leave the board like that for a couple of minutes, to ensure a full reset.
If doing that solves your problem then: yes, other people have experienced this. If not, then you may have encountered an even worse problem/defect.
The usual method is to disconnect the battery plug and CMOS battery for a couple of seconds and then reconnect them. The charging light should start flashing red and then you can charge the laptop again. If this is 11th Gen of course. This is not supposed to be an issue with 12th Gen boards. That is, if it’s the issue of the CMOS battery drain.
